Old 03-13-2010, 08:38 PM   #1
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
Trim tree thingy
I am getting ready to put sound deadener in my trunk. I have removed all the trim panels. The two side panels have two each of these plastic tree looking things. They are black plastic, pointed and once pushed in are a biotch to pull out so I cut the heads off of them.
I am sure others have run into these. What are they called and where did you go to replace them?
Cheers
K
Moriartii is offline   Reply With Quote
Old 03-13-2010, 08:50 PM   #2
chrisgalles
TEXAS FIGHT!
chrisgalles's Avatar
Drives: Awesome
You can probably get them from gmpartsdirect.com ... I am currently in the process of doing the same thing... I'm just notching all of the sound deadening material I am laying down though.
chrisgalles is offline   Reply With Quote
Old 03-13-2010, 08:55 PM   #3
tjmac49
tjmac49's Avatar
Drives: 2010 Camaro SS/RS, IBM, L99
Moriartii: They are called Trim Retainers. You can get them at websites like The Fastener Warehouse. Here is a link: http://www.thefastenerwarehouse.com/...age/566976.htm . Hope this helps
tjmac49 is offline   Reply With Quote
Old 03-13-2010, 08:58 PM   #4
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
There are all kinds of names for them, basically - panel retainers.
http://www.nextag.com/panel-retainer/search-html
HeavyD is offline   Reply With Quote
Old 03-13-2010, 09:09 PM   #5
Moriartii
Moriartii's Avatar
Suhweet!!!
Thank you all!!!
Cheers
K
Old 03-13-2010, 09:47 PM   #6
multiSS
multiSS's Avatar
Drives: 69 SS396 chevelle 2010 2ssrs camaro
local body shop will have all sorts of them
multiSS is offline   Reply With Quote
Old 03-13-2010, 11:50 PM   #7
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
There's also several different versions available at autozone or pep boys. Maybe something that's easier to remove but still holds well? Who knows, there's a very wide variety of these little things...
Old 03-16-2010, 10:35 AM   #8
Moriartii
Moriartii's Avatar
I ended up getting a package of 15 from advance auto parts, they are the universal ones. Specs are 3/4" head x 3/4" length fitting in a 1/4" hole.
Cheers
K
Old 03-16-2010, 10:41 AM   #9
garcmol
garcmol's Avatar
Lowes has them in the hardware isle. They are in the blue drawers. (so nice that all Lowes stores are pretty much the same)
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! RPI Designs Cosmetics and Lighting Modification Discussions 36 06-25-2017 10:57 AM
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! RPI Designs Exterior Parts & Accessories 30 02-20-2013 04:23 PM
Can someone explain this interior trim kit / ambient lighting ? cbrniner Cosmetics and Lighting Modification Discussions 19 01-30-2010 11:56 AM
