Solo Performance
Old 03-16-2010, 11:46 AM   #1
njhardc0re
njhardc0re's Avatar
Drives: 2SS/RS
MBRP Cat Back 304 Stainless
Anyone have any experiences with the MBRP Cat Back 304 Stainless system (V8)?
I heard some clips and wanted to know if anyone actually had it..
Thanks!
njhardc0re is offline   Reply With Quote
Old 03-16-2010, 01:43 PM   #2
SummoneR
Paul
SummoneR's Avatar
I have the 304 cat back system on my Manual SS.
I like it. It is a deep mellow tone, not too loud but a nice low rumble. It's sounds much different then a Flow Master or Stainless Works exhaust, those are more loud and aggressive raspy sounding.
Old 03-16-2010, 02:38 PM   #3
TC
TC's Avatar
Drives: 2010 VR 2SS-RS
I've got their x pipe with no cats or resonators, and it's pretty loud. Sounds really good at low to mid rpm- gets a little loud with some droan on highway. Keep it in 5th gear though and your golden!
TC is offline   Reply With Quote
Old 03-16-2010, 02:38 PM   #4
njhardc0re
njhardc0re's Avatar
Drives: 2SS/RS
Def don't want raspy. I just want to have one that doesn't go completely silent when cruising. I was originally was going to go for the magnaflow comp series but I heard that is pretty quiet unless you step on the gas.
Old 03-16-2010, 02:53 PM   #5
SummoneR
Paul
SummoneR's Avatar
Ahh, well this has a good sound at start up and idle, a rev sounds good but not as impressive as it sounds when taking off, under load it sounds much better. At freeway speeds it's a nice low rumble and not too loud to drive you nuts.
Good luck in whatever you choose.
Old 03-16-2010, 03:04 PM   #6
caverman
caverman's Avatar
Drives: '69 SS Convertible
Are you wanting to go with 3" only? If you can stick with 2.5" I would recommend you look into Magnaflow's 2.5" Comp Series (different than their 3") or the SOLO Mach X.
MBRP is a very good system as well. It was #1 on my list for a long time. Ended making my own Magnaflow/Factory system for about 1/2 the cost. I would've gone MBRP if I was willing to spend that kind of money.
Build Journal
Old 03-16-2010, 03:29 PM   #7
njhardc0re
njhardc0re's Avatar
Drives: 2SS/RS
This one is only about $200 more than the comp series.
http://www.camaropartsoutlet.com/69504/119.html
Old 03-16-2010, 05:44 PM   #8
jachevy28
Camaro. Is. Life.
Drives: 2016 1SS
I have MBRP as well on my daily driver. Definitely happy with the sound (and I had a Corsa on my '02 Z28 for reference). SummoneR describes it well above...it resonates and rumbles at a low octave and sounds great at idle, and under load at low rpm's...which is where most of my daily driving occurs.
jachevy28 is offline   Reply With Quote
Old 03-16-2010, 06:00 PM   #9
SATXLS3
SATXLS3's Avatar
Drives: 2012 GMC Sierra Z71 4x4 Crew
MBRP 3in
Thanks!
I have the 3in MBRP T304 stainless cat back on my M6 LS3. Love it! Worth the money! Sounds awesome at start up, revs, cruise. Loud but not obnoxious. One person told me it sounded like a vette! Going with the CAI next, which should sound even better! Good Luck!
SATXLS3 is offline   Reply With Quote
Old 03-16-2010, 07:01 PM   #10
njhardc0re
njhardc0re's Avatar
Drives: 2SS/RS
Very cool
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 08:43 PM
Question About Cat Back & Axle Back Exhaust Systems SamSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 01-03-2010 01:42 PM
mbrp for sale cat back $900 camaross14 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 4 12-29-2009 02:37 PM
MBRP Camaro exhaust in stock GmPartsDirect.com V8 Bolt-Ons & Tunes 3 11-08-2009 11:01 AM
Cat Back Exhaust Question? Paul4137 V8 Bolt-Ons & Tunes 4 10-31-2009 10:05 PM
