JDP Motorsports
Old 03-21-2010, 11:04 AM   #1
StrictlyPro
Sky Soldiers - Airborne
StrictlyPro's Avatar
Drives: 2010 White Camaro SS
Sumping the Tank?
Trying to figure out a fuel system solution for the 900-1200rwhp range. What issues would I be looking at by placing welding in a sump tank and running an Aeromotive Eliminator?
I've never had problems on older fox body mustangs, but not sure how deeply wired the fuel systems goes into the computer. Tried searching for some of the early fuel issue threads, but they were discussing the 600-800hp range which is easily solved with dual pumps.
Strictly Performance
SS M6 - Numbers Soon
Vortech YSI Kit
416ci Forged Shortblock
LMR Cold Air Intake
Thunder Racing Lethal Z Cam
Kooks LT Headers
Walker Bullet Exhaust
StrictlyPro is offline   Reply With Quote
Old 03-21-2010, 11:10 AM   #2
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
factory tank is plastic,, you would need to fab up a different tank,, then just turn off all the fuel pump module codes in the ecm and run your own fuel system,
Old 03-21-2010, 11:18 AM   #3
StrictlyPro
Ya right after posting this I found an article on another site saying the FPCM could be turned off with no ill effects.
Rgr on the plastic tank lol.
Vortech YSI Kit
LMR Cold Air Intake
Kooks LT Headers
1/4 tank or full tank of gas when storing Car Phil Oliver 5th Gen Camaro SS LS LT General Discussions 40 09-28-2012 09:10 AM
miles to the tank? bokoo 5th Gen Camaro SS LS LT General Discussions 36 12-29-2009 10:37 PM
trouble shoot this MadMatt 3rd Generation Camaros 2 10-02-2009 02:07 PM
Has anyone filled their tank yet trudawg660 5th Gen Camaro SS LS LT General Discussions 9 05-23-2009 04:25 PM
Fuel pump or bad tank of gas? Boomer Sooner 4th Generation Camaros 25 01-02-2009 07:34 PM
