| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
#101 | |
![]() Drives: 2010 2SS/RS & 04 silvy Join Date: Mar 2008
#102 |
![]() ![]() Drives: 69 Convertible Camaro Join Date: Sep 2008
#103 |
I used to be Dragoneye...
That's all I would ask....stupid waiting game!!!
#104 | |
Not That sad..considering
Drives: Man Join Date: Aug 2007
Location: the part of washington the capital forgot about.
Stop Whinging
#105 |
Okie doke
Lets try to put this into perspective. As a former 2004 Cobra owner (eventually modded to 509rwhp / 520rwtq) ..
Stock, people got those cars to run mid-high 12s at 110 - 113mph .. That was with 390/390 and a car weight of about 3665lbs .. If the camaro puts down the advertised HP/TQ (which I bet it will and then some) but is at about 3850lbs or so .. I think it should run high 12's at about 110 or so with a good driver. Also, there is a big differnce (at least w/ ford) between the live axel and the IRS setup. It seemed to me with the IRS I could get a lot better traction with higher hp/tq numbers. Even when I was a 520rwtq .. I could put it down pretty well. I did however upgrade from the stock 275s to 305s on 18x10 inch rims .. Crowley |
#106 | ||||
The Jalopy Jedi
Drives: anything I can get my hands on Join Date: Sep 2006
horsepower sells cars. torque wins races.
#107 |
Helping Build America
Drives: 2010 2SS/RS,LS3 2006 Colorado Join Date: Aug 2008
Like I said it was 1976. I was 17 yrs old. I also said blowing that tranny probably saved my life. I was pretty wild back then and thought I had the world by the balls. A few months after that I was in the army jumping out of C-130s at FT Bragg. Go figure. Go all my Airborne brothers!
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
#108 | |||||
The Jalopy Jedi
week 1. seperate the men from the boys week 2. seperate the men from the fools week 3. the fools jump
#109 |
![]() Drives: 2007 GMC Sierra Join Date: Jul 2007
k i got a question though, but i wonder if he said the auto as in not using tap shift or if he meant using tap shift controls, because i thought TAPshift was always faster than a manual in most cases anyways
#110 |
o-60 is probably going to be only one shift so there isnt going to be much difference between the paddles and the normal auto
Stop Whinging
#111 |
i forgot i was just saying with how the LS v8 engines run that a 750hp LS v8 would have more then 600 ft lbs of torque.
Stop Whinging
#112 | |||||
The Jalopy Jedi
and it all means nothing if you cant get it to the ground. case in point 346hp LT1 - 11.8 seconds 1/4 mile
#113 |
i wasnt even refering to that, some one said the rear end was good for 600 ft lbs and i was refering to my talk with Oppenhieser about how they put 750hp through the rearend so my comment was to infer that 750hp in a LS v8 would be closer to 680-700 ft/lbs . i was just making a point about the rearend and transmission strength not what was better.
Stop Whinging
#114 | |
junior member
Drives: Grand Am Join Date: Aug 2008
#115 |
![]() Drives: 2010 GTI Join Date: Jun 2008
I wonder if the moderator could merge this thread with the "auto faster than mt" thread. That could be interesting.
#117 |
![]() Drives: Future 2012 owner, 1965 Impala Join Date: Aug 2008
That's a popular belief, but it's not accurate. Torque is simply a measure of instantaneous force, not power over time, and a part of the equation that determines horsepower. Horsepower, on the other hand, is the measure of the rate at which work is done, and that determines the car's rate of acceleration. A better way to say what is meant by "torque wins races" is to say that horsepower developed by higher torque at lower rpm wins races, because that develops useable horsepower at rpm levels likely to be seen on street driven cars.
Bob |
#118 | |
Okie doke
You know what I got out of that ... torque wins races. ![]() ![]() ![]()
#119 |
#120 | |
![]() Drives: 2005 Pontiac GTO Join Date: Jul 2008
6= number of gears L= longitudinal mounting 80= torque capacity minus a zero (meaning 800lbft) E= electronically controlled That's for the auto. But I believe the T-56 in the GTO was supposed to be able to handle more than the 4L60e (which would be 600lbft if you're paying attention) in the auto version. The trans designations is something I learned from training at my auto repair shop. |
#121 |
Okie doke
In regards to the tranny .. I'm not sure how the 6 speed holds up against the T56, but in my cobra I was making a lot more than 450ftlbs and it seemed to hold up just fine. That being said, I didn't beat it to death and it never had slicks ...
Crowley |
#122 | |
Okie doke
LOL .. definitely know what you mean .... A nice broad torque band is nice as long as you can use put it to the ground. It makes sense that if you are going to make modifications that will increase torque, you should have the proper mods done so you can safely keep it on the ground ... point taken I think one thing that people will find out is that with the IRS in there, it will be easier to keep it to the ground (as long as the half shafts can withstand it ....)Crowley |
#123 |
![]() Drives: 08 STI/Family Hauler Join Date: Oct 2007
Here is something I've been wondering. The 08 M3 is 416hp 290 something tq and weighs 3700 and change and gets 4.1-4.3 0-60 (mag testing so who knows), wouldn't the SS be about 4.3-4.5 just based on power to weight? Or are there lots of other factors at play?
Not that it matters for me as anything under 5 seconds is plenty fast for me. |
#124 | |
The new M3 has a redline of somewhere over 8000 rpm, which is how they get to over 400 hp, as hp is proportional to rpm HP=Torque*rpm/5252. So the M3 is more of a race car engine, producing very little hp down low-compared to what we are used to. By using a lot of expensive technology, such as individual throttle bodies-8! that isolate pulses they are able to achieve acceptable street manners with what would otherwise be too aggressive of a camshaft. There are some obvious tradeoffs in longevity, as a motor that needs to be pushed that high just to really get going will not last like a 6000 rpm motor, in my opinion. As for your question, gearing also plays a key role as I would be willing to bet the M3 is geared much more aggressively than the Camaro, and even with a tiny 4L v8 still gets only 20mpg on the highway. I think this is why it would be somewhat faster with similar hp and weight, they sacrificed a lot of efficiency and longevity for performance. To each his own I suppose.
Hooters, hooters, yum yum yum, hooters, hooters on a girl thats dumb.
-Al Bundy 07 2WD Trailblazer SS, LS1 E-fans, 4" FWI, pcmforless tune 72 VW Beetle, 2275cc, Dual 44 IDF's |
#125 |
Fear the Hawg!
Drives: 1998 Camaro SS Join Date: Oct 2008
I hope the 4.6 0-60 for the M6 turns out to be true, but I'll be skeptical of any times until a few production cars are tested.
| Thread Tools | |
| Automatic faster than the manual??? | 2sharp | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 319 | 09-30-2008 09:20 AM |
| looking for 2nd gen repair manual? | [KRPT]ECP | 1st & 2nd Generation Camaros | 4 | 02-27-2008 05:02 PM |
| Detroit's 3 finally on track, tough critic says | TAG UR IT | General Automotive + Other Cars Discussion | 1 | 10-14-2007 12:16 PM |
| Camaro Manual Transmission | LSxcellent | 5th Gen Camaro SS LS LT General Discussions | 17 | 08-01-2007 05:11 AM |
