Gen5DIY
Old 03-12-2010, 06:24 PM   #1
V8Addict
V8Addict's Avatar
Drives: 2016 2SS
Any way to disable Auto Headlights Permanently?
Does anyone know how to permanently turn off the auto headlights on the SS? I know I can temporarily turn them off but it resets itself to auto....sometimes I want complete control.
V8Addict is offline   Reply With Quote
Old 03-12-2010, 06:38 PM   #2
XTREMESS
XTREMESS's Avatar
Drives: 2011 CAMARO 2SS SYNERGY GREEN MET
you would need an alarmguy(a good one) to set up a relay to pulse whattever that switch pulsesto the bcm , everytime you turn on the car
thats it!
XTREMESS is offline   Reply With Quote
Old 03-14-2010, 07:03 PM   #3
Jer4251
Camaro Addict
Jer4251's Avatar
Drives: too many
in the older cars, it was just a resister in the dash sensor.
2013 ZL1 Vert
1990 IROC-Z Vert
1996 SS Vert #1468
1991 Z28
2014 Sierra Denali
Jer4251 is offline   Reply With Quote
Old 04-23-2010, 02:37 AM   #4
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
ALL you need to do is open the switch and remove or cut the spring that makes the knob come back to "Auto", once you remove it, you will be able to leave it at "Off" and move it as you wish.
it only takes like 10 minutes.
christianmotox is offline   Reply With Quote
Old 04-26-2010, 04:58 PM   #5
NEGXXIS
NEGXXIS's Avatar
Drives: 2016 Camaro SS A8
I did basically the same thing to my switch. works great
2016 Camaro SS – factory Summit White - Avery Satin Pearl Nero Wrap with Carbon fiber and gloss black accents – Anderson Carbon Rear Spoiler – Ikon front spoiler – Oracle LED smoked side markers – GM Dark Tail and third lights - Phastek 1.5” Lowering Springs - MRR 228 Wheels 20x10 and 20x11
2004 Chevy 2500HD Diesel - 601 rwhp / 1089 rwtq
SOLD - 2010 Camaro SS - Featured in GM High Tech Performance and Camaro Now Magazines - http://www.superchevy.com/features/g...of-perfection/
NEGXXIS is offline   Reply With Quote
Old 07-04-2010, 05:31 PM   #6
IamJacksCamaro
IamJacksCamaro's Avatar
Drives: Camaro LS M6, Fiero, Ford F100
To anyone that has done this mod, does the warning about the automatic headlight control being turned off still pop up on the DIC? I would imagine that if it did, it would come on each time the ignition is turned on.
IamJacksCamaro is offline   Reply With Quote
Old 07-06-2010, 01:42 PM   #7
joblumer
Drives: IOM2SSRS
so how do you remove the switch, is there a diy
joblumer is offline   Reply With Quote
Old 07-06-2010, 01:47 PM   #8
christianmotox
Drives: ( . )( . )
The warring only comes on if you have the car runing and you move the knob to OFF, but if the know is always in the off position, you will not get the warning on the DIC.
Old 07-06-2010, 01:59 PM   #9
christianmotox
Drives: ( . )( . )
Its pretty straight forward, just use a card to pry it open from the knob side, and it will pop out, once its out, just disconnect the plug.
1
2
3
Old 07-07-2010, 12:10 PM   #10
joblumer
Drives: IOM2SSRS
thanks
Old 07-08-2010, 10:15 AM   #11
joblumer
Drives: IOM2SSRS
Ok, got switch out and disconnected, really easy. Tried to take switck apart not so easy. Did not want to break, so how do you take switch apart. thanks
Old 07-08-2010, 01:53 PM   #12
amanc96
amanc96's Avatar
Drives: 2011 SIM 2SS/RS
Use a flat head screw driver and slowly work the back off by prying the tabs back. and don't forget about the two in the middle of the switch.
amanc96 is offline   Reply With Quote
Old 07-08-2010, 02:20 PM   #13
joblumer
Drives: IOM2SSRS
OK, thanks. I tried that last night, guess I was not patient enough. Will spend a little more time on over the weekend. Again thanks for quick reply.
Old 09-29-2010, 09:16 PM   #14
t.c.tam
t.c.tam's Avatar
Drives: 2011 Camaro LS
can anyone confirm that this works please? i imagine if you turn on the car and hold the switch to the left, the auto headlight will still be on because that is the default computer setting.
Ordered 8/7/2010
(1100) Preliminary order accepted 8/16/2010
(2500) Order preferenced 8/18/2010
(3400) Order broadcast 8/25/2010
TPW 8/30/2010
(3800) Order produced 8/31/2010
In-Transit from Osh 9/1/2010
9/15/2010 Delivered!!
t.c.tam is offline   Reply With Quote
Wanted: How To disable auto dim side mirror 2SSRS-CGM Camaro DIY & HOW-TO instructions & discussions 32 04-05-2015 05:22 PM
GM offers sneak peek of Detroit auto show display KILLER74Z28 General Automotive + Other Cars Discussion 7 12-02-2013 06:01 PM
2006 TRAVERSE CITY AUTO CONFERENCE KILLER74Z28 Off-topic Discussions 2 09-18-2010 10:45 AM
Z/28 Auto? I sure hope its an option cuz its quicker in the CTS-V BigDan Camaro ZL1 Forum - ZL1 Specific Topics 110 06-25-2010 01:38 AM
Iacocca rips auto industry, warns: Don't sell Chrysler KILLER74Z28 General Automotive + Other Cars Discussion 6 04-14-2007 12:38 AM
