Old 03-19-2010, 10:55 PM   #1
OSearcy4
OSearcy4's Avatar
Drives: 2010 Camaro
DIY "CAMARO SS" door to ground LED projection
Here is a short how to on installing this kit.
These panels are very bright and can be used in multiple applications.
For starters here is the finished product
1) Remove Door Panel
2) When you remove screws the door panel pops straight out. Its held in by pop rivets here is a link to a video with more details.
3) Now you need to draw outline for the cutout.
4) After cutting it out and mounting the box it should look like this. If you notice you have to cut that foam in half and you also have to cut off the place were it was held on where the box is.
5) Now you need to wire up the light to come on with the dome light. You have to tap into the gray wire in the pic. Its located right above the gas pedal.
6) Now you need a ground, look behind this panel.
Ground here
7) Now run both wires through the hole near the fuse box, just for easy access.
8) After you put the door panel back on run the wires across this inside of the panel and out near the speaker, this is the best I could get it to look without digging into the wire connection which was way to much for me. I'm not worried about this showing honestly.
9) Now after you connect everything together and screwed the door panel back on here's the final result.
Any questions email me at OSearcy4@aol.com
OSearcy4 is offline   Reply With Quote
Old 03-19-2010, 10:57 PM   #2
ron10
Drives: 2010 2SS IOM L99
nice
Old 03-19-2010, 10:59 PM   #3
Camaro21
Drives: SOLD - 2013 M6 ZL1
Nice Writeup.. Thanks
Camaro21 is offline   Reply With Quote
Old 03-22-2010, 11:23 AM   #4
Chewy
My boredom isn't safe
Chewy's Avatar
Drives: 2010 SS Camaro
Send a message via AIM to Chewy Send a message via MSN to Chewy
nice write up bro, i asked one of the mods what happened to my DIY and i havn't heard back yet.
Chewy is offline   Reply With Quote
Old 03-22-2010, 12:30 PM   #5
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
I'm fairly sure these projectors are not licensed by GM to use the Camaro or SS symbols.
The mods will probably have to delete this DIY.
Old 03-22-2010, 01:11 PM   #6
cool
Old 03-22-2010, 03:21 PM   #7
montej23
montej23's Avatar
Drives: 2011 VR Camaro
nice write up but its very dim it would be better if it was bright
montej23 is offline   Reply With Quote
Old 03-22-2010, 11:53 PM   #8
OSearcy4
OSearcy4's Avatar
Drives: 2010 Camaro
just ordered some new LEDs and I'm gonna test them next week. Its not really that dim just hard to take a good pic, however these new LEDs are supposed to be the brightest single light possible around 85 lumens.
Comparable to most LED flashlights with 5 LED pods which shine around 40-60 lumens.
They are supposed to be so bright its not recommended to look directly into them.
I ordered them and told the manufacturer that I wanted them so bright they show up in the day. So we will see I will update pics when I finish the modifications.
Old 03-22-2010, 11:55 PM   #9
Ivan @ Southwest Speed
QUICK!!! CUT AND PASTE EVERYTHING!!!
ROFLMAO,
Ivan
Old 03-23-2010, 12:00 AM   #10
OSearcy4
OSearcy4's Avatar
Drives: 2010 Camaro
why?
Old 03-23-2010, 12:02 AM   #11
OSearcy4
OSearcy4's Avatar
Drives: 2010 Camaro
Oh also more details on the new LEDs:
common LEDs have 5-20 mA
these are rated at 700-750 mA
Hopefully the change will be extremely noticeable.
Old 04-02-2010, 04:50 PM   #12
montej23
montej23's Avatar
so do we have a update on brightness of the projected embolm
Old 04-02-2010, 05:25 PM   #13
OSearcy4
OSearcy4's Avatar
Drives: 2010 Camaro
still waiting on the new LEDs to come in...
Old 04-02-2010, 05:44 PM   #14
Legend
Hello!
Legend's Avatar
Drives: 2008 JSB Z06!
That's cool!
Legend is offline   Reply With Quote
DIY - Footwell LED lighting In tune with Dome Light markmass Camaro DIY & HOW-TO instructions & discussions 52 09-03-2010 08:00 PM
