Cold Air Inductions
Old 04-16-2010, 09:41 PM   #15
Scourage
Syntax Error
Scourage's Avatar
Drives: 2010 Camaro 2SS/RS
I've been keeping an eye on the suggested settings with a 1" drop, but how does changing tread width effect things? Wider tires obviously
Scourage is offline   Reply With Quote
Old 04-17-2010, 12:54 AM   #16
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
does not actually affect the alignment that much but it can change the way the car handles. I.E. a split configured tire might look great, but the handling is reduced as compaired to having a oversized tires front and rear being equal.
What tires/tire size were you thinking of?
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 04-19-2010, 11:35 AM   #17
Hotchkis
Drives: 1st through 5th gen Camaros
We have worked on quite a few 5th Gens at our R&D center here in California, as well as on-site at Willow Springs during several track tests. With our Hotchkis springs and OE alignment capabilities, the vehicle can adjust camber from -0.4° to -2.6° for the front and -0.7° to -1.8° for the rear. No need to buy a kit or anything like that. For your situation where tire wear is important on a street driven car, we suggest the following alignment specs:
Front:
Camber: -0.75° to -1°
Toe: 1/16” total toe in
Rear:
Camber: -0.8°
Toe: 3/16” total toe in
Hope this helps!
Hotchkis is offline   Reply With Quote
Old 04-19-2010, 12:59 PM   #18
caverman
caverman's Avatar
Drives: '69 SS Convertible
Front:
Rear:
Camber: -0.8°
Hope this helps!
Thanks.....
I have another question for you. One of the Pedders guys suggested the following about loosing the bolts, driving around slowly, and then re-tighten before alignment. It definately sounds logical....should I do this for the Hotchkis springs as well. Also, I'm assuming I won't need to cut the bumpstops?
The most important step in installing lowering coils is to time the OE rotational bushes to the new ride height. EVERY control arm bolt must be loose: front LCA, front radius arm, rear toe, trailing, inner lower... With the bolts loose drive the Camaro SLOWY around the lot and on to the alignment rack rails. With the weightbof the car on the wheels tighten all the bolts. The bushes are now timed to your new ride height. This means your second set of springs the bushes are now working with your new Peddes lowering coils.
Build Journal
Old 04-20-2010, 12:40 PM   #19
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
It realy doesn't matter with who or how you lower your car,Loosing the control arm pivot bolts and retightening them with the wieght on the tires should be done.This is called timing the bushings,if not done the ride can be slightly stiffer and will cause the bushings to fail premature.This applies to the factory rubber bushings.Most aftermarket bushings piviot by design unlike the factory bushings.
Bruce@raymondsperformance is offline   Reply With Quote
Old 04-20-2010, 03:58 PM   #20
caverman
caverman's Avatar
Thanks....it makes sense to do this.
By chance does anyone have a pic of the Control Arm Pivot bolts and any of the other bolt locations that should be loosened before alignment? I'm going to have the Alignment guy do it but since I don't know 100% which bolts need to be loosened I would like to see a pic so that I have a clue as I watch what he losens.
Build Journal
Old 04-20-2010, 04:01 PM   #21
Info@PeddersUSA.com
With the exception of the cradle bushings, if there is a bushing on it, you should loosen it. The biggest culpret is the upper rear control arm bushing, which is, of course, the hardest to get to.
mike
dms
Old 04-21-2010, 11:19 PM   #22
caverman
caverman's Avatar
mike
dms
Ok....one more question on this. Does anyone know if the bolts need to be re-torqued to a specific number? Or...just have them get it as tight as they can and then re-check in a week or so?
Build Journal
Old 04-21-2010, 11:38 PM   #23
Info@PeddersUSA.com
The predictable response will be all bolts need to be torqued to GM specs, and also review the 1 time bolt/nut policy by GM
mike
dms
Old 04-21-2010, 11:40 PM   #24
caverman
caverman's Avatar
mike
dms
Anyone know how I can find out what the GM torque specs should be on the different bolts?
Build Journal
Old 04-21-2010, 11:52 PM   #25
Info@PeddersUSA.com
You need to confirm these torque measurements.
thanks
mike
dms
Old 06-02-2010, 11:31 PM   #26
Scourage
Syntax Error
Scourage's Avatar
mike
dms
Took it to the dealer today for an alignment, 1" drop, 275/40 Pirelli's up front, 315/35 Nitti Invo's on the rear.
Gave them the recommendations from the site, street 75%/track 25% is what I was shooting for.
Front;
Camber -1.4
Caster 8.0
Toe 1/16" in
Rear;
Camber -0.9
Toe 1/16" in
When I picked it up, I see they got Camber and Toe very close to what I wanted, but Caster on the front is 6.0 with a note on the invoice saying caster is not adjustable. I thought that was just rear only on the non-adjustable caster.
Appreciate any input and whether I need to clarify the camber issue with the dealer.
Old 06-02-2010, 11:45 PM   #27
Info@PeddersUSA.com
Front;
Camber -1.4
Caster 8.0
Toe 1/16" in
Rear;
Camber -0.9
Toe 1/16" in
Caster is not adjustable on the front. But Pedders makes an eccentric that will make it adjustable and will add 1.0 to 1.25 degrees caster. It does require slotting the hole which will take about .5 to 1.0 hours to complete
Reducing your rear camber to 50% of the front will reduce your plowing when driven very aggressively. Also taking the front toe to .1 degrees toe out each wheel will make a positive affect as well.
There is a signficant thread or 2 on the caster eccentrics.
mike
dms
Old 06-03-2010, 12:02 AM   #28
Scourage
Syntax Error
Scourage's Avatar
Guess I missed that one. I've seen the threads on the eccentrics and was waiting to see what I could get done with the alignment first.
I know it feels a lot better than it did before the alignment.
I may have upset a few neighbors as I was driving around the round-about just down the road.
Looking at hitting the track for the first time this weekend.
Definitive GT500 Thread garagelogic Chevy Camaro vs... 98 02-12-2010 02:14 PM
Lets start a Tire Specific Thread here, sizes, brands, specs and other usefull info. 55Designs Wheels and Tires Talk Sponsored by The Tire Rack 0 12-20-2009 08:58 PM
Suggestion: Explanation to thread starters for their threads being locked? colin911 Site Related Announcements / Suggestions / Feedback / Questions 2 12-06-2009 11:25 PM
Dealer Praise Thread (Not an Idiot!) RPO_Z28 Camaro Price | Ordering | Tracking | Dealers Discussions 84 06-25-2009 02:00 AM
prices thread nimnels 5th Gen Camaro SS LS LT General Discussions 1 05-02-2009 07:47 PM
