Old 03-19-2010, 01:12 PM   #1
Hotchkis
Drives: 1st through 5th gen Camaros
Alignment Help Thread
We are excited to see that many Camaro5 enthusiasts have now installed performance coil springs and handling packages.
We've noticed quite a few threads with questions about height and alignment for our products and others. We've put together a list of our testing numbers and experiences in order to help answer some of the more commonly asked questions. We are using numbers and images from our R&D and testing on customer cars. Due to the numerous Camaros we have modified and tested, we have built a nice data base of chassis variances and build tolerances. The bottom line is, the car is built with very tight tolerances. When compared to the earlier Camaros, the 5th gen is in a whole new league for fit and finish.
Perhaps some of the other shops and vendors can post their alignment advice as well, and this thread can be useful when speaking with alignment shops and dealerships. We want you to have the best experience possible with Hotchkis, from install to racetrack. If you find you have a question that isn't answered above, PM or call us. We want your input.
Our quick facts:
· With stock and our sport coils we have seen minute ride height variances, with most cars at or under 1/16” and only one with a corner measurement variance of 1/8”
· Even after 1000’s of punishing street and track miles we have not seen our sport coils settle. We design our coil springs to be low stressed and spec high tensile excellent quality steel to eliminate any possibility of material fatigue. Our coils are preset during manufacturing, compressed to coil bind to ensure proper load height, shot peened to relieve material stress and most important, are made in the USA.
· Below is a picture of the slotted strut mount standard on all Camaros. A good amount of camber adjustment is available without grinding or alignment hole modifications.
· So far we have not found it necessary to grind out any alignment holes to achieve a proper street/track performance alignment.
Alignment specs for the 2010 Camaro SS:
STOCK SPECIFICATIONS-STOCK SPRINGS
FRONT:
· CAMBER: 0° to -1.6°
· CASTER 6.70° - 7.10°
· TOE: 0 TO 1/8” TOTAL TOE IN
REAR:
· CAMBER: 0° to -1.0°
MEASUREMENT MINIMUMS & MAXIMUMS FOR HOTCHKIS SPORT COIL EQUIPPED VEHICLES
NOTE
These are not our recommended alignment specs. They represent the alignment range possible with our sport coils installed.
Note that increased neg. camber of the lowered car is beneficial to performance handling.
FRONT:
· CAMBER: -0.4° to -2.6°
REAR:
· CAMBER: -0.7° to -1.8°
HOTCHKIS PERFORMANCE STREET SETUP
FRONT:
· CAMBER: -1° to -1.4°
· CASTER 7.00° - 7.50°
· TOE: 1/16” TOTAL TOE IN
REAR:
· CAMBER: -0.8°
· TOE: 1/16” to 1/8” TOTAL TOE IN
HOTCHKIS TRACK DAY/STREET SETUP
FRONT:
· CAMBER: -2.0° to - 2.5°
· TOE: 0 to 1/16” TOTAL TOE IN
REAR:
· CAMBER: -1.0° to - 1.25°
We determined our recommended alignment settings through street and track testing using the stock Pirelli tires. These settings are a great place to start, offering acceptable tire wear and grip in a variety of performance driving conditions. Driving styles, track condition, tire selection, tire pressure and most importantly tire temperatures across the face of the tire are the determining factors of final alignment settings.
Hotchkis is offline   Reply With Quote
Old 03-19-2010, 03:42 PM   #2
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
Pedders Camaro/G8 Bushing Timing Tech Sheet.pdf
Pedders Camaro/G8 Alignment Tech Sheet.pdf
We have based our align specs for street and track based on professional drivers using telemetry equipment, tire temp monitoring, and recommendations from 3 professional drivers, including Paul Tracy.
The following Aggressive Street settings are recommended based on an average drop of 1 inch:
Front:
Camber to -1.0 degrees
caster 7.4 to 7.8 degrees (requires adding caster Pedders Caster eccentrics to get into this range of caster, which is very benificial
Toe: .1 degrees toe out each wheel.
This amount of toe out will reduce tire scrub and understeer, and will not add to tire wear.
Rear
Camber to -.5 degrees. Reducing the camber to this level will reduce understeer. With a 1 inch drop or lower, you cannot obtain this number without Pedders rear camber eccentrics
Toe to .05 degrees toe in each wheel.
For Aggressive Track
Now these settings are only for a Camaro with a Complete Pedders Track suspension Package. This setup with street performance tires can hit 1.38g's thru the turns, and have great tire temps all across. Paul Tracy said this setup was "PERFECT"
Front
Cambers to -2.4 degrees
Caster 7.5 to 8.0. Requires Pedders Caster eccentrics
Toe .25 degees toe out each wheel. (This setting should not be used for the street)
Rear
Camber -1.2 degrees, Required Pedders rear eccentrics
Toe .05 toe in each wheel.
Here is a video of the Pedders Camaro with these settings, driven by Paul Tracy. Notice the Pedders Camaro being chased by a ZR1, which could not go the same line as the Pedders Camaro.
Here is a video from Chris Fessler, our dealer and sponsor:
http://vimeo.com/8678971
Any questions just ask
thanks
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 03-19-2010, 03:48 PM   #3
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Thanks Guys..
This stuff is great !!!
Old 03-20-2010, 05:30 AM   #4
eblake98
Drives: 2010 Black
Which settings?
Street Alignment:
Front:
· Camber: -1° to -1.25°
· Toe: 1/16” Total TOE IN
Rear:
· Toe: 3/16” to Ό” Total TOE IN
Thanks,
Mark Rossetti
Brand Manager
Hotchkis Sport Suspension
562-907-7757 xt 225
Fax : 562-907-7765
Do I use the above or what what was just posted? Also were the bump stops trimmed?
eblake98 is offline   Reply With Quote
Old 03-20-2010, 09:49 AM   #5
Mr Twisty
Mr Twisty's Avatar
sticky! Great info
-- Benjamin Franklin
Old 03-20-2010, 10:11 AM   #6
kga10734
Don't Feed the Troll
kga10734's Avatar
Drives: 2010 Camaro 2LT/RS & 1999 Corvette
I vote STICKY this thread, that way others don't have to go hunt this info down like I did. My alignment guy was able to get both my front and rear camber to -1.0 degrees without any suspension modifications or special bolts, and I have a 2 1/8" drop on front and 2" drop on the rear.
kga10734 is offline   Reply With Quote
Old 03-20-2010, 07:08 PM   #7
Info@PeddersUSA.com
If you are -1.0 degrees front and rear, you are not set up for max abilities.
Having the ability to add 1 to 1.25 degrees positive caster is a big deal. Having the rear cambers to complement the front cambers is again a big deal. But if you are happy with your setup, that is a big deal as well.
thanks
mike
dms
Old 03-20-2010, 07:20 PM   #8
kga10734
kga10734's Avatar
thanks
mike
dms
He was able to get my front Caster set to around 7.5 to 7.7 if I remember correctly. I'm going to drive it like this for a while and see how things work out. Then I'll take it back down and get everything checked again in a few months.
Old 03-25-2010, 11:59 PM   #9
1BadaSS
Drives: 2010 CGM 2SS 6spd
Where did you get yours aligned at?
2010 CGM 2SS/6MT-Kooks LT headers w/cats, MBRP Exhaust, D1-SC Procharger, FAST 65lb Injectors, NGK TR-6 plugs, 160* T-stat, ADM Boost Gauge,ChuckTuned= 530rwhp/500rwtq
1BadaSS is offline   Reply With Quote
Old 03-26-2010, 12:11 PM   #10
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Hey everyone! This is a great idea to get a thread together with everyone's recommendations. Below is an image of a downloadable PDF on our website, with our recommendations for various alignment settings according to end-use. Please let us know if you have any questions at all!
Here is a link to the PDF: Alignment Settings
Old 04-16-2010, 11:00 AM   #11
caverman
caverman's Avatar
Drives: '69 SS Convertible
Ok...I have a question on the alignment. I have a set of Hotchkis springs on the way and should be installing them shortly after I get them. I don't know all that much about Camber/Caster/Toe etc. so bare with my wording if it's not correct.
This is my daily driver and I won't really be going to the track.....maybe once or twice if at all. I would like it to handle nicely but not necessarily at the cost of eating up my tires prematurely.
If I remember reading correctly others have said that a -.05 was the most they could get out of the way the factory had the car setup. Looking at everyones recommendation for a Performance Street setup you are recommending more than that.
So, should I just have them set my alignment to the factory settings and/or have them get as close to the Peformance Street settings as possible or is there some other settings you would recommned for someone in my driving situation?
Build Journal
Old 04-16-2010, 01:29 PM   #12
Info@PeddersUSA.com
You have ample adjustability of from camber at any height
You currently do not have any caster adjustability. But caster can be increased and made adjustable with our Pedders front Adjuster kit
When dropping your rear, negative camber can significantly increase. Excess negative camber in the back end increases understeer. Thru telemetry, we have determined your vehicle will handle better at -.5 degrees rather than -1.0 degrees. I have yet to see a Camaro able to get to -.5 degrees camber at the rear with OE eccentrics. Do I think it is possible? Yes. There are potential tolerance issues that may allow one to be able to get this low. But that would be the exception, rather than the rule. Pedders Rear Alignment Kit
thanks,
mike
dms
Old 04-16-2010, 02:01 PM   #13
caverman
caverman's Avatar
thanks,
mike
dms
Man.....don't really want to spend onther $200+ right now if I don't have to. What would your suggestion be if I didn't go with an alignment kit for now?
Build Journal
Old 04-16-2010, 07:09 PM   #14
Info@PeddersUSA.com
I totally understand!
This is what I would do:
Front.
Camber to -1.0 each
toe to .1 degrees toe out each wheel
Rear
Camber, get the least amount of negative Camber as possible
Toe, toe in .05 degrees each wheel
Hope this helps and drive safe.
mike
dms
Definitive GT500 Thread garagelogic Chevy Camaro vs... 98 02-12-2010 01:14 PM
Lets start a Tire Specific Thread here, sizes, brands, specs and other usefull info. 55Designs Wheels and Tires Talk Sponsored by The Tire Rack 0 12-20-2009 07:58 PM
Suggestion: Explanation to thread starters for their threads being locked? colin911 Site Related Announcements / Suggestions / Feedback / Questions 2 12-06-2009 10:25 PM
Dealer Praise Thread (Not an Idiot!) RPO_Z28 Camaro Price | Ordering | Tracking | Dealers Discussions 84 06-25-2009 01:00 AM
prices thread nimnels 5th Gen Camaro SS LS LT General Discussions 1 05-02-2009 06:47 PM
