Gen5DIY
Old 03-20-2010, 01:05 PM   #1
Inferno2SS
Inferno2SS's Avatar
Drives: 2010 IOM 2SS/RS
Novice Header Question
Would someone mind explaining to me the difference and benefits of these 2 different ARH LT headers? I am looking to try to add around 50 HP and am planning to add a CAI, headers and a tune. But want to make an informed decision and am still confused after reading other header threads.
I dont care as much about the loud or deeper sound I am happy with the way the car sounds now but would like to add a little more pep and improve the handling. Am also planning to do the Pfadt Sport Suspension Package to improve handling.
American Racing 1-3/4 Headers + X Pipe + cats for 2010 CAMARO
http://jreperformanceparts.com/gm/20...10-camaro.html
2010 Camaro ARH Long Tube Headers 1-3/4" x 3" Conn With/Cats
http://jreperformanceparts.com/gm/20...-cat-back.html
Inferno2SS is offline   Reply With Quote
Old 03-20-2010, 01:17 PM   #2
flyby
Drives: 2010 Silver SS
the 3" is to conect up to aftermarket 3" pipe for axle back. Make sure what you need if you have already gotten an axle back installed. If not I'd go with the complete system from ARH
flyby is offline   Reply With Quote
Old 03-20-2010, 01:47 PM   #3
Inferno2SS
Inferno2SS's Avatar
I guess part of what I am asking is, is it worth the extra $450 to get the full system as apposed to using the stock system from the cat back? Is there a performance advantage and is it worth the extra $450?
Old 03-20-2010, 03:22 PM   #4
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
The first system goes all the way back to the axle, 3" all the way there. You mate it up to your factory pipes there, it goes down to 2 1/2" to match up. If you like the factory sound now then you will be happy. I had my car this way for a month or so before going to magnaflows and 3" all the way. The factory mufflers are a fairly straight through design, changing them is mostly for a more aggressive sound under acceleration. That second system looks like it mates up to the factory system after the cats, which means you will have 2 1/2" from there and the factory H pipe and not the ARH 3" X pipe. I would recommend the first system, I love mine, Easy install and quality workmanship. Good luck.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 03-20-2010, 04:44 PM   #5
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
An exhaust only flows as well as the narrowest point. If there's 2.5in from the axle back, you'll gain nothing, in terms of performance. Probably not much to be had from going all 3in anyway. The sound may be different though. I'd also suggest you go with the 1 7/8 headers as they've been shown to give more HP over the 1 3/4. The 2in version also shows a slight gain over the 1 7/8. It comes down to price and preference.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 03-20-2010, 11:17 PM   #6
alfie43
alfie43's Avatar
Drives: S/C 2SS/RS Camaro-6M-VicRed
Location: Alfie (Mariano) lives in Shelby Twp, Metro-Detroit
Send a message via ICQ to alfie43
If want a 45-50 hp gain and you are not interested in spending money for the sake of changing the sound, go with the second system that you listed, i.e., LT headers with high flow cats that connect directly to your stock exhaust system.
It has been shown time and time again that all the power gains are forward of the cats. Modifications from the cats back provide minimal power increase, if any. They are only for sound improvements (?).
I got 45-50 hp from Kooks LT headers with high flow cats, a CAI, a dyno tune with a stock exhaust behind the cats.
http://www.camaro5.com/forums/showthread.php?t=62200
The headers and CAI did change the sound of my car. To me, my car sounds awesome ...especially on wide open throttle. How an exhaust systems sounds is very subjective and personal for each individual.
My car has absolutely no drone...it doesn't sound like I'm in a 4 engine WWII bomber when cruising on the freeway, but when I hammer it ...WOW!
Alfie
alfie43 is offline   Reply With Quote
Old 03-21-2010, 12:19 AM   #7
Inferno2SS
Inferno2SS's Avatar
Alfie, sounds like you have done exactly what I am looking to do, add some extra power without getting too loud. Best of both worlds, quiet when cruising and like a beast when WOT.
Those are some great dyno numbers you got there. I will have to keep my fingers crossed I can get something close to that.
Thanks for the feedback.
Mike
Complete ******** install from a Novice Susantroy1 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 63 07-31-2015 02:25 PM
question about LT header codes-- AdamCzap Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 03-08-2010 06:29 PM
Header question brtaus Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 02-26-2010 04:35 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 07:53 AM
LT header and exhaust question upstateny Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 02-02-2010 10:23 PM
