Gen5DIY
5th Gen Camaro SS LS LT General Discussions General 5th generation Camaro topics not covered by other subforums.
Old 03-17-2010, 01:00 AM   #1
Tran
Administrator
Tran's Avatar
Cool C&D: 2010 Lingenfelter Camaro SS shootout with 2010 Roush Ford Mustang Stage 3
As featured on Homepage Blog.
2010 Lingenfelter Chevrolet Camaro SS vs. 2010 Roush Ford Mustang Stage 3 - Comparison Tests
Pony Excess: The Lingenfelter Camaro SS meets the Roush Mustang Stage 3.
BY ROBERT RICH, PHOTOGRAPHY BY MARC URBANO
March 2010
http://www.caranddriver.com/reviews/...mparison_tests
Even though the auto industry is sputtering—along with the rest of the economy—there remains a cadre of horsepower junkies who always want more than the factory has delivered. The recent arrivals of a resurrected Camaro and a new Mustang have stoked this group’s desire for more tire-obliterating thrust.
Lingenfelter Performance Engineering (LPE) exists to satisfy such primal cravings. LPE has built a Camaro SS with its $10,995 TVS2300 kit, essentially a Magnuson/Eaton supercharger with high-flow fuel injectors, a cold-air induction system, a voltage-boosted fuel pump, and a recalibrated engine-management system. Though the engine is internally unchanged, the system’s 9 psi of boost is good for 570 horsepower.
To put those extra 144 horses to the pavement, the LPE car gets a host of other upgrades, including 20-inch wheels shod with Nitto NT05 tires ($4415), a 3.70 rear axle with heavy-duty half-shafts ($3484), a dual-disc clutch from a ZR1 Corvette ($1860), and a stiffer Hotchkis suspension ($1710). Add to that a Corsa exhaust ($1750), big Brembo brakes ($7940), and various lesser upgrades, and the mods ($34,539) just about double the Camaro SS’s sticker price ($35,125) for a total of $69,664.
The Roush Mustang Stage 3 doesn’t bite into your wallet quite as hard, coming in at $61,255, which amounts to $28,510 of Roush Performance upgrades and the $31,845 price of a specific Roush-ordered Mustang GT. This lower price isn’t due to less content. In fact, the Roush engine has been reworked more extensively than the LPE V-8 because in order to achieve similar power (540 horses) from its much smaller V-8 (4.6 liters), its supercharger must blow harder—up to 15 psi. To ensure that the more highly pressurized engine doesn’t bust its gut, it gets lower-compression forged pistons, forged connecting rods, and a forged crank. The Roush Stage 3 also gets the expected upgrades to its clutch, suspension, exhaust system, and wheel-and-tire package, though only the front brakes are bigger.
In addition to the go-fast bits, however, the Roush Stage 3 package also includes appearance upgrades ranging from aero bodywork to Roush-emblazoned gauges, upholstery, floor mats, and shifter. There’s even a kit full of Roush-inscribed tools that drops down from the trunklid.
Though ostensibly similar mechanically, the two cars have very different personalities, which is as it should be in the realm of Camaro versus Mustang. We are not ranking them here as we do usually because that struck us as meaningless—if you’re a dedicated Chevy guy, nothing is going to convince you to go out and spend twice the money for a modified Mustang. Still, driving the two back-to-back was illuminating.
As quick as the stock Camaro SS is, the Lingenfelter-modified car is in a different league. Unless you’re on perfectly clean, dry, and warm pavement, full throttle in any of the lower gears produces instant wheelspin. On the cold, damp day of our road drive, full throttle would spin the rear tires even in fourth gear, in a perfectly straight line.
At the track, the LPE Camaro scorched the quarter-mile in 12.2 seconds at 120 mph—0.8 second and 9 mph quicker than the stock Camaro SS. The huge power boost exists at all speed ranges, with the LPE car 0.9 second quicker to 60 (3.9 seconds) and hitting 150 mph in 19.5 seconds—an interval at which the stock car is huffing and puffing to get past 133 mph.
Even in the Camaro’s tall sixth gear, the LPE version, helped by its shorter, 3.70 rear end, shaves about four seconds from the stock model’s 12-second 30-to-50 and 50-to-70 times. That’s the virtue of a supercharger, which boosts engine output across the rpm range, and the LPE implementation of the Magnuson/Eaton TVS2300 blower is flawless. The engine operates with all of the refinement and tractability of the naturally aspirated stock V-8.
We were equally satisfied with the LPE Camaro’s controls. The shifter, which has shorter throws, is precise and not unduly heavy. The dual-plate ZR1 clutch is just as smooth and linear. And the steering and brake feel are natural and make for effortless driving.
The Corsa exhaust sounds purposeful from outside the car, but inside it’s quiet, particularly when cruising on a highway. And the ride is also comfortable on smooth roads, though there’s a bit more vertical motion than in a stock Camaro.
Push the LPE Camaro on a bumpy back road, and the car is less happy. Under those conditions, the suspension never settles down and the car moves around at all times, both vertically and laterally, so you need to keep a firm hand on the steering wheel to stay in your lane. And if you’re hard on the gas, the LPE Camaro’s extraneous motions are amplified.
The upgraded suspension on this car did not include upgraded shock absorbers. We suspect that a set of shocks matched to the stiffer springs and anti-roll bars would help the car calm down on back roads. That said, this is a delightful machine in every other way, and if you love the new Camaro and want one with enough power to embarrass any legendary muscle-car species from the Sixties, you won’t go wrong with this LPE modification.
One needs to have a strong extroverted streak to drive this Mustang because people will notice the spoilers, the stripes, and the ubiquitous Roush labeling. But this Stage 3 Stang doesn’t put curb appeal before performance.
With 15 psi of boost generated by its supercharger, the highly modified 4.6-liter V-8 develops 540 horsepower, only 30 fewer than the Lingenfelter. As a result, it’s only a hair slower than the 143-pound-heavier Camaro in the usual sprints. Zero to 60 takes 4.2 seconds, and the quarter-mile is history in 12.4 seconds at 119 mph. Above 130 mph, however, the Roush falls behind the Lingenfelter, hitting 150 nearly four seconds later.
Still, in everyday driving, this Stage 3 Mustang is a burner, able to light up its rear tires at will and accompanying the forward thrust with a beautifully syncopated rumble from its exhaust system. That exhaust note is ever present; while it’s momentarily thrilling, hearing it all the way to the West Coast would be trying. Still, this Roush Mustang delivers as stirring a V-8 exhaust tone as we’ve ever heard, and it gives the car great character.
Another distinctive feature is the old-fashioned short-throw shifter. It reduces fore-and-aft motions, but side-to-side motions are also narrow and notchy. You won’t be moving the lever diagonally between gears—the shifter dictates distinct motions along two axes. Combined with a clutch that tends to finish its engagement a bit suddenly, this powertrain demands concentration.
The Roush chassis, on the other hand, is very well calibrated. Even though it lacks the independent rear suspension of the Camaro, the ride is smooth and settled, even on the bumpy back roads that confound the Lingenfelter car. The steering is precise and linear, and the brakes are plenty strong for hard street driving. In serious cornering, the seats also do their part, offering suede-like upholstery in the center and firm side bolsters that are tight enough to constrict drivers weighing north of 170 pounds.
We haven’t seen many aftermarket body kits that truly improve the looks of a car, but the Roush’s is an exception. The panels are beautifully made and perfectly fitted, the wheels are gorgeous, and the big white racing stripes enhance the car’s screaming-blue paint.
With its excellent performance, flamboyant style, and fantastic exhaust sound, the Roush Stage 3 delivers an experience that is even more special—and faster—than a production Shelby GT500's. With only a limited number produced each year, the Roush is well worth the 13-grand premium over the Shelby for those who crave domestic speed in a unique wrapper.
>>> Visit our CAMARO BLOG <<<<
>>> Visit our CORVETTE BLOG <<<<
Old 03-17-2010, 06:16 AM   #2
GMRULZ
GMRULZ's Avatar
Drives: 2010 SS & 2008 C6
They need the driver mod for those cars...Lol..
I ran 12.2 w/ just headers, CAI & a tune on stock pirelli`s...Same as the Lingenfelter...
They should have let me drive it...
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s!
Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list..
GMRULZ is offline   Reply With Quote
Old 03-17-2010, 06:25 AM   #3
R.I.P. jesserayjames
Drives: 2010 IOM 2SSRS
I am glad I was born a Camaro lover, the back of that mustang looks like crap, Camaro is so much better looking car.
2010 SSRS is online now   Reply With Quote
Old 03-17-2010, 06:41 AM   #4
1badSS/RS
1badSS/RS's Avatar
Drives: Rally Yellow Transformers pkg
1badSS/RS is offline   Reply With Quote
Old 03-17-2010, 07:46 AM   #5
nosrettap58
nosrettap58
nosrettap58's Avatar
Drives: 2012 cadillac srx
O.K. I'm bias but the mustang is fugly.
nosrettap58 is offline   Reply With Quote
Old 03-17-2010, 07:53 AM   #6
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Nice cars... and am happy the Camaro came out on top !!
Old 03-17-2010, 08:14 AM   #7
tmurphycardesign
Drives: 2010 camaro, v6, manual, cyber grey
great pics!
tmurphycardesign is offline   Reply With Quote
Old 03-17-2010, 08:34 AM   #8
calflan
calflan's Avatar
Drives: 1LT; IBM; 6 Spd Manual
Unreal how much better the Camaro looks, front, rear, all around.
You really nailed it on styling Chevy ! Mustang, in my opinion, never really had the appeal of the Camaro.
1LT; Airaid CAI; Flowmaster American Thunder Axelback; Int Floor Lts; RS Spoiler; Radio Controls; Sequential tail lights; Oil Catch Can; VMAX Throttle Body; MACE plenum spacer; Mace manifold insulator[/I]
calflan is offline   Reply With Quote
Old 03-17-2010, 01:06 PM   #9
youngoliver
youngoliver's Avatar
Drives: 2SS/RS SIM -- Lifted 99' GMC
Awesome car... the camaro that is haha
youngoliver is offline   Reply With Quote
Old 03-17-2010, 01:13 PM   #10
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Very cool pics !!! Can anyone say in need of traction .. LOL
Both cars look great!
Crowley
Crowley is offline   Reply With Quote
Old 03-17-2010, 01:15 PM   #11
Days75
Days75's Avatar
Drives: 2010 VR 2SS A6
both very hot! I would gladly take either out for a joy ride!
Days75 is offline   Reply With Quote
Old 03-17-2010, 01:16 PM   #12
Shardik2SS
How U Doin?
Drives: #21,644
Something is definitely wrong with that time. Especially when one of our members, nhra stocker ran a 12.43 @ 112 bone stock. I would have expected lower times than posted.
Shardik2SS is offline   Reply With Quote
Old 03-17-2010, 01:27 PM   #13
TaylorRyanSS
COTW: 12/13/10
TaylorRyanSS's Avatar
Drives: '12 370Z, '69 Camaro coming soon!
I really like the front of the mustang but the back end next to that beautiful Camaro booty makes the stang look cartoonish. Nice Review.
2010 CAMARO SOLD! JOURNAL: http://www.camaro5.com/forums/showthread.php?t=119635 | FACEBOOK: http://www.facebook.com/taylor.ryan.apt | GRAPHIC DESIGN: www.aptdesigns.net
Old 03-17-2010, 01:33 PM   #14
x7productions
x7productions.com
x7productions's Avatar
Drives: 2010 BMW E92 3-Series Coupe
Send a message via Skype™ to x7productions
However, I do think the front end on the new mustangs isn't that bad.
Watch Camaro : Heritage - Featuring over ten Camaro5 Members' 2010/2011 Camaros!
http://www.camaro5.com/forums/showthread.php?t=158574
Go like our Facebook Fan Page!
http://facebook.com/x7productions/
x7productions is offline   Reply With Quote
Old 03-17-2010, 01:33 PM   #15
Muscle Master
SS Lightning
Muscle Master's Avatar
Drives: An SRT8
I don't care what anyone say .... that mustang is sharp !!!
The first rule of modding something that's not American is to not try to compete with modded V8 cars that are American. Really, they can run insane power with little investment. It's not even a fair fight.
Camaro 2SS RS, IBM, White Rally Stripes, custom fuel door: Status: going to the dealer: soon
Muscle Master is offline   Reply With Quote
Old 03-17-2010, 01:34 PM   #16
camarowa
camarowa's Avatar
Drives: 2013 SVT Raptor, sold 2010 Camaro
- Pfadt Suspension Package; Springs & Sways
- Brembo Brake Upgrade (Yellow); Courtesy Fesler Built
- Custom Magnaflow Exhaust
- Blacked-Out Bowties & RS Emblems, Front bowtie delete
- Full Dynamat Extreme Trunk Coverage
- Tinted side markers
- Interior DSV Customs Leather Upgrades
- Airaid CAI V2
- Forgestar F14 Gunmetal 20x9, 20x11
- Doug Thorley Shorties
camarowa is offline   Reply With Quote
Old 03-17-2010, 01:34 PM   #17
Nucleartiger
Drives: 2011 Camaro 2SS/RS Black M6
I like the front of both but the rear of that Mustang is horrible. I can't decide if it is the fact that the Camaro looks like it is scowling at you while the mustang looks wide-eyed and frightened or (nothing meant offensively here) that the Mustang just looks like some of that Japanimation stuff that they put on tv these days and call cartoons.
Nucleartiger is offline   Reply With Quote
Old 03-17-2010, 01:38 PM   #18
Gabe
Gabe's Avatar
Drives: '10 Camaro 2SS/'65 Malibu SS
I'm loving that under-the-hood picture of the Camaro!!
NMCVBC - CGM 2SS/RS/BLK/A6
(original order date): 06/27/09
3000 (accepted to production): 08/17/2009 TPW
3300 (scheduled for prod): 08/17/09
3400 (broadcast): 08/18/09
3800 (produced): 08/22/09 A9138699
4200 (shipped): 8/24/09
5000 (at dealer): 09/04/09
6000 (del to cus): 09/04/09
Gabe is offline   Reply With Quote
Old 03-17-2010, 01:40 PM   #19
600hp-lpe
600hp-lpe's Avatar
Drives: 2010 2SS RS RJT MN6
Might have something to do with the tires.. I'm guessing.
I have a LPE 570 Camaro and will run it sometime this summer.. and it won't be on Pirelli's.
My 2005 Corvette C6 totally stock pulled 12.2 - 12.3 times all day long.
The LPE Camaro is definitely faster.. no question in my mind.
I just need the drag strip near me to open to prove it... they open early April.
2010 2SS/RS RJT 6SP
600 HP Lingenfelter package 526 RWHP 491 RWTRQ
Pedders Justice package with Z-bar and supercar coilovers
LPE ZR-1 twin disc Clutch, LPE rear w/3.73 gears
NHRA cert. 8.50 CM 10 point roll cage, Cobra racing Seats
Gforce 5 PT. Harnesses, MOMO steering wheel and pedals
285/35/19 Bridgestone RE-11 Tires, CCW 19X10 SP16A Wheels
315/30/18 Front, 335/30/18 Rear Hoosier tires, CCW C2K Wheels
Racing Brake Rotors, stainless lines, MT800 Brake pads
Spohn HD Rear Axles, Toe Links, Trailing Arms, Lower Control Arms
Beware of the LPE Brotherhood
600hp-lpe is offline   Reply With Quote
Old 03-17-2010, 01:49 PM   #20
PQ
Drives a Maro
PQ's Avatar
Drives: Hybrid SS Camaro
Don't be so surprised at the times for these cars. After all, a half a second cost money.
Well........ I gained a half second pulling a few fuses but .............. still.
Oh, and I know this article is about performance mainly but I too find the Camaro miles ahead of the Stang here. OMG, that is one seriously ugly ford. And I do like the Mustang in general.
PQ is online now   Reply With Quote
Old 03-17-2010, 01:52 PM   #21
JohnInSoCal
Drives: RJT L99 500HP
that's a heck of a lot of money to run a 12.2. I don't know what mine would run in a 1/4 but my L99 auto is a hair faster to 60 MPH than the LPE on stock tires at less than 1/3 the price.
JohnInSoCal is offline   Reply With Quote
Old 03-17-2010, 02:05 PM   #22
Silver Ice
Silver Ice's Avatar
Drives: 2010 Camaro 2ss-rs
I agree, the mustang is fugly.
Silver Ice is offline   Reply With Quote
Old 03-17-2010, 02:09 PM   #23
the upcoming
the upcoming's Avatar
Drives: 10'2SS/RS,94'toyoda,02'vette
and that stang doesnt have an inpection sticker...
the upcoming is offline   Reply With Quote
Old 03-17-2010, 02:21 PM   #24
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I don't think that was a great representation of either of those cars. Most rags actually almost admit they don't go for absolutely the fastest times; I don't understand that reasoning (i.e. no powershifting, TC, on, and other BS). Seeing those times doesn't lead me to believe these cars are a great value, however, I know there are people running better times with similar cars, so though I thought it was a good article, it may not be the best representation of the subjects. Still - I thought LPE was using Pedders or Pfadt suspension systems for their cars...
"...What IS true: We anticipated that this would happen - we are never finished - and yes, Ford DOES deserve to win now and then. To think that GM can come out with a car to make ford throw in the towel is simply foolhardy..." - fbodfather
Old 03-17-2010, 02:23 PM   #25
REAPER SS
REAPER SS's Avatar
Drives: 2010 CAMARO BLK 2SS/L99
Kick ass Camaro
REAPER SS is offline   Reply With Quote
Gran Turismo 5... No Camaro? 5thGenOwner 5th Gen Camaro SS LS LT General Discussions 111 12-06-2011 10:06 AM
Winner, winner - Jalopnik compares the Big 3 Number 3 5th Gen Camaro SS LS LT General Discussions 31 04-17-2011 03:24 PM
Latest Camaro Products - March 2010 Sean@Phastek V8 Bolt-Ons & Tunes 26 08-04-2010 04:42 PM
The DEFINITIVE EXPLANATION OF CAMARO SUSPENSION, ISSUES, AND UPGRADES Info@PeddersUSA.com Suspension / Brakes / Chassis 106 10-19-2009 06:08 PM
