Old 07-06-2011, 07:03 AM   #85
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
Originally Posted by caligrown562 View Post
This might be a supid question but are the alignment specs for a stock ss the same on a stock v6. If not what are the best specs for a stock v6? Thanks
It is different, what the specs are i'd don't know. When I had SS suspension installed I had to tell the shop FE3 for the alignment.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 07-06-2011, 10:55 AM   #86
gahammerle
gahammerle's Avatar
Drives: 2010 Camaro LS M6 Inferno Orange
Here's a spec sheet for V6, SS, & G8 - both stock & performance:
http://forum.wretchedms.com/showthread.php?t=60
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers
Find me on Facebook:
http://www.facebook.com/gahammerle
gahammerle is offline   Reply With Quote
Old 07-12-2011, 05:41 PM   #87
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
And now here too.
Old 09-06-2011, 11:27 PM   #88
Rogan
No Pain No Gain
Rogan's Avatar
Drives: Yellow 5th Gen 2SS RS
Originally Posted by Info@PeddersUSA.com View Post
We have based our align specs for street and track based on professional drivers using telemetry equipment, tire temp monitoring, and recommendations from 3 professional drivers, including Paul Tracy.
The following Aggressive Street settings are recommended based on an average drop of 1 inch:
Front:
Camber to -1.0 degrees
caster 7.4 to 7.8 degrees (requires adding caster Pedders Caster eccentrics to get into this range of caster, which is very benificial
Toe: .1 degrees toe out each wheel.
This amount of toe out will reduce tire scrub and understeer, and will not add to tire wear.
Rear
Camber to -.5 degrees. Reducing the camber to this level will reduce understeer. With a 1 inch drop or lower, you cannot obtain this number without Pedders rear camber eccentrics
Toe to .05 degrees toe in each wheel.
For Aggressive Track
Now these settings are only for a Camaro with a Complete Pedders Track suspension Package. This setup with street performance tires can hit 1.38g's thru the turns, and have great tire temps all across. Paul Tracy said this setup was "PERFECT"
Front
Cambers to -2.4 degrees
Caster 7.5 to 8.0. Requires Pedders Caster eccentrics
Toe .25 degees toe out each wheel. (This setting should not be used for the street)
Rear
Camber -1.2 degrees, Required Pedders rear eccentrics
Toe .05 toe in each wheel.
Here is a video of the Pedders Camaro with these settings, driven by Paul Tracy. Notice the Pedders Camaro being chased by a ZR1, which could not go the same line as the Pedders Camaro.
Here is a video from Chris Fessler, our dealer and sponsor:
http://vimeo.com/8678971
Any questions just ask
thanks
mike
dms
I knew those mountains looked familiar! I did the zr1 class out there. Pretty impressive to see the Camaro hold a nice line and zr1 trying to hold as tight. This vid just pushed me closer to getting the zl1 and upgrading the suspension for track use. Thanks!
2010 2SS/RS/L99 - Headers/CAI/SWAYs/CoilOvers/Tune/Steel Braided Brake Lines/Frozen Slotted Rotors
Rogan is offline   Reply With Quote
Old 09-07-2011, 10:08 AM   #89
JusticePete
Old 09-13-2011, 02:04 AM   #90
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
Too much front camber
Throughout this year, I've lost count of the number of times my car has been up on the alignment rack. The main reason is to try various alignment settings to see how the car would respond.
The rear of the car is very well behaved. Oversteer is (mostly) predictable and managable with the throttle.
The front of the car is where the Camaro's 3800 lbs really rears its ugly head. Terminal understeer occurs much too easily and early. To battle this, I tried all sorts of camber settings.
-1.5° front camber caused understeer to occur early and easily.
-2.5° front camber made the front end grip much better, but at the cost of lost braking. You can really feel the difference how poorly the car brakes with too much camber.
-1.7° front camber seems to be a pretty good compromise. Next year, I plan to go back to the shop and dial in more -ve camber 0.1 degree at a time to try to get the best of grip and braking power.
My current alignment specs are as follows:
Front
Camber: -1.7°
Toe: -0.1° (out)
Caster: 7.3
Rear
Camber: -1.3° (max out stock adjusters)
Toe: +0.15° (in)
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 09-13-2011, 10:40 AM   #91
JusticePete
Front
Camber: -1.7°
Toe: -0.1° (out)
Caster: 7.3
Rear
Toe: +0.15° (in)
Everything you are doing is right on the money. What wheel and tire package are you running?
Old 09-13-2011, 11:39 AM   #92
Avalnch
Avalnch's Avatar
Running:
Forgeline GA3 20x10/20x11 + Toyo R888 285/40R20 & 315/35R20
Old 09-29-2011, 02:59 PM   #93
JusticePete
Running:
It would really help if we could get more rubber up front. I haven't run the front to rear numbers, but something like a 305/30/20.
Old 09-29-2011, 11:23 PM   #94
Avalnch
Avalnch's Avatar
More rubber up front would be nice for sure, but 20" R-compound tires are hard to come by. Waiting for more choices.
Old 02-10-2012, 08:09 PM   #95
njdad61
njdad61's Avatar
Drives: '12 45th Ann. 2SS Coupe, '79 Z28
I'm about to install BMR Split Drop Springs (1.4" front/1" rear), Trailing Arms (poly bushings), and Toe Rods (non-adjustable). I have the stock P-Zero tires and around 415 rwhp. I'm looking for the best alignment specs for my car. It is mainly a daily driver, although I have a very heavy foot and need all the traction I can get! I also plan on taking it to the drag strip a few times but I want the settings to best promote good tire wear and street traction. Below are the alignment specs in the BMR Spring installation instructions, but is there something more exact I should have the alignment guy shoot for? Thanks for any help!
STREET PERFORMANCE
Front camber: -0.8min to -1.1 max
Rear camber: -0.7min to -1.0max
Front toe: -1/16"
Rear toe: -1/16"
Front caster: 7 to 8.5 (OE not adjustable)
2012 45th Anniversary Edition 2SS LS3
CFM Painted Heritage Grille, JRE Custom Tune, VMAX CNC Ported Throttle Body, Doug Thorley LT Headers w/ Catless Midpipes, Borla S-Type Catback, RotoFab CAI, ADM Race Scoop, ADM W/W Reservoir Relocation Kit, MGW Short Throw Shifter, BMR Split Drop Springs(1/4" front/1" rear), BMR Trailing Arms, BMR Toe Rods, 6000k HID Bulbs, AAC P13W Plasma LED DRLs, AAC ABL Interior Lighting Kit (Dome/Footwells/Trunk), RPI Designs Charcoal Sidemarker Covers
njdad61 is offline   Reply With Quote
Old 02-11-2012, 09:54 AM   #96
JusticePete
STREET PERFORMANCE
Front toe: -1/16"
Rear toe: -1/16"
Daily Driver?
Weekend Drag Strip Warrior
Autocross Champion?
Give me a more details about your driving and I'll set you up with an alignment to suit.
Old 02-11-2012, 01:35 PM   #97
njdad61
njdad61's Avatar
STREET PERFORMANCE
Front toe: -1/16"
Rear toe: -1/16"
Daily Driver?
Autocross Champion?
It's a daily driver so I'd like as much traction as I can get on the street. I only plan on going to the drag strip maybe a couple of times per year. Thanks!
Old 02-12-2012, 11:35 AM   #98
JusticePete
We can do that!
Front
Caster: No Factory Adjustment
Camber: -.75
Toe: ZERO
Rear
Camber: ZERO or as close to ZERO as possible
Toe: IN .10
Improved rear tire wear, better on center steering feel all round better driving feel.
Definitive GT500 Thread garagelogic Chevy Camaro vs... 98 02-12-2010 01:14 PM
Lets start a Tire Specific Thread here, sizes, brands, specs and other usefull info. 55Designs Wheels and Tires Talk Sponsored by The Tire Rack 0 12-20-2009 07:58 PM
Suggestion: Explanation to thread starters for their threads being locked? colin911 Site Related Announcements / Suggestions / Feedback / Questions 2 12-06-2009 10:25 PM
Dealer Praise Thread (Not an Idiot!) RPO_Z28 Camaro Price | Ordering | Tracking | Dealers Discussions 84 06-25-2009 01:00 AM
prices thread nimnels 5th Gen Camaro SS LS LT General Discussions 1 05-02-2009 06:47 PM
