Gen5DIY
Old 09-23-2008, 06:20 PM   #1
bobscogin
Drives: 2016 Challenger R/T, 1965 Impala SS
VVT on L99, or what?
I'm looking at the cut away illustrations of the LS3 and L99 on http://www.gmhightechperformance.com
Compare the timing gears/chain on the two engines. The LS3 cam gear looks like you'd expect, but the L99 looks much different. It's obviously more than just a timing chain cam sprocket. Is it part of the AFM system (don't think so), or some sort of VVT mechanism, or what?
Bob
bobscogin is offline   Reply With Quote
Old 09-23-2008, 07:54 PM   #2
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
it is part of the AFM system but i cant explain it
headpunter is offline   Reply With Quote
Old 09-23-2008, 08:37 PM   #3
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:155 ban
Old 09-23-2008, 08:41 PM   #4
bobscogin
I can't explain it either. I thought the AFM was operated by solenoids and a valve body in the crotch of the cylinder bank. The cam "sprocket" looks like it could be one of those hydraulic cam phase changers that are used to vary timing, but of course without individual intake and exhaust cams, it would phase shift both intake and exhaust lobes simultaneously. Anyone know?
Bob
Old 09-23-2008, 11:47 PM   #5
SoFlaZ
SoFlaZ's Avatar
Drives: Nothing special :-(
The VVT and AFM are independent systems but probably work together for the best efficiency. AFM just has collapsible lifters and the cam phaser I THINK moves the intake and exhaust together. It seems REALLY expensive to have a 2 in 1 type of cam but I could be wrong. I would assume also the VVT is hydraulically operated as is the AFM is.
SoFlaZ is offline   Reply With Quote
Old 09-24-2008, 07:09 AM   #6
rayhawk
rayhawk's Avatar
Drives: Trailblazer SS
It is possible to have a cam in cam system, and vary the intake and exhaust valve timing relative to each other, dodge does it for the new viper. However, from what I understand, the L99 simply varies the timing of the camshaft. Think of it as advancing or retarding the camshaft as the engine is running based on engine conditions. For the L99, VVT may have more to do with optimizing the engine for 4 cylinder vs. 8 cylinder operation than with anything else, but I am not too sure. If it made a big difference to fuel economy or increased performance, I would think you would have seen the VVT on the LS3.
Hooters, hooters, yum yum yum, hooters, hooters on a girl thats dumb.
-Al Bundy
07 2WD Trailblazer SS, LS1 E-fans, 4" FWI, pcmforless tune
rayhawk is offline   Reply With Quote
Old 09-24-2008, 09:24 AM   #7
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
I checked the catalog and GM calls that cam sprocket a "camshaft position actuator." I found it on a '09 1500 hybrid with the 6.0 "LFA" motor. Thats the only thing I could find it on. It also shows a "actuator magnet" on the front of the timing cover.
Robert91RS is offline   Reply With Quote
Old 09-29-2008, 02:49 PM   #8
ohnonothimagain
Drives: none
If this has been discussed I apologize(I didn't see it), but does anyone out there have concerns/issues with the L99 having the AFM and shutting down cylinders ? I KNOW the electronics/management is far better than it used to be(the Cadillac 4-6-8)-but I guess I'm too old school to accept technology such as this. I figure the more technical and advanced it is-there's just all that much more to break down and fix. Thanks for a great forum.
ohnonothimagain is offline   Reply With Quote
Old 09-29-2008, 02:50 PM   #9
The_Blur
Jayhawk USN
The_Blur's Avatar
I imagine your concern is lag. That will not be a problem with the L99.
TO: Camaro5//
warn 145:155 ban
Old 09-29-2008, 02:54 PM   #10
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I don't know how long AFM has been out...I want to say 4-5 years...but I've never read anything about it breaking down or failing. No articles, no recalls, no reviews, no posts...
I'm certainly no authority on the subject, but the only negative aspect to AFM I've heard reported is an awkward exhaust note when the system is engaged.
Old 09-29-2008, 03:46 PM   #11
Jamestwilliams
junior member
Drives: Grand Am
It was first introuced on the Cadillac sixteen, it had 4,8,16, and 1000hp. The engine was just for testing upcoming tech particularly cylinder deactivation. Although it was a fully operational engine they stuffed it in a Suburban with a hell of a lot of effort. It's too bad they didn't build that caddy though, the sixteen would have put everything to shame period.
Jamestwilliams is offline   Reply With Quote
Old 09-29-2008, 03:48 PM   #12
fierodeletre
Drives: 02 WS6 TA, 88 Fiero Formula
Interesting that GM doesn't market the L99 as an AFM VVT engine even though if you're altering cam timing, that's what it is. Notice that the VVT in the 5.7 L hemi bumped it up form 340 hp to 375 and over 400 pounds torque. You'd think that if this system is slated to go in the L99, that GM would market it as such.
fierodeletre is offline   Reply With Quote
Old 09-29-2008, 07:32 PM   #13
ohnonothimagain
Drives: none
RE: What Chevrolet calls AFM is NOT new-Cadillac had it during the early 1980s with a variable displacement engine, branded the L62 V8-6-4 engine. Introduced in 1981, this 6 Liter engine selectively activated and deactivated cylinders according to power demand. Cadillac hailed the engine as cutting-edge; but it proved unreliable and was scrapped. What goes around comes around-that's why I've been concerned about vehicles with cylinder deactivation. That's what I was trying to say-and I just hope that it's not too complex that if/when something goes wrong-it's not MORE expensive to fix than a car without AFM....Just my humble opinion; it could cause Camaro lovers to hate that feature.
Old 09-29-2008, 08:04 PM   #14
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
When I worked at a dealership, I was told by the GM reps that it is a totally different animal than what was in the Cadillac... The way that it is designed, IF it ever does malfunction, it just wont deactivate the cylindars and will stay in V8 mode... you don't have to worry about it getting stuck on just 4.
Sterling is offline   Reply With Quote
Why the L99? The Vette uses a LS3 with Auto 6-sp! Why cant the SS Have this option? D-Unit Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 21 02-17-2009 08:16 AM
Advice---Supercharged L99, S/C'd LS3 or LS9? CamaroZR1 Forced Induction - V8 25 09-25-2008 10:21 AM
Tuning the L99 Lifted07Sierra Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 09-02-2008 11:28 AM
L99 discussion The_Blur Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 85 07-25-2008 03:07 PM
L99 Theory, Gas Guzzler Tax pruettfan 5th Gen Camaro SS LS LT General Discussions 12 07-22-2008 02:06 PM
