Emblempros
Old 03-14-2010, 01:25 AM   #1
ELDuran
ELDuran's Avatar
Drives: 2010 2LT RS Camaro (Rally Yellow)
Whistling sound??
So I upgraded my audio (will post pictures tomorrow) but the car makes a whistling sound when I accelerate now? How can i get rid of this sound? And why am I getting it? I know it has something to do with my amps.
Back-2-Back Champs L.A. Lakers!
ELDuran is offline   Reply With Quote
Old 03-15-2010, 10:15 AM   #2
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
Try to reindex your windows. I had a slight whistling noise and I had ice built up at one point the prevent the windows from going up 100%.
HeavyD is offline   Reply With Quote
Old 03-15-2010, 11:02 AM   #3
sounds like you have a happy Camaro
Old 03-15-2010, 12:47 PM   #4
Sour DeeZ
Drives: 2011 IOM 2SS RS M6
What settup did you go with? List everything you installed. And did you do it yourself?
Sour DeeZ is offline   Reply With Quote
Old 03-15-2010, 04:32 PM   #5
JKLNHYD
Defending the Nation...
JKLNHYD's Avatar
Drives: '16 Summit White 2SS, A8, Sunroof
The buzzing sound you hear after installing amps is usually because you tied into your power supply for the amp to a power supply that does not come directly form the battery. If it's a hot wire you found elsewhere, that may be your problem. If you connected directly to the battey for your hot, then you may have a bad/almost bad ground. Hope that helps...
'16 2SS, A8, Sunroof, non-NPP
"SURSUM AB ORDINE"
JKLNHYD is offline   Reply With Quote
HOW DOES THE BOSTON ACOUSTICS SOUND SYSTEM SOUND? siliconewolfgang Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 27 09-21-2009 12:52 AM
L99 Corsa Exhaust Sound? VALOR Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 08-09-2009 11:31 PM
Mystery Sound....I need your help ZZcamaro Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 08-09-2009 07:41 PM
whistling sound when reversing francone13 5th Gen Camaro SS LS LT General Discussions 14 07-20-2009 04:04 PM
Muscle car exhaust sound linkwpc 5th Gen Camaro SS LS LT General Discussions 19 12-09-2007 06:50 AM
