Old 05-23-2011, 05:02 PM   #71
markssylver
markssylver's Avatar
Drives: 95 bbb impala ss
So how do you time the bushings is that when loosen the suspension bolts and drive the car the align it an retighten the loosened bolts
10.56@134mph
ADM BUILT AND TUNED CGM 2SS RS
ADM/LPE 417 with ported heads/inconel vavles gt11 cam
ADM ported maggie with 14 rib rear 10 rib front pulleys
ADM fuel system and race air intake
ADM/LPE ZR1 clutch /pedalreturn spring
ADM billet aluminum valve covers /RPM LEVEL 6 TR6060
LPE HD 241mm diff with 3:45 gears HD axles and d/s
ADM widened wheels with 315nitto nt05s Bogart 17 dragwheels CTS-V front 6 piston brakes
Pedders HD subframe/differential bushings alignment kit 27/32mm sways Supercar coilovers
683RWHP/650RWTQ
markssylver is offline   Reply With Quote
Old 05-23-2011, 05:40 PM   #72
caverman
caverman's Avatar
Drives: '69 SS Convertible
I wouldn't loosen them and then drive it. You have the alignment guy losen them, SLOWLY drive it around the parking lot or have them vigorously shake/move the car, then re-tighten and align.
I woudn't drive it with loose bolts. You don't want your suspension to fall off on the way to the alignment shop.
Make sure to find an alignment shop that knows what you are talking about when you say you want them to time the bushings. At least they should be familiar with the process if they use different terminology. If they say it's not necessary and won't make a difference....find another shop. Be prepared to pay more money than just a regular alignment. There is more work involved with timing the bushings.
Build Journal
Old 05-31-2011, 04:48 PM   #73
DHSS
DHSS's Avatar
Drives: Empty
My car pulls hard to the right after three times to the alignment shop. Guys says he got them to exactly match the factory settings which doesnt seem right to me. Can anyone please help? Also, a rattle from the passenger rear when the rear suspension goes over a bump. Could this be the issue for the pulling?
Thanks
DHSS is offline   Reply With Quote
Old 05-31-2011, 04:55 PM   #74
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Thanks
If the car check out alignment wise I would not be concerned with the rattle being connected to the pull. It would really help if you could post the exact alignment specifications found on your Camaro. The reason is straight forward. The green range, the factory tolerances for alignment are 'generous'. You could be in the green range all around and create a pull. Please see if the Dealer will provide you with an alignment sheet so you can post it up.
Old 06-27-2011, 06:47 PM   #75
camaro34
camaro34's Avatar
Drives: 2011 Camaro SS
What's a good drag racing set up for stock suspension?
camaro34 is offline   Reply With Quote
Old 06-27-2011, 07:21 PM   #76
JusticePete
What is your RWHP.
Old 06-27-2011, 07:35 PM   #77
camaro34
camaro34's Avatar
What is your RWHP.
417
Old 06-27-2011, 08:49 PM   #78
JusticePete
417
Drag radials or slicks?
Old 06-27-2011, 09:06 PM   #79
camaro34
camaro34's Avatar
I shamefully say stock pirellis. I don't really want to lose that on road handling. I just want to get ride of the wheel hop. I have BMR TR's and Toe rods and pedders diff bushings and TR bushings. I want to get cradle bushings but their not in the budget right now.
Old 06-27-2011, 09:16 PM   #80
JusticePete
No worries.
Well start my guess is alignment will help. Get to the local alignment shop and have them dial in just a bit of toe in .05. Have them set your rear camber to the least amount of negative camber possible. These adjustments will square up your rear toe and put maximum rubber to the track surface. As a by product redducing rear camber will help reduce understeer.
When you can, get the inserts and you should be good to go.
Old 06-27-2011, 10:37 PM   #81
camaro34
camaro34's Avatar
No worries.
Thanks, I'm trying to save up for the HD bushings. Can i bring the car to any alignment shop?
Old 06-27-2011, 11:08 PM   #82
JusticePete
Yes sir. If they are not sure what to do have them call Pedders at 248.522.8021
Old 06-27-2011, 11:10 PM   #83
camaro34
camaro34's Avatar
Ok thanks for the advice and help.
Old 07-06-2011, 02:56 AM   #84
caligrown562
Drives: 2012 1SS
This might be a supid question but are the alignment specs for a stock ss the same on a stock v6. If not what are the best specs for a stock v6? Thanks
caligrown562 is offline   Reply With Quote
Definitive GT500 Thread garagelogic Chevy Camaro vs... 98 02-12-2010 02:14 PM
Lets start a Tire Specific Thread here, sizes, brands, specs and other usefull info. 55Designs Wheels and Tires Talk Sponsored by The Tire Rack 0 12-20-2009 08:58 PM
Suggestion: Explanation to thread starters for their threads being locked? colin911 Site Related Announcements / Suggestions / Feedback / Questions 2 12-06-2009 11:25 PM
Dealer Praise Thread (Not an Idiot!) RPO_Z28 Camaro Price | Ordering | Tracking | Dealers Discussions 84 06-25-2009 02:00 AM
prices thread nimnels 5th Gen Camaro SS LS LT General Discussions 1 05-02-2009 07:47 PM
