Old 08-18-2011, 10:16 AM   #253
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Originally Posted by Venom_SS View Post
Ok, I orders the cts-v calipers but am having a hard time getting some front rotors. Can you guys help me find some that don't cost an arm and a leg. I have tried to look for Dba or other companies that offer drilled but only brembo so far. They are very expensive at $1300 for the front pair. I tried r1 and grantelli but either have anything. Please help
Availability has been an issue for CTS-V rotors. Have you checked on availability for the GMPP Brembo two piece rotor for the CTS-V?
Old 08-18-2011, 12:21 PM   #254
Venom_SS
Drives: Camaro SS
The brembo 2 pc was $1300 for the pair. I was looking for something a little more reasonable
Venom_SS is offline   Reply With Quote
Old 08-18-2011, 10:29 PM   #255
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Drives: /\yes, this is me/\
Can I ask what you paid for the the calipers?
R.I.P. http://www.camaro5.com/forums/showthread.php?t=373249
Back Street Performance has done a great job with ALL my Performance & Suspension mods, highly recommend them (Rich@BSP) he's in my friends list. https://youtu.be/Lht8sKe1Maw
TLSTWIN is offline   Reply With Quote
Old 08-18-2011, 11:38 PM   #256
JusticePete
Give one of these two Chevy / Pedders Dealers a call for help with the CTS-V bits.
Becky Dolye
Rogers Chevrolet
chevyfleet@aol.com
(734) 479-7171
Rich Wilhoff
Abel Chevrolet Pontiac Buick
r.willhoff@yahoo.com
(888) 599-4944
Old 08-19-2011, 12:40 AM   #257
Venom_SS
Drives: Camaro SS
They list to call them but when you do they will just take your number. After a day they call you and say the rotors are unavailable at the moment
Old 08-19-2011, 10:35 AM   #258
JusticePete
mike@thepowdercoater.com originally posted this in a self standing thread. I thought it was worth reporting it here. Thanks for a great tip Mike.
Originally Posted by mike@thepowdercoater.com View Post
I know its a popular upgrade, but be advised that when swapping the rears out for cadillac rears, the balance tubes should be moved to the opposite side of the cadillac caliper before installation.
On the camaro caliper, the crossover tube is on the side with the smaller piston. Because the caliper sits on the leading edge of the rotor on the cadillac, rather than the trailing edge like the camaro, the crossover tube is on the side with the larger piston.
The reason for the difference is pad wear and taper. The leading edge wears faster and generates more heat, so to compensate for it, perfomance caliper manufacturers put smaller pistons on the leading edge.
Fronts are oriented the same on both cars, so if doing a front only upgrade there is no issue.
Just some friendly advice from your local powdercoater.
That is a great tip. We did flip them on our install, but I do not think we made it as clear as you did.
Old 08-25-2011, 03:50 PM   #259
JusticePete
Availability of the OE CTS-V rotors has been problematic. I am checking with the source to see if there is anything we can do to alleviate this. I should have a response back shortly.
Old 09-04-2011, 10:38 AM   #260
jai
Drives: VE SSV
Only took 1 day for me to get some last week from buygmpartsdirect.com
jai is offline   Reply With Quote
Old 09-04-2011, 11:36 AM   #261
tsears
tsears's Avatar
Drives: 2010 Camaro 2SS/RS - L99 - CGM
How much did they run you?
2007 Corvette Z06 - Velocity Yellow
Halltech | Forgestar | Bilstein
tsears is offline   Reply With Quote
Old 09-04-2011, 07:59 PM   #262
jai
Drives: VE SSV
About $250 + shipping
Old 09-05-2011, 11:20 PM   #263
08G8V8
Drives: 2008 Pontiac G8GT
I've got the gen1 CTS-V calipers on the front of my G8. Now that we have a solution for keeping the ebrake, I'm looking to complete the installation with the gen1 CTS-V calipers on the rear.
Both gen1 and gen2 CTS-V models had the rear calipers mounted on the forward side of the rotor. Both also had the crossover tube on the lower side of the caliper, which based on what Mike said, would be on the LARGER piston.
I'm trying to grasp the design rational of the larger vs smaller pistons, and position relative to the rotor. Is the mounting of the CTS caliper on the "leading edge" of the rotor considered "leading edge" because it is "forward" of the axle, vs the Camaro on the "trailing edge" because it is "aft" of the axle?
I was thinking the "leading edge" of the rotor would be the first portion of the rotor to enter the caliper, hitting the pad first.
Could you please elaborate on this for me? THANKS!
08G8V8 is offline   Reply With Quote
Old 09-07-2011, 05:15 PM   #264
JusticePete
You are correct.
The leading edge is in reference to the rotation of the rotor to the caliper when driving forward. We'll call the smaller Piston #1. When the Caliper is mounted on the front side of the rotor Piston #1 is on top and the cross-over tube on the bottom. To keep the leading edge orientation the same when mounted on the backside of the leading edge Piston #1 is on the bottom. That is why the cross-over tube is moved.
Last edited by JusticePete; 09-08-2011 at 11:51 AM. Reason: Corrected large to small
Old 09-07-2011, 06:53 PM   #265
08G8V8
You are correct.
Here is a photo of a drivers side rear CTS-V on the left. As you state, the smaller Piston #1 is on the top of the caliper and the cross-over tube is on the bottom of the caliper. As the rotor goes around forward, it hits Piston #1 first.
You take that same drivers side rear CTS-V caliper and rotate is 180 degrees to mount it on the rear of the axle, the picture on the right, Piston #1 now moves to the bottom of the caliper and the cross-over tube to the top. Rotor rotation remains the same, so as the rotor rotates forward, it still hits Piston #1 first.
This looks like it keeps the leading edge orientation as you stated above. What am I missing here?
Old 09-07-2011, 07:01 PM   #266
Beauwulf
Beauwulf's Avatar
Drives: '10 LT RS A6 & '04 Acura RSX Type S
Here is a photo of a drivers side rear CTS-V on the left. As you state, the larger Piston #1 is on the top of the caliper and the cross-over tube is on the bottom of the caliper. As the rotor goes around forward, it hits Piston #1 first.
The bleeder port is on the bottom when the caliper is aft of the axle! You can't bleed it that way....
Beauwulf is offline   Reply With Quote
Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 TAG UR IT Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 57 05-28-2016 10:10 AM
Camaro Production Numbers 1967 - 2002 PAUL SS General Automotive + Other Cars Discussion 3 07-22-2010 08:12 AM
GM Reveals 2011 Chevrolet Silverado HD FenwickHockey65 General Automotive + Other Cars Discussion 55 03-04-2010 02:56 PM
Need Stopping Power? Baer 15" Six Piston Brake Upgrade now available! Kris@BMCPerformance Suspension / Chassis / Brakes 11 12-10-2009 07:50 PM
Baer 15" 6 Piston Extreme Plus Brake Upgrade for 2010 Camaro Available Now! Kris@BMCPerformance Suspension / Chassis / Brakes 6 11-04-2009 10:17 PM
