| Camaro V6 LLT Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
#126 | |
One Lucky Guy.
Drives: #22 Tom Henry Racing 2010 2SS/RS Join Date: Dec 2007
Sounds to me like you are making an accusation... If you can't prove that then leave that speculation out of this thread. We don't have paying sponsors so our members can have uncensored dialog with vendors. But accusations that are unfounded are not allowed. Either you agree or disagree with the findings. If you can't counter with your own personal experience then leave it be. You've made your point. Take it to PM's moving forward.
Click image to see build thread. PQ - "the love of cars. It's a boys first step toward manhood and a mans last hold on boyhood." Fbodfather - "We do not want to use the Z28 moniker on a car that does not deserve this hallowed name." The_Blur - "Let's not confuse competitors with equals." |
#127 | |
One Lucky Guy.
#128 |
![]() ![]() ![]() ![]() Drives: '12 Toyota Tacoma Dbl Join Date: Sep 2009
GTAHVIT - so does that count towards me since I have my own experience and dyno proof? I believe the accusations are true on some basis. Tell me how there is only a 4% drivetrain loss for tq? Doesn't seem odd to you? I mean come on you have me, the guy that supposedly started all of this, putting all of his intergrity on the line and allowing people to call me a bitch yet we have knowledgable people on here trying to prove points. I think mrray's points are valid enough. You can move this I guess to the vendor area, but by being in the V6 area I would hope that it is open to all comments! I know your a Mod so I respect any decision you make but they also have you as a mod because you are fair.
STANDING 1/4MI: 13.948@99.87 6600RPM HP/TQ Gains - 30.54HP/24.3TQ (NOT PEAK) |
#129 | |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
Historically, yes, you leaned out a motor a bit to get more power... But what we are finding is that this motor while appearing to run overly rich, apparently likes it this way. Again... I purposely have avoided performance comments but I can see at WOT I was pulling timing... I've scheduled some dyno time for Saturday... |
#130 | |
I refuse to go smurfy
Drives: 2009 Challenger SRT8, 2010 Camaro Join Date: Nov 2009
I thought this motor was tuned on the lean side from the factory?
![]() -Bill...the Camaro was my wifes, now she's got a minivan Challenger- 2009 Dodge Challenger SRT8 Procharger D1 Supercharger: 10.895 @ 126.720 MPH |
#131 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 1LT RS Rally Yellow Join Date: Oct 2009
Nope, IIRC, the commanded AFR is like 11.7. Without CAI, and with tune, my biggest hp numbers happen at ~11.97, while biggest torque numbers are ~12.86, according to the DynoJet. I'm unsure of what Vince's data logs show for that. The motor like the richer side of things, lol.
#132 |
![]() Drives: 2010 Camaro LS 2009 Challenger SE Join Date: Jun 2009
THAT'S MY LS
The car in the video is mine. Completly stock except for the Airaid. 87 octane.
#133 |
![]() ![]() ![]() ![]() ![]() Drives: '10 LT RS A6 & '04 Acura RSX Type S Join Date: Oct 2009
OK, being one of the original Trifecta tune testers, I may be able to shed some light here.
I have the Airaid CAI on my car. I ran a dyno test before the tune was installed and got a 4-5 HP gain with the Airaid (hood closed). I ran the next run with the hood open and, without cooling the car down, gained 9 HP. The conditions (raining cats and dogs) and operator were in question so I made no comment on that aspect of the test and waited confirmation of the result. Also, the dyno I was on is an "eddy current" type and, typically, reads 30 HP less than a Mustang dyno... 40 less than a dynojet (this is a known difference throughout the automotive industry and the topic of many heated debates!) so my numbers are lower in total but still showed the increase. Bottom line, different dynos read different total numbers! A dyno is a tool for DIRECT comparison only! You just can't get the same numbers from one to another! OK... when Vince reviewed the first log files on mine after the tune, he found a problem with the power enrichment calibration. Sometimes it was working and sometimes not. Vince said at it's worst, my AFR was up to 14.7/1...! This could be the issue with DDoc's pulls. Combine that with the differences both Scrming and I have seen in performance based on IAT reported temps and you can get a variable that exceeds the gains seen from the Airaid and could explain DDoc's lower numbers... hell, it could just be that the operator didn't have the peddle all the way to the floor... you just can't be sure from one set of runs. Yes, you should look into it further but, I truely don't believe it's all the fault of the Airaid. When I installed the Airaid, before the tune was done, I did find the throttle response to be marginally better (primarily on a hard launch). The only real issue I noted, other than the inconsistent runs caused by the enrichment calibration problem, was a slight lean surge at idle in traffic. Given the slight lean condition from the intake and south Florida heat and traffic, that's a minor issue. No more surging after the tune... but, it's winter here so.... that remains to be seen if it's all cured. My only real critique of the Airaid is in the way it transitions from the filter housing to the tube. There is a hell of a ledge there that has got to upset the flow somewhere in the rev range. That is another potential issue for performance if the tube is grossly misaligned. After looking at some of the "fast prototype" inserts Airaid used to "tune" this intake, I could see where a mialignment could cause a substantial difference in the effectiveness of the intake. I understand the need for the accordion section due to the (excessive) engine movement but, that is just not right! I am working on a cure for that..... My feeling is that, although the stated gains where not realized on the second test car, they are within the range of error of the whole dyno process. The difference between fuel trims (basic condition of the car...) on the different cars used could attribute to the lower number on the second car... let alone all the other variables involved in dyno testing. And, one last thing, I've seen up to 5 HP difference on my race bikes just from the amount of filter oil that was applied... food for thought.... On a side note... a manual tranny will "soak up" about 12-15% of the HP while an auto eats 17-20%. The reason a good auto can run with a standard is in the application of the available torque. Just look at the stock times of the L99 Vs the LS3. The auto has 26 fewer HP and still puts down very similar times in the 1/4. The MPH is usually a bit higher on the standard but, the ET is very close.
#134 |
Whats a Millwright?
Drives: 2LT/RS SIM, 05 Wht Denali Join Date: Feb 2010
I think this will be my last time looking at this thread. I don't see how the original base line numbers on torque can be so high. If they are then the owner has possibly the most powerful stock LLT GM dropped in the camaros so far. Lucky him/her. On several occassions i noticed answering a cpl questions were sort of avoided and this has made my mind up to go with a different CAI. Thx again for doing the tests and posting the vids.
#135 | |
It is a well known issue and has been debated "ad nosium" over the years... LOL! Basically, it doesn't matter as it's the differences on the same dyno that are important! You guys know me... if it was BS, I would call it M8!
#136 | |
#137 | ||
![]() ![]() Drives: 2010 Camaro Join Date: Jun 2009
Both are excellent posts. Thank you David
AIRAID Filter Company | www.AIRAID.com
airaidinfo@AIRAID.com | Toll Free # 800-498-6951 Find a local or Online AIRAID Dealer : http://www.airaid.com/DealerLocator.aspx |
#138 |
Even if i made only 1 more hp, it still looks sweet under the hood. Friend at work has airaid on her challenger r/t.
#139 |
SCRMING-
If you are seeing the AIRAID pulling timing pretty good, does that mean it would be hard to net HP gains using it? Just plain confused? |
#140 |
I think I'm going to refrain from making any statements regarding HP or performance... I am simply going to post data and let every one draw their own conclusions..
#141 |
SCRMING- My question does not have to be about Airaid or any other CAI...
Just looking for an understanding- if a car is pulling timing is it also possible to show gains in HP, given that situation? |
#142 |
I've got a manual w/airaid. It rocks! (I am still worried about the autos in the 1/4)
Airaid CAI (V2 Tube)/ Flowmaster American Thunder/ Barton Shifter Kit/ Hotchkis Sport Sway Bars/ Hotchkis Sport Springs/ AAC Lights/ GM Trim Kit/ Tint/ Pioneer Premier Champion Series Sub/ Pioneer 1500 Watt Amp |
#143 | |
Yep, we know that. That's not the arguement. As it is, and in no small part due to a pm, I'll officially refrain from anymore posting in this thread. I'll wait scrming's results and go from there. I can't wait for Saturday.
#144 | |
![]() Drives: 2010 Cyber Grey Join Date: Feb 2010
I dont take sides here but I have to say david did what we all asked and I am happy with what I saw. Enough said lets close the topic here. No need to work everyone up and bash a product that has proven it self Thanks AirRaid. Wizzer |
#145 | |
You Can Call Me Jay
Drives: 2010 1LT RJT Manual w/CAI & Solo Join Date: Sep 2009
Also, please be advised all the cool guys here now have Star Trek Avatars.... |
#146 | |
#147 |
You Can Call Me Jay
#148 |
I am going to sign off from this topic- I want to thank all of you for the education I received! Here is my take away from ALL this...
GM is now producing engines that are not leaving much on the table anymore...I saw that in my 07 Vette and now with this LLT V6. Diablo has confirmed that they could not find any real improvements in testing for this engine and the CAI's seem to have varying results...+ or - 5 HP, is within Dyno variance. Congrats GM! Good luck all, see ya on other topics. Time to start driving my car again...staying Airaid and Ls3 mufflers. May throw some 93 octane for kicks...LOL |
#149 |
Beauwulf......thanks for the write up and insight! Seems we both had the same problem.
#150 | |
![]() ![]() Drives: 1LT RS w/polished 19"rims Join Date: Jul 2009
WOW after reading 120 posts it's nice to see track time mentioned... I would love to see some time slips with & without the Airaid on the same day with the same DA. I don't know if Scrming is going to do any track tests?
| Thread Tools | |
| Camaro Product Manager - interview | Moose | 5th Gen Camaro SS LS LT General Discussions | 11 | 04-04-2012 06:10 PM |
| Gran Turismo 5... No Camaro? | 5thGenOwner | 5th Gen Camaro SS LS LT General Discussions | 111 | 12-06-2011 10:06 AM |
| Im sure this has been asked before.. But forgive my innocence :) | gmag21 | Suspension / Brakes / Chassis | 23 | 02-21-2010 10:29 PM |
| Comparison Test, by Proxy: 2010 Chevrolet Camaro vs. 2009 Dodge Challenger SRT8 | AirGoya | Chevy Camaro vs... | 86 | 07-24-2008 11:20 AM |
