| V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters |
Thread Tools |
Drives: 2010 Challenger R/T;2011 Mustang GT Join Date: Jan 2010
Barton Shifter
Alrighty....got home from being out of town all week and got it done. I will focus only on the areas of interest.
Remove: Getting the stock shifter out was pretty easy. Hardest part was getting the shifter out from below. Not much clearance around the driveshaft. Install: Getting the Barton shifter pressed in from below can be tough. Took me about 15 minutes to position it correctly so I could press it in from below. It is a very tight fit with the o-rings. Make sure you grease them before install. ![]() The instructions mention loosening the cross-member for the transmission and lowering 1/2". I personally don't feel this was necessary but may help others. Back in the car, I installed the Barton shifter handle. Very straight forward. Next was the boot and then the shifter knob. I went with the standard SS ball and it is really a beautiful piece. I have found the source of rattle for the shifter. Please see below: **Source of shifter rattle** The shift knob is what rattles under acceleration. There are a couple of solutions. 1. Install the lock nut, add some teflon tape about 1/2" above the lock nut, screw the shifter ball down. 2. Use some RTV silicone and coat the threads of the shifter handle after installing the lock nut. Install the shifter ball and lock it down with the nut. Let dry overnight. 3. Use the stock shifter handle. The dynamat some folks are using is just masking the real problem. My recommendation for Barton would be to install a nylon nut in the bottom of the shifter ball/grip. Impression: This product screams quality. It is outstanding in design and really is a work of art. I would highly recommend it to anyone. ![]() Pics: ![]()
![]() Drives: 1968 RS/SS 396 Join Date: Aug 2008
You are going to luv your new shifter
IN MY GARAGE
2010 2SS/RS Camaro from Camaro Scotty, Magnuson TVS2300 supercharger, Kooks LTH with High flow cats, ADM RACE CAI, Barton Shifter, Livernois tune, Eibach Pro kit... 2006 C6 Z06 1993 Ruby Red 40th Anniversary Corvette convertible 1971 Corvette convertible 1968 RS/SS 396 Camaro 2009 335i xdrive BMW[/B] |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS IOM L99 Join Date: Jan 2010
they are nice.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 RJT 2LT/RS Convertible Join Date: Nov 2009
No better Shifter, service and economics. Just switched over to the flat stick and the comment from people passing by has increased 2 fold !
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Drives: 2010 Camaro SS Join Date: Sep 2009
#6 |
#7 |
![]() Drives: 2010 Camaro 1SS/RS RJT Join Date: Jan 2010
He is VERY FAST, he shipped mine out the same day and I go it two days later, putting it in this Saturday with the help of another forum member ...now just waiting on the Black T-Handel
2010 Camaro SS LS3 Vortech V-3,10Rib 3.47 Pully Airfilter Pipe Delete, 10 PSI, TSP LT Headers
Borla S, Alky Control Meth Kit, PFADT 1.25, ZL1 Fuel Pump, DSS 1000HP axles, Mantic ER2 Clutch, Hex Vents ECS Tune 658 RWHP 598 RWTRQ |
#8 |
![]() Drives: 2010 Camaro 2SS IOM M/T Join Date: Feb 2010
That's it, i've read enough threads with positive comments on this shifter. Ordered mine five minutes ago. First mod to my month old Camaro.
#9 |
You will not regret upgrading to the Barton shifter.
#10 |
#11 |
Just put mine on this weekend, well Slim SS put it in for me but I watched , Love it so far, feel and looks!! Side note, if any one is thinking of getting this or any other shifter and exhaust cut outs, id recomend putting the shifter in first, kinda made it cramped trying to work up there under the car with the cut outs in!
#12 |
![]() Drives: summit white/IOM ss/rs ls3 Join Date: Jan 2010
i installed my barton with the flat stick and love it, but it did chatter a bit in 2nd and 3rd under mid to WOT. I havent done the dynamat yet but i thought i would share what i have done and it took 75% of the chatter away. i took some regular grey silicone and put it on the threads of the shifter and a little inside the flatstick. i took it for a drive right after putting the silicone in and it didnt seem to help alot, but after it dried i have almost no chatter anymore.
#13 |
Shifter arrived today. Will install this weekend with review and pics.
#14 |
Bump.
#15 |
Installed my Barton shifter this afternoon and just got back from a test drive. That's how a shifter should feel and perform! Kept the stock knob for now. Thanks Barton for a well engineered performance shifter.
#16 |
![]() ![]() Drives: 2012 Camaro ZL1 SIM CTF Car M6 Join Date: Jan 2010
Very pleased with mine!
2012 ZL1,CTF Car, SIM MN6, Polished Wheels,The Rare Flat Black Insert. Proud member of the unofficial Camaro5 "Rodgers Chevrolet Fan Club" ![]() |
#17 |
![]() Drives: 2010 IBM 2SS/RS Join Date: Dec 2009
I just had the Flat Stick installed. What an amazing product at an incredible price.
I had never used a short throw shifter before and I wish I had the money to do this sooner. Very solid mechanical feel, and I love the way it clicks as it moves into gear. The only thing I noticed is the black aluminum ball gets VERY hot if it sits in the sun for a few minutes. Anyone who is considering this, do it!! Best $210 you'll ever spend.
IBM 2SS/RS, M6, Polished Wheels, 3M Clear Bra, 27% Windows, CAGS Eliminator, Barton STS
Upcoming Mods: Cold Air Inductions CAI, Kooks 1 7/8" LTH, and 3" Exhaust, Tune. 1100 Order accepted at dealer: 3/15/2010 - NVTZ1X 3300 Scheduled For Production: 3/17/2010 TPW 4/5/2010 3800 Produced: 4/7/2010 2G1FT1EW3A9208281 5000 Delivered To The Dealer: 4/21/2010 6000 Delivered To Customer: 4/23/2010 |
#18 |
What a great product! Can't complain at all about the whole process! Barton has one hell of a great product and if your thinking of getting a short throw shifter no one out there can touch the quality or customer service!
#19 |
![]() Drives: 04 sentra, 2ss Join Date: Apr 2009
Wow great price and positive reviews I might have to order
| Thread Tools | |
| TAG's 2010 THRSS #2 | TAG UR IT | Member Car Journals | 2731 | Yesterday 08:53 AM |
| DIY Hurst Short Throw Shifter Install - Pix and Video | TAG UR IT | Camaro DIY & HOW-TO instructions & discussions | 77 | 04-28-2013 09:10 PM |
| My Shifter Review – Factory vs Hurst vs MGW | caverman | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 46 | 02-02-2013 04:03 PM |
| Pic's of Aftermarket Shift Knob on Stock shifter stalk | jammer174 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 3 | 12-04-2010 08:49 PM |
| Barton Short Throw Shifter (Post-Installation) | rauhaus camaro | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 1 | 12-26-2009 02:39 PM |
