| Camaro V6 LLT Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
#151 |
Go Blue!!!!!
Drives: 2012 Cruze LT Join Date: Mar 2009
#152 |
My wife has not seen me for weeks. I have been reading Airaid threads. If this is it, what am I gonna do with all my spare time?
Airaid CAI (V2 Tube)/ Flowmaster American Thunder/ Barton Shifter Kit/ Hotchkis Sport Sway Bars/ Hotchkis Sport Springs/ AAC Lights/ GM Trim Kit/ Tint/ Pioneer Premier Champion Series Sub/ Pioneer 1500 Watt Amp |
#153 | |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
![]() IIRC the purpose of the wedge was to tune the intake tube so that the MAF would correctly sample the amount of air passing through the tube. In fact David posted : "An intake system that is properly designed to provide less restriction (more air flow) while allowing the mass air sensor to sample the incoming air flow accurately (as it did in the original intake) should not result in the PCM re-learning or compensating. The additional air flow resulting from less restriction should be measured from the mass air sensor accurately as the correct frequency reading per volume of air. Additional air flow should continue to be sampled accurately from the mass air sensor until the additional amount of air flow exceeds the functional limits of the mass air sensor or the allowable parameters of the PCM." from here: http://www.camaro5.com/forums/showth...91#post1070991 The way I read that is a properly designed intake system should retain the stock A/F. Airaid's own testing showed this is not the case. The Airaid intake is in fact shifting the A/F. This seems to be contrary to Airaid's own design principals. I've mentioned that I also seen a shift in the A/F in my data. While I don't have a way to measure A/F directly, we can look at the O2 data, since our cars actually use wideband O2 sensors, just like an A/F gauge! Here is some of the data I've collected... I'm only going to show a small section of the data, mainly a point at 6000 RPM... yes, only one point but the rest of the RPM range pretty much shows the same thing.. Here is some data from my stock intake: ![]() And the Airaid: ![]() Here is what the data is telling me.. everyone is free to draw their own conclusion... MAF Frequency - Notice the stock intake number is higher than the Airaid. That would mean the stock intake is flowing more air than the Airaid, which obviously isn't true. O2 - The O2 number is the mvolt output from the sensors. The higher the number the richer the mixture. Unfortunately their is no easy way to translate the number to an A/F... but the key is higher is richer... So the stock intake has the O2 output at 905 & 900. The Airaid intake has the O2 output at 885 and 885. So in this case the Airaid is in fact running leaner than the stock intake. Again this supported by Airaid's findings on their dyno. What does this mean... My interpretation of this data is that the "wedge" does not appear to be working as designed. It appears that the MAF sensor when in the Airaid intake tube is "under-reporting" the amount of air that is actually flowing through the tube. That would explain why my fuel trims went from -1.6% to +2.3% (even +3.1%). Yes, I did reset my fuel trims and drove around for 30 minutes in a wide variety of conditions, stop-n-go, hard accell, cruising... And it would explain the shift in the A/F from 900/905 down to 885, indicating the car is running leaner... Again this is how I interpret this data. This is not a comment on actual performance... To me this is just supporting data for the A/F shift.
#154 |
Well, i have the swap time down to about 20 mintues... LOL! No track for a few more weeks though... LOL
#155 |
Did I miss the memo, what's up with all the Star Trek avatars and references?
#156 |
![]() ![]() Drives: 1LT RS w/polished 19"rims Join Date: Jul 2009
#157 |
![]() ![]() ![]() ![]() Drives: '12 Toyota Tacoma Dbl Join Date: Sep 2009
Yeah you missed it Chad lol
STANDING 1/4MI: 13.948@99.87 6600RPM HP/TQ Gains - 30.54HP/24.3TQ (NOT PEAK) |
#158 |
![]() ![]() ![]() ![]() ![]() Drives: '10 LT RS A6 & '04 Acura RSX Type S Join Date: Oct 2009
Hey John... lemme ask you a couple of questions. I assume you removed the tune for these runs? Also, how much timing was being pulled with just your headers... without the tune?
#159 | |
When I run 93 I really don't seen any knock retard... except when I slap the throttle,which according to Vince is most likely "burst" knock retard.. So I'll see a few degrees getting pulled but only for a short time... |
#160 |
Interesting.... I wonder if the cam phase follows timing...
#161 |
You Can Call Me Jay
Drives: 2010 1LT RJT Manual w/CAI & Solo Join Date: Sep 2009
#162 | |
You Can Call Me Jay
scrming, your still burning 93 right? |
#163 | |
One Lucky Guy.
Drives: #22 Tom Henry Racing 2010 2SS/RS Join Date: Dec 2007
That's all I'm saying. if you don't know for sure that someone is doing something unethical then don't make the accusation. But we all know that dyno numbers are arguable at best for many of the reasons already stated.
Click image to see build thread. PQ - "the love of cars. It's a boys first step toward manhood and a mans last hold on boyhood." Fbodfather - "We do not want to use the Z28 moniker on a car that does not deserve this hallowed name." The_Blur - "Let's not confuse competitors with equals." |
#164 |
Next is SS camaro.....
Drives: 2010 Camaro LS, Rally yellow Join Date: Feb 2010
What is Knock retard and pinging? so running 93 would get rid of it even tho the car is not tune?
#165 |
I think from earlier reports it seems our engine loves the 93 more than the 87. Though I just put 89 in it and can actually tell that it runs smoother by monitoring the rpm band with the dashhawk, though this may be due to the new spark plugs I just put in. The oem ones were literally black around the base of the plugs.
#166 |
I refuse to go smurfy
Drives: 2009 Challenger SRT8, 2010 Camaro Join Date: Nov 2009
got my denso plugs too....parts are starting to show up, tools are here, just a couple more components and I'll have to schedule the trigger pull
thinking I need a dashhawk too
![]() -Bill...the Camaro was my wifes, now she's got a minivan Challenger- 2009 Dodge Challenger SRT8 Procharger D1 Supercharger: 10.895 @ 126.720 MPH |
#167 |
Im assuming that the black around the plugs was caused by carbon?
#168 |
![]() Drives: 2010 Camaro 2LT RS Join Date: Nov 2008
scrm,
Did those two data logs occur on the same day? I'm asking because I think the MAF is measuring mass, so the total air density would play a factor. Differences in temp and humidity would account for a diff in the MAF reading at the same RPM. Same flow rate, different density. Bigger question: Does anyone know how Airaid measured the a/f ratio? Like; did they stick a sensor in front of the cat where the O2 bank-1 sensor is? If they did it without a probe of some kind, I'm really like to know how (so that I can use the supplied signals to do the same thing)! |
#169 |
#170 |
65 and still a Camaro nut
Drives: 2010 IOM 2LT 6M Airaid/Corsa Join Date: Apr 2009
David, I installed my Airaid yesterday and so far it's great! As one of the other fellas said, my "butt dyno" loved it! I'm a bit confused by all the bickering and arguing going on in this thread. You talk about differences in dynos and other factors, but what I think a lot of you fail to realize is how much the weather plays a role in these tests. How much horsepower your engine produces is directly related to temperature, altitude, and humidity. If it's hot and muggy outside, your car will not perform as well as it would in cool and dry conditions.
#171 | |
AutoX is for fast DRIVERS
Drives: 2010 2LT/RS Supercharged Join Date: Sep 2009
![]() I agree with this, others have said in this thread that they realize these things and are a cause of hp/tq fluctuation, which makes sense to me. The important thing here is if you're seeing increases across the bored, whether it is 3hp or 10hp, the unit is giving you gains. Where the problem lies, is devildoc's test that shows a loss. To me its not so much the numbers (although it is still important) but it's a static loss/gain.
Automotive youtube channel. / My First Autocross / My automotive blog / Build Thread
Custom Super Charger / MRT V1 / ARH LT Headers and Cats / 2.5" Entire System / Ported & Polished IM / IM Spacer / Ported TB / Trifecta Tune / Brembo Brakes / Pfadt Sways, End Links, Rear Trailing Arms & Springs / SS Rear Diff. Check out video's of my current set up! ==> RX Super Charged ![]() |
#172 |
![]() Drives: Black 2LT RS 5th gen Join Date: Dec 2008
off topic question - looking for topic in forums
To begin, I dont believe I am as informed or as knowledgable as most of you here in this thread, but this comment must refer to the "unable to skip gears" on manuals topic i read about around the time I got my V6 manual.
If my assumption is correct, then I havent really understood this. But I have noticed that when I ride hard, I have a little issue slipping the gear into 2nd from 1st. Its the only shift that gives me a little trouble. Im wondering if its due to a lack of skill on my part, or am I missing something else? N yeah, I'd love a nice explanation of what forum members meant by "unable to skip gears on a manual transmission" any ideas or redirects? thanks in advance. ![]() Also, I was considering adding an AI to the car for HP and MPG performance increases. This thread was helpful in some ways so thx to all of you. |
#173 | |||
If you compare my original dyno with the airaid intake/exhaust it was 241hp then the test that put everyone on the "war path" was that same test/same day provided 253hp stock box to 242hp airaid. All with alittle bit worse atmospherics.Quote:
#174 | |
#175 |
Don't Feed the Troll
Drives: 2010 Camaro 2LT/RS & 1999 Corvette Join Date: Jun 2009
When Airaid first came out, wasn't it explained that the "wedge" was designed to make the airflow go up and toward the MAF so it could get a correct reading? It's been so long ago, but I think that was the idea behind the "wedge". It also seems to me, the intake is kind of like the exhaust, If it gets choked down to a smaller diameter pipe along the way, this pretty much disrupts the flow and make the rest of the larger pipe redundant?
I'm interested in seeing your dyno results scrming. I put mine back on this past Saturday, and I can tell a slight difference in bottom end torque.
| Thread Tools | |
| Camaro Product Manager - interview | Moose | 5th Gen Camaro SS LS LT General Discussions | 11 | 04-04-2012 06:10 PM |
| Gran Turismo 5... No Camaro? | 5thGenOwner | 5th Gen Camaro SS LS LT General Discussions | 111 | 12-06-2011 10:06 AM |
| Im sure this has been asked before.. But forgive my innocence :) | gmag21 | Suspension / Brakes / Chassis | 23 | 02-21-2010 10:29 PM |
| Comparison Test, by Proxy: 2010 Chevrolet Camaro vs. 2009 Dodge Challenger SRT8 | AirGoya | Chevy Camaro vs... | 86 | 07-24-2008 11:20 AM |
