| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
#76 | |
MOD SQUAD
Who cares about the Blue Oval crowd and their little Ponys? We're getting our Camaro back-and it'll be Supercharged!-MDAII Team LS3 |
#77 |
![]() Drives: 2010 Camaro SS/RS IOM Join Date: Feb 2010
Can the mufflers clear the ground effects??
#78 |
MOD SQUAD
The tips are 4 inch OD. I'm not sure how big the opening is for the GM GFX.
Nick or Anthony from ARH might be able to answer your question.
#79 |
sounds great
T-BONES BLACK 2SSRS TEAM L99
CAI w/ADM scoop,Magnacharged 3.8 pulley,L92 ported heads,ss valves,patriot springs,yella terra rockers,Comp cam,L99 to LS3 conv.ATI super damper,Taylor plug wires,NGK plugs,ARH 1 7/8 lt headers w/Borla stingers,Elite oil catch can,trans cooler,Jannetty built Richmond 4.11 rear end,Spohn trailing arms,front Racing Brake rotors,Hawk hps pads,BMR end links,AACstyle lighting. Thanks to Shane & crew for engine work at Thunder Racing & tuner Jeoff at EPS. 501rwhp-463rwtq ++ |
#80 |
R6P Marketing Lab Rat
Drives: 2010 2SSRS for weekends mostly Join Date: Feb 2009
same boat
X 2
Ask for the tips to be separate so that they can be welded as part of the install. There are clearance problems caused by the large round tips inside the GFX exhaust outlet. Yes this is a PIA but the GFX option is not seen as mainstream market and as a result takes a back seat and sometimes forgotten or b/c one was not available to fit for production design modeling. I am not sure what the current status is on tips for the GFX. |
#81 |
MOD SQUAD
400 plus miles and still no codes...
![]() Oh, and it was warm enough yesterday to turn the TC off............ Note to self, I'm going to need wider tires!
#82 | |
One Lucky Guy.
Drives: #22 Tom Henry Racing 2010 2SS/RS Join Date: Dec 2007
![]() Yeah me too. ![]() Oh and I am a huge fan of ARH. I couldn't be happier with my exhaust. LT's, CATs and X pipe FTW!
Click image to see build thread. PQ - "the love of cars. It's a boys first step toward manhood and a mans last hold on boyhood." Fbodfather - "We do not want to use the Z28 moniker on a car that does not deserve this hallowed name." The_Blur - "Let's not confuse competitors with equals." |
#83 |
MOD SQUAD
You're going to have to spot me a couple of lengths...
#84 |
![]() Drives: 2010 Camaro 2SS/RS ABM Join Date: Jun 2009
sounds great man, and you swear no done???
2SS/RS/M6 | ABM | White Stripes | Black Int
Mods: American Racing Headers & Exhaust, Airaid Intake, Pfadt Front/Rear Sway Bars, Stealth Bulbs, AAC LED bowtie, AAC Concept LED Side-markers ABM/Tinted, 20% Tints, Chuck COW Tune, MGW shifter (blue with white racing stripes). Coming Soon: 4:10 Gears? |
#85 |
One Lucky Guy.
LOL
Not if I don't figure out how to get her to hook.... ![]() ![]()
#86 |
MOD SQUAD
There is a small amount of drone around 1300 RPM's in 6th gear but it only occurs when you put a load on the engine. As soon as the drone starts if you back off the throttle a little bit the drone goes away. Dynamat is now making Superlite Dynamat (see here Dynamat). I'm going to try this in the trunk to see if helps out with both the small amount of drone and wheel/road noise. The trunk has basically no insulation at all other than the trunk mat so I'm thinking the Dynamat will quiet all nose down better than stock.
The ARH is by far the best sounding exhaust I have ever heard on an LS engine and I drink Flowmaster Kool Aid. I'm never taking mine off. IMVHO the drone is very minor and I can live with it... Same here, I can not believe how much performance a full exhaust system gives my Camaro... Hell, even the TC is having a hard time keeping up! ![]() Oh, and for those keeping track, My check engine light finally came on... Looks like I got the codes for the cats not heating up fast enough. No biggie, If I was worried about it I would have never put the full system on.
#87 |
12.23s@113mph
Drives: 2SS/RS, A6, just a few bolt ons Join Date: Jul 2009
what does the inside of the mufflers look like?
is it perforated pipe wrapped in filling like steel wool, is it straight through like corsa's RST technology, or does it have baffles and such like flowmaster?
RIP Cammie 7/15/2009 - 4/1/2011 |
#88 |
MOD SQUAD
Perforated pipe and is a straight through design.
#89 |
![]() Drives: 2010 2SS/RS M6 Black on Black Join Date: Jan 2010
The problem with the GFX is not so much the diameter of the opening, but the placement of the tips front-to-rear. A 4" tip should fit within the dished portion of the GFX fitting, but the tip has to be placed more forward (more inset in the housing) to match with the dished portion. You may need to cut some length from the exhaust pipe as well as from the tip's pipe to get it to fit within the GFX housing.
I tried to install the GMPP axle back with 4" tips (they're bigger than 4" BTW) and they wouldn't fit without major mods. I ended up getting the quieter version without tips, and had custom tips added later. They had to cut the pipe almost all the way back to the hanger rods. Cutting off the tips from the original GMPP setup was too much work for my dealer so I went the other route.
Mods: Pedders Xa's, bushings, braided brake lines, Solution B sway bars, Hawk ceramic pads, Spohn trailing arms, Kooks 1 7/8 LT's, HF cats, Magnaflow 3" cat-back, MBRP rec tips, Cold Air Inductions black CAI, MGW short-throw shifter w/retro shift ball, Showstopper Engine Bling, Forgeline MD3P's 9.5 & 11", Conti DWS 275's & 315's. AAC plasma DRL's.
Proud previous owner of: 1968 327 Camaro, 1972 Camaro SS 350, 1978 Z28, 1979 Z28. 2010 SS is My 5th Camaro |
#90 |
![]() ![]() ![]() ![]() Drives: Black & Blue 1SS Join Date: Apr 2010
Hey guys I just installed 1 7/8 headers and a three inch all the way back to the stock mufflers. Is it normal for me to have a lot of drone with stock mufflers. Its almost unbearable. I'm not going to lie I love the sound of the exhaust from the outside but not from the inside. It hits a tiny bit at idles I did use the washers on the cross bar.
Any ideas? |
#91 |
Annyone? :-)
#92 |
12.23s@113mph
do you have an automatic with AFM enabled? that could be your problem.
#93 |
No :( a M6
#94 |
One Lucky Guy.
Hmmm... Everyone else I know has an aftermarket axle back...
I could shoot a vid of the exaust sound from the inside of my car.... but it will be hard to tell... If you'd like I will take a quick vid and post it tomorrow... My ARH setup does drone a bit but mostly when cruising ant real low RPM... say around 1500... it actually gets a little quieter with more rpms...
#95 | |
#96 |
Hawaii 5-O
Did your Check Engine Light come on after installing the ARH exhaust system. I purchased the entire system also, had a local shop install for me and now the Check Engine Light has came on. Suggestions?
#97 |
Ya mine came on I was expecting to though . Since there are not cats or anything
#98 | ||
MOD SQUAD
#99 |
![]() Drives: 2ss Join Date: Jul 2011
awesome set up
Did it make a huge difference?
#100 |
MOD SQUAD
| Thread Tools | |
| V8 Camaro Performance Upgrades List | Milk 1027 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 79 | 03-04-2013 09:25 AM |
| LMPerformance Inc., Flowmaster 2010 Camaro American Thunder Exhaust System 3.6L V6. | LMPerformance | V6 Bolt-Ons & Tunes | 5 | 07-05-2010 02:32 PM |
| GM Reveals 2011 Chevrolet Silverado HD | FenwickHockey65 | General Automotive + Other Cars Discussion | 55 | 03-04-2010 01:56 PM |
| 2010 Camaro American Racing Headers FREE Shipping | MoranoRacing | V8 Bolt-Ons & Tunes | 2 | 02-10-2010 08:45 PM |
| NEED TO KNOW AMERICAN RACING HEADERS QUESTION!!! PLEASE HELP ME OUT!! | 1sickss | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 20 | 11-12-2009 11:21 AM |
