Hines Performance (HPE)
Camaro V6 LLT Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 03-15-2010, 11:39 AM   #1
Airaid Filters
Airaid Filters's Avatar
Drives: 2010 Camaro
Exclamation AIRAID Dyno Test & Videos For 3.6L Camaro
Gentleman,
At the request of Camaro5 forum and its members, we have re-tested our AIRAID Intake system to address some myths and misconceptions that have been posted about our Intake system.
Myth # 1: The AIRAID Intake system on the 3.6L Camaro “loses” or “Lost 20HP”.
Fact # 1: The AIRAID Intake system does in fact add additional horsepower and Torque and does not “Lose” any power.
Myth # 2: The AIRAID Intake System “Requires A Tune” to see any HP or TQ gains.
Fact # 2: As you can see again with our Testing, the AIRAID does not require any tuning at all to achieve HP & TQ gains.
2010 Camaro 3.6L V6 OEM Intake system, Hood Closed
We ran a baseline test with the OEM Intake system on a stock Camaro with no other modifications. This is documented as Run 1. We saw 269HP & 262 ft-lbs of torque with average AFR of 12.3. As you can see no tricks, gimmicks, or tuning was done to this vehicle.
2010 Camaro 3.6L V6, AIRAID Intake System, Hood Closed
Next we installed our Airaid intake system on the same vehicle with the Hood Closed and no other modifications. Engine temp was brought up to 200degrees exactly the same as run 1. We saw 275HP & 268 ft-lbs of torque with average AFR of 12.7. This is documented as Run 2. Please refer to Myth 1, No loss in power was observed at any part of the RPM Range. No custom tuning was performed to achieve these dyno results. Typically custom tuning is a means to extract additional hp over and above typical gains of a CAI, other modifications or to address unique issues. Issues can be in the form of a unique combination of modifications.
2010 Camaro 3.6L V6, AIRAID Intake System, Hood Open
Finally, to satisfy everybody’s curiosity we ran a duplicate test like run 2, except with the hood open. This is documented as Run 3. We saw 276HP & 266Ft.lbs of torque with average AFR 12.6. As you can see the differences were marginal at best for this 3.6L Camaro. Please keep in mind the Dyno does not duplicate the actual driving environment and comparing the hood open to hood closed does not simulate real world driving conditions. Our Dyno tests and Videos document that the difference we saw between having the hood open to closed showed a 1hp and 2ft-lb of torque difference which is within the accuracy of the Mustang Dyno.
2010 3.6L Camaro Dyno Sheet
As you can see with the Dyno sheet, the AIRAID makes a nice steady gain throughout the RPM band, and you can also see there is no “Loss” in power at all. Please also make a note of how similar the gains are with the hood open and closed.
The AIRAID showed a gain of 6hp & 6ft-lbs of torque with the hood closed, and 7hp & 4ft-lb of torque with the hood open over the OEM intake system on this particular 2010 Camaro 3.6L. You can also see that the AIRAID does not run quite as rich as the OEM intake system, and the AFR averages are right in line.
Please keep in mind 2 things here, 1 is that even though this particular 3.6L Camaro did make less HP & TQ than our original car that we used for development, that is perfectly normal as all vehicles are going to vary. A Dyno is not a number that should be etched in stone, it’s a rough estimate of what one vehicle did on that given day. The 2nd thing here and most important is that the AIRAID did not show a loss of power in any of our tests.
Please also understand that a “Dyno” is not the same as actually driving on the street and it does not represent “Real world conditions”, and even if a given product shows a higher or lower dyno number does not translate into how it will actually perform on the street in a real world environment.
Thanks,
David
AIRAID Filter Company | www.AIRAID.com
airaidinfo@AIRAID.com | Toll Free # 800-498-6951
Find a local or Online AIRAID Dealer : http://www.airaid.com/DealerLocator.aspx
Airaid Filters is offline   Reply With Quote
Old 03-15-2010, 11:40 AM   #2
Rwarchol
Rwarchol's Avatar
Drives: 2010 1LT SIM A6, 2005 GTO TR A4
Rwarchol is offline   Reply With Quote
Old 03-15-2010, 12:00 PM   #3
bmwdon
I refuse to go smurfy
bmwdon's Avatar
Drives: 2009 Challenger SRT8, 2010 Camaro
nice to see #'s finally!!
-Bill...the Camaro was my wifes, now she's got a minivan
Challenger- 2009 Dodge Challenger SRT8 Procharger D1 Supercharger: 10.895 @ 126.720 MPH
bmwdon is offline   Reply With Quote
Old 03-15-2010, 12:20 PM   #4
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
269hp stock? That seems really high. What am I missing here? Regardless, your results do indeed show an increase.
Old 03-15-2010, 12:21 PM   #5
LadyinBlue
LadyinBlue's Avatar
Drives: 260HP/242TQ
Thanks, David! Now that Airaid that's been decorating my dining room since Christmas will be installed :-)
LadyinBlue is offline   Reply With Quote
Old 03-15-2010, 12:23 PM   #6
KMPrenger
KMPrenger's Avatar
Drives: '10 ABM LT/RS, 01 Ford Ranger
Well, as you said...starting HP rating really does not matter. Stock V6 manuals have shown to be in the 260 range, but definitely not the automatics.
But again...no matter.
Shes ALL MINE! - 8/24/2009 2G1FB1EV2A9133373 Custom Magnaflow Exhaust, Vararam intake, MACE Ported Intake Manifold, RX Ported TB, RX "Black Ice" manifold insulator, Trifecta Tune, Mike Norris Catch Can, DRL Harness, Heritage grill, Street Scene lower grill, NLP Spoiler, ZL1 rockers, Switchblade silver interior, Defenderworx sills, and more!
Old 03-15-2010, 12:26 PM   #7
Airaid Filters
Drives: 2010 Camaro
Hello BackinBlackSS/RS,
Well depending on the vehicle and brand of Dyno ie. Mustang or Dyno jet, the Stock numbers are going to vary. The mileage is another factor that comes into play with the stock numbers as well.
Hello LadyinBlue,
Sounds great. I know you will be very pleased with the AIRAID Intake.
Thanks,
David
Old 03-15-2010, 12:27 PM   #8
dagolfguy
dagolfguy's Avatar
Drives: 2010 Camaro 2LT RS
Good for you, David!
I'm happy to see that you've followed through with the testing and the release of the results, and I hope that folks can appreciate the effort involved with that.
For us folks not intimately familiar with the equipment involved, can you please let us know which parameters are monitored on that computer screen in the videos? I can see the numbers clearly, but not the labels.
Again, thank you!
-Dave
dagolfguy is offline   Reply With Quote
Old 03-15-2010, 12:35 PM   #9
chozn4service
Five-O
chozn4service's Avatar
Drives: 2010 RS RJT
I applaud you David and Airaid with posting your results, and after being the subject of some bashing and ridicule, you remained professional throughout!
I'm a firm believer that if you don't stand for something, you'll fall for anything.
I have the Airaid as you very well know and I can tell the difference in performance. Glad to see that your numbers can put to rest some of the BS that was flowing around here. Of course, there are some who will argue with you that the sun doesn't rise in the east and set in the west, and will never be happy or satisfied with results no matter what they may read. You just can't allow yourself to be brought down to that level.
Thanks for the time, effort and results, and not rushing to please naysayers by putting anything out there that could be subjected to scrutiny.
Peace!
chozn4service is offline   Reply With Quote
Old 03-15-2010, 12:35 PM   #10
devildoc
devildoc's Avatar
Drives: '12 Toyota Tacoma Dbl
So this was a stock camaro? Making the most power anyone has seen in a stock car so far. Then by adding an intake making just as much power as Mrrays camaro is making with a tune,LT,and exhaust! Seems a lil to far fetched....
STANDING 1/4MI: 13.948@99.87
6600RPM HP/TQ Gains - 30.54HP/24.3TQ (NOT PEAK)
devildoc is offline   Reply With Quote
Old 03-15-2010, 12:42 PM   #11
esperman
You Can Call Me Jay
esperman's Avatar
Drives: 2010 1LT RJT Manual w/CAI & Solo
David,
was this particular V6 car a manual?
This is all very intersting. I'm alittle confused on the torque numbers. The engine is SAE certified 273 lb ft at the crank. Seeing 262 lb ft stock at the wheels doesn't feel right.
I am glad the AFR seems pretty good!
esperman is offline   Reply With Quote
Old 03-15-2010, 12:43 PM   #12
marley.
OCD
marley.'s Avatar
Drives: 2010 Camaro and 1999 Camaro
Great post David. Thanks for the info.
2010 Camaro5 Fest Top Street Modified Camaro
marley. is offline   Reply With Quote
Old 03-15-2010, 12:47 PM   #13
Airaid Filters
Drives: 2010 Camaro
Again, thank you!
-Dave
Hello dagolfguy,
The main parameters the screen shows are Horsepower, Torque, Engine Temp, and AFR
Peace!
Hello chozn4service,
Thank you very much, I appreciate your honest feedback!
Hello devildoc,
Yes, as I stated in the above post the Camaro was 100% STOCK.
We never test vehicle with other modifications done to them. Not sure how else I can say this.
AGAIN, Not all Dyno’s are going to show the same RWHP Numbers. There is something called different brands of Chassis Dyno’s and they all show different numbers. Run your car on a Mustang and Dyno Jet and you will see different numbers.
Thanks,
David
Old 03-15-2010, 12:51 PM   #14
Airaid Filters
Drives: 2010 Camaro
Originally Posted by esperman View Post
David,
Hello esperman,
The Camaro we used for this test was a Manual.
The numbers that you see reported are from all over the country and on different types of chassis dyno's. The numbers are going to vary some.
Hello marley,
Thank you for the positive feedback.
Thanks,
David
Old 03-15-2010, 12:52 PM   #15
devildoc
devildoc's Avatar
What BS you talking about there Chozn? Glad you can tell that your performance has increased without a dyno.
MRRAY - congrats you paid thousands of $ for the same hp/tq that Airaid can get out of a stock car with just an intake.
Old 03-15-2010, 12:55 PM   #16
esperman
You Can Call Me Jay
esperman's Avatar
So far so good. Can't wait to see JP, Nates & Scrming's dyno runs. Then I think we'll have a definitive picture.
Old 03-15-2010, 12:56 PM   #17
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 JDP Track Spec Camaro
David,
Thank you for doing this test and documenting it so well! I know you and everyone at Airaid takes claims like this very seriously, Airaid stands behind their products 100% which is why we offer and use Airaid products! We will also do a test on a local C5 members LLT to confirm there is in fact a gain and everything is working as it should which I'm confident we'll find to be the case. We appreciate your support and have a good one!
Kind regards,
AEM | Airaid | Anvil | ARH | BBK | BMR | Brembo | CAI | CSF | COMP Cams | DBA | DSS | ECS | FAST | Forgeline | Gforce | Hawk | Hurst | Hotchkis | Injen | MagnaCharger | Magnaflow | KOOKS | Oracle | Pedders | Pfadt Racing | ProCharger | Roto-Fab | RX | Seibon | SLP | Spohn | Stainless Works | Street Scene | Turn One | Vararam | VMAX | Whipple | + MORE!
JDP Motorsports is offline   Reply With Quote
Old 03-15-2010, 12:56 PM   #18
Airaid Filters
Drives: 2010 Camaro
You may want to go to the top of this thread, it has a Dyno sheet and video’s to document the gains.
AGAIN, it’s actually understanding how a Dyno works and all the variables involved with them.
Old 03-15-2010, 12:59 PM   #19
Mikk2K
Mikk2K's Avatar
Drives: '10 Camaro LTRS, '12 Pro4x Frontier
Great post David. I really appreciate all the hard work that you and good folks at Airaid put in. Your facility looks fantastic by the way
Mikk2K is offline   Reply With Quote
Old 03-15-2010, 12:59 PM   #20
esperman
You Can Call Me Jay
esperman's Avatar
actually he didn't pay for it...thats what so great on being a beta tester! LOL.
I can assure you his car is putting more power down that just an intake MOD (just in case people don't catch your sarcasm)
Old 03-15-2010, 01:00 PM   #21
bmwdon
bmwdon's Avatar
did mrray13 do his dyno run on a mustang or dynojet?
Old 03-15-2010, 01:03 PM   #22
BaylorCamaro
AutoX is for fast DRIVERS
BaylorCamaro's Avatar
Drives: 2010 2LT/RS Supercharged
Well this is good news! Thanks David for the testing! Yeah these numbers seem a little high but what is important is they seem static and it shows the CAI adding a little hp/tq.
Awesome!
Automotive youtube channel. / My First Autocross / My automotive blog / Build Thread
RX Super Charged / MRT V1 / ARH LT Headers and Cats / 2.5" Entire System / Ported & Polished IM / IM Spacer / RX Ported TB / Trifecta Tune / Brembo Brakes / Pfadt Sways, End Links, Rear Trailing Arms & Springs / SS Rear Diff.
Check out video's of my current set up! ==> RX Super Charged
BaylorCamaro is online now   Reply With Quote
Old 03-15-2010, 01:05 PM   #23
Airaid Filters
Drives: 2010 Camaro
David,
Kind regards,
Hello JDP Motorsports,
Thank you for the positive feedback and we appreciate your support.
Hello Mikk2K,
It’s no problem at all. We just want you to be a happy customer.
Thank you as well for the compliment on the building.
Thanks,
David
Old 03-15-2010, 01:13 PM   #24
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Couple of things....
What kind of fuel did the test car have in it?
Also I put the Airaid in my car this afternoon (Thanks, David!) and I have some initial data...
Ok... The test car went from 12.4 to 12.7 A/F... so the test car in fact got a bit leaner.. we've seen other cars get a bit more lean... I did notice from my logs that my car is in fact running leaner. With the stock intake my fuel trims went from running in the -0.8% to -1.6% and the occasional -2.3%... With the Airaid my fuel trims went to +1.6% to +3.1%. This would support that the car is running a bit leaner with the computer having to add fuel to correct...
On my WOT run my O2 output was a bit off also. Stock I was in the 900 to 905 mvolt range... With the Airaid the O2s were in the 875 to 885 range.. so again a bit leaner than stock... which agrees with Airaid's finding (car going from 12.3 to 12.7).
Other interesting thing is looking at the MAF frequency there are sections in the log where the MAF frequency is less than stock... that means the MAF is reporting that there is less air going in than stock... which of course doesn't make sense... so there is more air going in than stock but the MAF is reporting LESS air... and that would explain why things are running a bit lean.
This is what I know so far...
scrming is offline   Reply With Quote
Old 03-15-2010, 01:15 PM   #25
devildoc
devildoc's Avatar
Well obiviously not....correct me if I'm wrong but he was at 276hp last with all the mods done correct? I guess we need to have mrray go to the same dyno that Airaid used then. Sorry for the sarcasam Esperman, just doesn't make sense!
Camaro Product Manager - interview Moose 5th Gen Camaro SS LS LT General Discussions 11 04-04-2012 06:10 PM
Gran Turismo 5... No Camaro? 5thGenOwner 5th Gen Camaro SS LS LT General Discussions 111 12-06-2011 10:06 AM
Im sure this has been asked before.. But forgive my innocence :) gmag21 Suspension / Brakes / Chassis 23 02-21-2010 10:29 PM
Comparison Test, by Proxy: 2010 Chevrolet Camaro vs. 2009 Dodge Challenger SRT8 AirGoya Chevy Camaro vs... 86 07-24-2008 11:20 AM
