Solo Performance
Old 03-17-2010, 01:55 AM   #1
Kreature
Kreature's Avatar
Drives: Summit White 1LT/RS
Need help removing SS/RS badge Front grill
hey guys, just recently got my camaro and i need help on how to take the RS badge on the front grill.
i heard from others on the forums that it was only connected by a few clips. ive tried to take it off with my hands and i know i can feel like the clips but i just dont know in which direction i need to pull/push. it feels like i might break something and my other option would be to take the whole front bumper off to take a look and eventually take it off but i dont trust myself in doing that. im hoping someone could help me out with some directions without having the bumper removed. Much appreciated!
Kreature is offline   Reply With Quote
Old 03-17-2010, 04:59 AM   #2
baysinger
baysinger
Drives: 2010 IOM M6 SS
If you raise your hood you can then remove the top plate in front of the radiator I believe there are 4 bolts and 6 grummits that hold it in place. You will then be able to see and access the clips holding the bowtie to the grill. Not very hard once you remove the plate.
baysinger is offline   Reply With Quote
Old 03-17-2010, 09:07 AM   #3
caverman
caverman's Avatar
Drives: '69 SS Convertible
I used a small but long flat blade screwdriver to help. Push the edges inward while pulling out on the emblem. Here is the pic of mine I pulled out.
Build Journal
Old 03-17-2010, 05:05 PM   #4
Kreature
Kreature's Avatar
Oh wow thanks guys. now i have a good idea on how to take it off.
Old 06-26-2013, 11:56 AM   #5
AKA-22
AKA-22's Avatar
Drives: ELLE-1
sub
AKA-22 is offline   Reply With Quote
CAMARO WIKI Tran Wiki 55 03-28-2017 12:04 PM
Front grill markbolt 5th Gen Camaro SS LS LT General Discussions 0 02-21-2010 02:41 PM
Removing Front Bowtie Support? BlownSS 5th Gen Camaro SS LS LT General Discussions 18 01-29-2010 02:31 PM
Will SS/RS have "induction" style hood and SS front bumper? okernan6.2 Cosmetics and Lighting Modification Discussions 12 11-23-2008 01:55 AM
1SS standard equipment and options Tran Wiki 1 11-05-2008 02:34 PM
