Old 03-13-2010, 03:48 PM   #1
Don O
Camaro and Vettehead
Don O's Avatar
Drives: 2SS/RS IOM L99 69 427/400 Vette
Quick oil drain plug
Anyone used one of these before? A friend just installed one and it looks pretty convenient. Just attach a hose and drain right into a gallon container.
http://www.quickoildrainvalve.com/
Don O
Nothing sucks more than that moment during an argument when you realize you're wrong.
Don O is offline   Reply With Quote
Old 03-13-2010, 04:16 PM   #2
dirtydogg
Drives: .
only problem i can see if you use the one to attach the hose, how much clearance do you have. on my charger i have a plastic plate that covers the bottom of the motor, so no problems. haven't been under the my maro yet. i have used this item on several other cars and trucks, works great.
dirtydogg is offline   Reply With Quote
Old 03-13-2010, 04:24 PM   #3
Don O
Don O's Avatar
Looks like it would stick out at a right angle to the pan. Thanks for the feedback.
Don O
Old 03-13-2010, 06:19 PM   #4
dirtydogg
Drives: .
thank you for the pic now i know i will buy it for my maro also. really like it on my other vehicles. i wonder if they have one for my goldwing?
Old 03-13-2010, 07:22 PM   #5
ron10
Drives: 2010 2SS IOM L99
if i changed my own oil i would probably get one.
Old 03-13-2010, 08:05 PM   #6
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
Very popular on the big rigs. We see them all the time. They work great and prevent your threads in the pan from getting screwed up from removing the stock plug all the time.
HeavyD is offline   Reply With Quote
Old 04-15-2010, 08:37 PM   #7
daphatgrant
June '10
daphatgrant's Avatar
Drives: '10 2SS/RS RJT
Wow... very cool, now I'm torn between this and the magnetic drain plug .
RJT, 2SS/RS, M6, Black Int, Sunroof.
daphatgrant is offline   Reply With Quote
Old 04-17-2010, 12:22 PM   #8
obe1
obe1's Avatar
Drives: 2010 2SS/RS M6 IOM, 1995 Blown Z28
I've used the Fumoto valve on several cars with good luck. It has a spring loaded tab that rotates 90 degrees to release the oil. I've read some write-ups where people complain that some of the old oil doesn't fully drain out to due the height of the internal threads of the fitting.
2010 2SS RS M6 Inferno Orange Metallic
1995 Z28 - blown, intercooled and nitrous injected
obe1 is offline   Reply With Quote
Old 04-17-2010, 12:40 PM   #9
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
I put a similar drain plug on my wifes car. It was made by Fram. You just had to uncap it and screw on a hose fitting that made the oil flow out. Never had any leaks or problems with it.
Old 04-17-2010, 04:08 PM   #10
silverfox
silverfox's Avatar
Drives: 2010 camaro ss
silverfox is offline   Reply With Quote
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 08:51 AM
GOLD PLUG magnetic oil pan drain plug strobi Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 44 03-29-2012 02:09 PM
We need help with Electronics wiring diagrams 2SSRS@Gen5diy Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 11 12-13-2009 05:58 PM
Help with oil change, please. 5thGenCamaroChick Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 40 10-08-2009 08:22 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
