Old 03-21-2010, 12:00 PM   #1
Geoff131
Geoff131's Avatar
Drives: 2010 camaro ls
What is a “Disco Potato” Turbochargers!!!
I need help with this question. What is a “Disco Potato” Turbochargers. I have no idea what it is, but I am getting recommend that I use it. I just need information on it and I can not find any information on what it is and how it works anybody who knows a link or knows about please help me out and tell me what is it.
Geoff131 is offline   Reply With Quote
Old 03-21-2010, 12:46 PM   #2
Mr Twisty
Mr Twisty's Avatar
http://www.turbobygarrett.com/turbob...S_739548_1.htm
Too small.
You have a V6... I would sit back and wait till aftermarket puts a kit together.
-- Benjamin Franklin
Old 03-21-2010, 02:38 PM   #3
Fritostud
Drives: 2008 Suzuki Hayabusa2010 2SS/RS M6
looks like a turbo for a Hayabusa, not a Camaro!!
Fritostud is offline   Reply With Quote
Old 03-21-2010, 08:19 PM   #4
mike25
mike25's Avatar
Drives: 2012 Camaro 2SS/RS
i would start with any less than gt30r's if your doing a twin setup. a gt35r would be a good starting point for a single setup.
2LT/RS M6 CGM VIN#53104 SOLD
2012 Black 2SS/RS w/ Hurst-
Mods:
Corsa catback, SSE, Vararam
mike25 is offline   Reply With Quote
Old 03-22-2010, 07:41 AM   #5
Geoff131
Geoff131's Avatar
Reason I ask is someone I know has a “Disco Potato” Turbochargers! (twin turbo I think. He set it up in a mustang gt for a dealership for a promotion. Long story short the dealership didn't want it and he has it and in addition the dealership didn't pay him for his time. So he is willing to sell for $2500 for the twin turbo so that is why I am asking. So feed back will really help in my descision if I should get it or not.
Old 03-22-2010, 01:12 PM   #6
SSambumbia
Drives: 2ss/rs black/black
Turbos, specially twins, are not something that you throw into the engine compartment and poof, it's done. To install these you need cold pluming and hot pluming, intercooler, fuel management, etc, etc, etc. It is taking months for companies that do this for a living to come up with a complete kit, it is very labor intensive. Too much room for error. Save your money for a tried and tested complete kit. Or you might end up with some pretty expensive paperweights.
SSambumbia is offline   Reply With Quote
Old 03-22-2010, 01:19 PM   #7
2010 2-Tone
2010 2-Tone's Avatar
Drives: 2010 RY 2SS with Custom Stripes
Don't do it!!! You will end up spending alot of money trying to get it right. It is NOT a good deal. Wait and get the entire package from a good company that has done their research and has all the componets along with step by step instructions if you are going to do the install.
2010 2-Tone is offline   Reply With Quote
Old 03-27-2010, 01:25 PM   #8
Team STILLEN
Team STILLEN's Avatar
Drives: Varies
I actually worked directly with Garrett on the twin GT28 (disco) kit and the twin GT30 kits. The kit your friend has is JUST THE HOT SIDE. the cold side and engine management portion is an extra $3500 to $5500 depending on what options and fuel mods you go with. Trust me when I say this kit is not for the average joe technician either. Here is the completed kit......
http://the-perfect-exposure.blogspot...tang-gt-w.html
Scroll down and look at the tubing we had to design and you can see what it is going to take to get those on. Plus the battery reloc, fuse box and ECU reloc, and vapor management was a PITA. making for a 20+ hour install for the system.
Just FYI, anyone saying you cannot get REAL horsepower from the Disco Potato doesn't know anything about turbos. This kits can make over 700 wheel and has full boost at less than 2100RPM!!!!
Team STILLEN is offline   Reply With Quote
Old 03-27-2010, 05:29 PM   #9
cool
Old 03-28-2010, 08:38 PM   #10
Geoff131
Geoff131's Avatar
Thanks for the info like I said I just needed information on it. The person I go to is a very good trained tech that I got recommend to. He has a shop down in south jersey and mostly works on mekurs. He said he was going to give the whole kit for about 2500 because he got screwed by a dealership. The other reason why he is selling cheap is because if I decide to go with it he can use me as a advertisement. The install will be another cost, but I just wanted to if it will be worth it in a long run to get it. So any help will be good.
Old 03-31-2010, 02:57 PM   #11
Geoff131
Geoff131's Avatar
Just found out it was a garrett gt 28 rs turbo.
Old 03-31-2010, 08:47 PM   #12
Ronin_2SS
Loving My LS3
Ronin_2SS's Avatar
Drives: 2010 Summit white 2SS
Send a message via Yahoo to Ronin_2SS
as most have said its a garret gt28 rs turbo. alot of MR2 owners have used them to swap out the stock ct26 along with supra owners to replace the ct12's. quick spool pleanty of breath through out the rpm range. its a great turbo. if done right a twin gt28 rs can support 500+hp easily.
Ronin_2SS is offline   Reply With Quote
Old 04-01-2010, 04:34 PM   #13
radarwz
Boost All the Time!
radarwz's Avatar
Drives: 2005 pontiac GTO Twin Turbo
I have the GT-2871r's on my GTO. Each turbo's is rated @ 4.0L max. They make good power and spool quickly. They are expensive. That's why APS only made a few of the kits like mine. But because they have internal waste gates they are simpler to fab up. One of these or a 30/35 with the int. w/g housing would be simple pkg to build. Just think of the Fastlane kit adapted to a V6.
'05 GTO Blk/Blk, APS gen1 Twin Turbo, forged WRE 370ci, PerformaBuilt Stage 3 A4, Tuned by NicD - 10.89 @ 133 mph
'06 TBSS Black, Pacesette LT's w/catless mid, Efans, NicD tune and 4.10's!
'56 Chev Belair 2dr sedan, Wht/blk, 265 pwr glide.
'56 Chev 3100 p/u Black, 400 v8 3spd on the tree.
radarwz is offline   Reply With Quote
Old 04-08-2010, 12:34 PM   #14
merritr
GM Enginerd
Drives: Cyber Grey 2LT RS
This is my first post, I should probably make a more formal introduction, but that will have to happen later. The disco potato story is a good one. It is a legend that will be retold to future generations or maybe that is just in the circle of friends I keep... Anyway here is the gist of the tale:
http://www3.sympatico.ca/mr2sc/disco_potato.html
Now many of the parties that gave the disco potato its days in the spotlight are busy with new projects. The website MotoIQ.com is where they document their endeavors.
I just received my Cyber Grey 2LT Camaro last week. It will be the Moto IQ Project Camaro. The plan for it is to explore the potential of the V6. It will get the twin turbocharged treatment eventually. The goal is going to be to maintain the best efficiency and everyday drivability while milking the most performance.
merritr is offline   Reply With Quote
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 256 11-18-2016 07:50 PM
