Homepage | Garage | Wiki | Register | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
![]() Drives: 2010 LS3 SS Aqua Blue Join Date: Jul 2009
"Custom" Hurst chrome shifter lever installation
I didn't really want a short throw shifter as I like the way the stock shifter works (and I didn't want to spend $300+ for a new shifter), but I do like the chrome Hurst shifter lever with a ball, etc. So, I designed an adapter and I modified my shifter lever. I will try to post the pictures of the process in different stages here. If I can't figure out how to post the pictures here, I will post them on my profile.
If you want to do this yourself, I suggest just cutting off the upper part of the factory shifter below the weld to expose the top of the rubber insulator and then cutting the insulator out. (The factory shifter arm is a two piece unit that has rubber insulation between the two parts. The upper part is actually two pieces welded together. It has the tapered & slotted post (used to hold the leather covered knob in place) welded to a tube. Pull straight up on your knob and it will come off. I ended up using a drill to cut up the rubber insulator from the top on down. It is messy, but slotting the side like I did won't do you any good unles you do it in two places, split the housing, and pry it apart. But that may not even work very easily as the rubber is most likely bonded to the metal. It is probably injected and cured, etc. You'll see what I am talking about from the pictures. You''l have to scrape the rubber off anyhow and cleaning up a rubber mess is much better than a metal shavings mess. (Less metal cutting is better in my opinion) I don't feel any vibration issues with the shifter arm adapter that I installed. I used a thin piece of rubber insulation wrapped around the lower shaft, but it probably isn't necessary. I also designed my adapter before cutting the stock shifter up. I wasn't sure what it would look like until I cut it apart, but I assumed the lower shaft was uniform in diameter, and it is. If I had to do it all again, I would probably just design a less complex adapter, and mount it solid with some set screws. I actually drove the car around running errands with just the little stub (lower part of the factory arm) and nothing else. It wasn't difficult. There was plently of leverage with just that little stub. I have about $70 invested in this. Last edited by Kripp; 03-19-2010 at 12:45 AM. |
![]() Drives: 2010 Camaro 2SS/RS Join Date: Apr 2010
very nice. do mine
So-Cal Race team!!
Drives: Tahoe LTZ,2010 2SS/M6 Camaro Join Date: Apr 2009
WOW!!
BBK Intake, Flowmaster AT cat back Barton shifter,Painted stripes,,Heritage grill,LED DRLs, Smokin Tires!! |
ACE5
Drives: 2010 2SS/RS LS3 Join Date: Sep 2009
Nice. What parts did you use? Where did you find the arm adapter?
SIM 2SS/RS LS3, Vararam, RX Catch Can, SOLO HF Cats, Flowmaster AT Catback, Skip-Shift Eliminator. 404HP/414TQ
![]() Drives: 69Camaro,87IROC,96 SS,Z06&Stingray Join Date: Apr 2010
I really like the look of the old style shifter.
How does the HURST shaft attach to the adapter? Does it have to be welded? |
#6 |
I have seem them at Summit Racing.
Airaid CAI (V2 Tube)/ Flowmaster American Thunder/ Barton Shifter Kit/ Hotchkis Sport Sway Bars/ Hotchkis Sport Springs/ AAC Lights/ GM Trim Kit/ Tint/ Pioneer Premier Champion Series Sub/ Pioneer 1500 Watt Amp |
#7 |
Yes, I cut off the Hurst arm to the length I wanted and had it welded it to the adapter.
#8 |
I saw the parts and bought them all (chrome lever, ball, and rubber grommet) from someone on e-bay. I made the adapter that the lever is welded to.
Thread Tools | |
DIY Hurst Short Throw Shifter Install - Pix and Video | TAG UR IT | Camaro DIY & HOW-TO instructions & discussions | 121 | 02-26-2015 10:08 AM |
TAG's 2010 THRSS #2 | TAG UR IT | Member Car Journals | 3129 | 08-14-2014 09:29 AM |
My Shifter Review – Factory vs Hurst vs MGW | caverman | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 46 | 02-02-2013 04:03 PM |
Pic's of Aftermarket Shift Knob on Stock shifter stalk | jammer174 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 3 | 12-04-2010 08:49 PM |
Hurst Shifter Review on 2SS | linkwpc | Vendor and Seller review / feedback / experiences | 22 | 06-15-2010 08:27 PM |
