Old 03-19-2010, 05:20 PM   #1
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
Amp install kit
Just as it says, what are some good recommended amp install kits?
I also see items by Streetwires like the compression fitting ring connectors, are they worth a darn?
Also if the amp takes 4 gauge for power would moving to 2 gauge fit without a distro block?
Cheers
K
Moriartii is offline   Reply With Quote
Old 03-19-2010, 05:25 PM   #2
mrray13
mrray13's Avatar
Drives: 2010 1LT RS Rally Yellow
They make adaptors to go from 2g to 4 g, or you can trim, or add a distro block. I'd get the step down adaptors if you wanted to run 2g.
Stinger, Streetwires, Kicker, Memphis, Audiopipe are several off the top of my head. RF has their own as well. Ebay amp install kits, you'll find some nice pricing there. Also, strand count is the important. The higher, the better.
PacMan
mrray13 is offline   Reply With Quote
Old 03-19-2010, 06:31 PM   #3
Moriartii
Moriartii's Avatar
Would you recommend running a larger gauge power/ground than the recommend 4 gauge that SD mentions in their install manual?
Cheers
K
Old 03-19-2010, 06:40 PM   #4
mrray13
mrray13's Avatar
If all you are going to run is the single amp, and as short as the power run is going to be, 4g should be more then enough. That said, it doesn't hurt to go a little bigger, but in this case, with ~400wrms, it isn't necessary. If our battery was under the hood, eh, maybe bigger would be better. As it is, I doubt it.
PacMan
Old 03-19-2010, 08:51 PM   #5
Racer-X
Rhymin and Stealin
Racer-X's Avatar
Drives: The Search is on ABM V6.....
Send a message via MSN to Racer-X
We use Stinger HPM exclusively in our shop primarrily because it is very flexible (makes a difference some times) and the high strand count of the coppper also be wary of copper coated aluminum (this is found in the cheaper kits. also be careful of the cheaper kits that will be more of a 6 ga. wire with lots of extra insulation to give you the illusion of proper gauge wire. Stinger HPM and PRO the better street wires stuff the better kicker wire ect are all good stuff.
Bryan
I Make Cars Sound Good.
Enchantment Editions
Arc Audio Competition Team
Image Dynamics Elite Sound Performance Team
Team Stinger
Racer-X is offline   Reply With Quote
Old 03-24-2010, 10:38 AM   #6
Moriartii
Moriartii's Avatar
Ok I have another question, I want to run my amp power wire along the battery power wire. It this ok? Basically I want to zip tie the amp power wire to the orange battery wire in the camaro.
Cheers
K
Old 03-24-2010, 11:04 AM   #7
Racer-X
Rhymin and Stealin
Racer-X's Avatar
like this?
yeah it is perfectly ok. will not affect anything.
Bryan
Team Stinger
Old 03-24-2010, 11:10 AM   #8
CAMARO_MOW
CAMARO_MOW's Avatar
Drives: 2011 White 2SS/RS
IAS -- What install kit it that power cable from? Looks nice and clean!
2SS/RS Summit White with IOM Stripes and IOM Interior, Hurst Shifter....
CAMARO_MOW is offline   Reply With Quote
Old 03-24-2010, 11:18 AM   #9
Moriartii
Moriartii's Avatar
Yeppers just like that!
Cheers
K
Old 03-24-2010, 01:12 PM   #10
Racer-X
Rhymin and Stealin
Racer-X's Avatar
That is the Stinger HPM line of wire kits.
Bryan
Team Stinger
Old 03-24-2010, 01:14 PM   #11
CAMARO_MOW
CAMARO_MOW's Avatar
Thanks, that is what I was planning on getting too.
Old 03-24-2010, 01:19 PM   #12
Moriartii
Moriartii's Avatar
IAS-
Do you let the fuse holder hang free or is it mounted somehow? Also how do you ground the amp when you install?
Cheers
K
Old 03-24-2010, 01:47 PM   #13
Racer-X
Rhymin and Stealin
Racer-X's Avatar
we ALWAYS mount our fuse holders. this one is screwed to the metal of vehicle.
the grounds for these amps are done to the floor behind the amp rack... wire wheel to the paint to give us bare metal then pre-drill our hole and usually use a #10 screw and Star washer. then we will silicon over the ground point to prevent rusting.
Little hard to see in the pic as the wire for the subs is hiding it but the grounds are there.
Bryan
Team Stinger
Official Victory Racing Turbo Kit Post VictoryRacingEngines Forced Induction 44 07-26-2010 01:45 PM
ULTIMATE PERFORMANCE* TURBO Camaro SS -- 750hp Custom Single Turbo Kit (T04Z) Ultimate Performance Forced Induction - V8 496 10-11-2009 01:29 PM
What would you spend for a NAVI/DVD install kit Mohrg Beast Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 7 10-01-2009 12:42 AM
PLZ INSTRUCTION HOW TO INSTALL AMP AND SUB Terrellford12 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 14 07-03-2009 06:17 PM
