SDTW Custom Wheels & Tires
Old 03-25-2012, 05:46 PM   #113
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
1. Looking at your picture, it doesn't appear lowered
2. You can still adjust the camber in to spec, but it doesn't make it right, bottom line you likely have a bent part and verifying will be difficult with out changing it.
3. I'm not 100% sure on this, but i believe that a frame machine only checks the unibody, but i've never done it so i'm not sure on that.
4. yes
5. The before specs indicate that the strut may be bent, as it would affect the camber and the toe. It has no bearing on the previous owner.
i would be much more concerned with the strut than i would be with the alignment at this point.
Info@PeddersUSA.com is offline   Reply With Quote
Old 03-25-2012, 05:51 PM   #114
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
Like Rob said above,from the print out I would expect to find a bent left strut and posible upper strut mount.The damaged parts need to be replaced before any alignment is done.I would ask for a different tech to make the repairs.They don't need a frame rack to fix your car,just someone that knows what they are doing.
Bruce@raymondsperformance is offline   Reply With Quote
Old 03-25-2012, 06:28 PM   #115
CamaroBC
CamaroBC's Avatar
Drives: Cyber Grey 2LT RS Coupe
4. yes
I know I am concerned with the strut, but I have no intentions of letting those dolts work on it. I cant trust them. But I have to address their wrongs doings now, so they can rectify the further misalignment they purposely caused. They never even claimed there was a strut problem. So getting them to work on it, and take responsibility for their lack of pointing that out seems like a pipe dream.
http://AllsportsTees.Com
http://allsportstees.spreadshirt.com...shirts-C110728
http://allsportstees.blogspot.com/
Cyber Grey 2LT, RS. Car was bought this way: Painted Black 20" rims, Red Calipers, Flowmaster AxelBack Exhaust, everything DEBADGED! Bowties painted black bass speakers from Chrysler, Defenderworx Chrome Pistol Grip Shifter, underglow LED's installed not functional,Rally Stripes.
CamaroBC is offline   Reply With Quote
Old 03-25-2012, 07:28 PM   #116
CamaroBC
CamaroBC's Avatar
Also, In your assessment of the strut issue I was able to produce a noise just by pushing down on the one side of the car, as opposed to the other sides no sound. Im just shocked that lack of knowledge happened at my dealer shop.
Thanx again.
Old 03-25-2012, 11:26 PM   #117
Info@PeddersUSA.com
Just remember, all dealership are just like every other garage.
They have high end people, and low end people, it's just simple economics.
The big problem i see if that if the right tech doesn't get the right job, or the the right support.
Just explain your issue to the service adviser and if you feel your not getting anywhere ask for the service manager.
Old 03-28-2012, 01:58 PM   #118
chopss
chopss's Avatar
Drives: 04 sentra, 2ss
Hi I'm getting a alignment stock suspension, all season tire just need help on rear to make sure my SS well at a strong launch
Front camber -.8
Front toe 0
Rear camber -.3
Rear toe .10 or .05 which is better
Is this a proper set up for the rear?
chopss is offline   Reply With Quote
Old 03-29-2012, 11:40 PM   #119
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Front camber -.8
Front toe 0
Rear camber -.3
.10 per side will work well for you.
Old 04-12-2012, 12:57 PM   #120
Jshadow
31B MP
Jshadow's Avatar
Drives: 2010 1SS CGM Camaro
Send a message via AIM to Jshadow Send a message via Yahoo to Jshadow
Ok i'm a noob when it comes to suspension and alignment so hope you guys can help. I just dropped my 2010 SS 1" with Eibach Pro and also added some Eibach sways. I know i'm supposed to get a realignment now correct even though i have sways? If so what specs should I recommend? Sorry if this has already been addressed I don't know how to read all those numbers :/.
BTW this is my daily driver on stock tires.
2016 Red Hot 2SS soon....
Jshadow is offline   Reply With Quote
Old 04-12-2012, 02:48 PM   #121
Here are the newest FE2, FE3, FE4 and FE5 OEM and Pedders Alignment Specs.
Bush Timing
Step 1. Lift the car on a two post lift and raise it.
Step 2. Loosen the following bolts/nuts:
Front:
---Inner Control Arm Bushing
---Inner Radius Rod
Rear:
---Trailing Arm Bushings (both ends)
---Toe Rod Bushings (both ends)
---Lower Control Arm Bushings (Inner)
---Upper Control Arm Bushings (Rearward)
---Lower Strut Bushings
Step 3.
Lower the car and drive it around the parking lot SLOWLY and on to the alignment lift.
Step 4.
With the weight of the car on the wheels tighten all of the nuts/bolts to spec.
Step 5.
Align the car at the new ride height.
Here is the alignment specs for you and have the bushings timed before the alignment is done.
Old 04-12-2012, 09:05 PM   #122
Jshadow
31B MP
Jshadow's Avatar
Wait is that for me? And do i just bring them those pdf's and they do the rest lol?
Old 04-13-2012, 08:53 AM   #123
If you take These specs to the alignment shop they should be able to get your alignment where it needs to be.
Old 05-04-2012, 06:35 AM   #124
ThrasherJP1984
ThrasherJP1984's Avatar
Drives: 2011 CGM V6 Camaro
I could use some help too.....I have the BMR split drop springs im about to put on and i also have the rear SS shocks so that the springs will fit properly. its a daily driver and i just would like the best overall performance and wheel wear???? Thanks guys
ThrasherJP1984 is offline   Reply With Quote
Old 05-31-2012, 10:06 PM   #125
iceman5730
Iceman
iceman5730's Avatar
Drives: 2011 Camaro 2LT SC/RS CGM
I too need advise I just installed Eibach Pro kit sway bars/lowering kit and have poly subframe bushing It is a V6 RS. Stock tires. What should the setting be for use as a daily Driver with an aggressive foot/ maybe track 1 time a month.
Thanks
iceman5730 is offline   Reply With Quote
Old 06-05-2012, 06:09 PM   #126
JusticePete
Thanks
I suggest aggressive street sir.
Bush Timing
Front:
---Inner Radius Rod
Rear:
Step 3.
Step 4.
Step 5.
Definitive GT500 Thread garagelogic Chevy Camaro vs... 98 02-12-2010 01:14 PM
Lets start a Tire Specific Thread here, sizes, brands, specs and other usefull info. 55Designs Wheels and Tires Talk Sponsored by The Tire Rack 0 12-20-2009 07:58 PM
Suggestion: Explanation to thread starters for their threads being locked? colin911 Site Related Announcements / Suggestions / Feedback / Questions 2 12-06-2009 10:25 PM
Dealer Praise Thread (Not an Idiot!) RPO_Z28 Camaro Price | Ordering | Tracking | Dealers Discussions 84 06-25-2009 01:00 AM
prices thread nimnels 5th Gen Camaro SS LS LT General Discussions 1 05-02-2009 06:47 PM
