| Cosmetics and Lighting Modification Discussions External and Internal cosmetics modifications. |
Thread Tools |
![]() ![]() ![]() Drives: Rally Yellow 2SS/RS,Auto,G/X Join Date: May 2009
Dome Light Fuse
Does anyone out there know where the fuse is for the dome light.Can not get it to light.Think I blew a fuse. Any Help Please, Thankyou
Come on anyone know the magical answer?
![]() ![]() ![]() Drives: 2010 Camaro 1SS Join Date: Aug 2009
Page 5 - 6 of the owners manual:
Dome Lamps The dome lamp buttons are located in the overhead console. To change the settings, press the following: ( (Off): Turns the lamp off, even when a door is open. 1(Door): The lamp comes on automatically when a door is opened. '(On): Turns the dome lamp on. Since there isn't a seperate fuse, make sure you don't have the switch in the off position.
1SS/M6/CGM/Sunroof
#143575 Delivered 9/14/09 |
Haven't serched for it . How did you blow it. Some elect have brakers
and reset when car is turned off |
![]() ![]() ![]() ![]() Drives: 05/07 Chevy's Join Date: Aug 2009
Yea there isn't a fuse for the dome lamps. Its controlled by the BCM, so if it was a fuse problem there would be other things not working also.
#6 |
![]() Drives: 2010 2SS IOM L99 Join Date: Jan 2010
that is true.if it is a fuse issue,there will be other things on that circuit not working.have you checked the bulb?
#7 |
I check the switch,no go.I tap into this wire on the passenger side for the footwell lighting.It did work now it does not. I cant figure it out.What could it be.
#8 |
Pull up center console and tap into power for excesory power out.
Much simpler but the lights will be on when Car is started. |
#9 |
![]() ![]() ![]() ![]() ![]() Drives: 1SSRS RY L99 Join Date: Aug 2009
Something isn't right with your footwell lighting. You might have to disconnect your lighting and see if the BCM resets that circuit. Your lights might be shorted, or drawing too much load.
![]() Roto Fab, JBA Shorties, MBRP Catback, Sequential Taillights, 3rd Brake Pulser, Blue LED interior, Footwell LEDs, BumbleBee Vinyl Graphics, Filter mag, Magnetic plug. Gorilla Guard wheel locks, Husky Liner mats... |
#10 |
Heavyd -that sounds like that could be a great idea
| Thread Tools | |
| AAC red dome light update with pics. | jebckr | Cosmetics and Lighting Modification Discussions | 14 | 01-31-2010 10:02 PM |
| GTS tail light covers--tape behind tail lights visible? | zsuns | Cosmetics and Lighting Modification Discussions | 5 | 01-31-2010 01:55 AM |
| How to find the wire of the third brake light? From SPAIN | pdrulo | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 2 | 11-16-2009 01:44 PM |
| Third brake light | Rob53 | 5th Gen Camaro SS LS LT General Discussions | 23 | 11-11-2009 11:28 PM |
| New 4.5 L Duramax Diesel V8 for light duty pickups | Scotsman | General Automotive + Other Cars Discussion | 8 | 12-01-2008 07:21 PM |
