SDPC
Old 03-21-2010, 02:11 PM   #1
Fritostud
Drives: 2008 Suzuki Hayabusa2010 2SS/RS M6
Cam install questions
I've got my car torn down almost all the way for my cam install, and was wondering about the AC belt.
Is there a certain way to get it off, or does it just come off when you pull the crank pulley??
Also putting new valvesprings in, and need to know the torque specs on the rockers!!
Any help on this will be greatly apprciated!!
Fritostud is offline   Reply With Quote
Old 03-21-2010, 09:24 PM   #2
ThunderSS
ThunderSS's Avatar
Drives: 2010 CGM 2SS/RS
Cut the belt off, and buy a new one.. It's the easiest way.
You most likely end up tearing the old one up trying to get it off.
Rocker arms are torqued to 22 ft. lbs.
Hope this helps you out..
Daniel
2010 Camaro SS/RS HKE Forged 416 CID
http://www.fquick.com/ThunderZ28
510 HP/485 Ft. Lbs
ThunderSS is offline   Reply With Quote
Old 03-21-2010, 09:50 PM   #3
DaveT
DaveT's Avatar
Drives: 2010 2SS CGM LS3
Daniel
Really??
How does the new one go on?
DaveT is offline   Reply With Quote
Old 03-21-2010, 10:06 PM   #4
Scourage
Syntax Error
Scourage's Avatar
Drives: 2010 Camaro 2SS/RS
When I bought my new belt from GM, they included the tool for install.
Scourage is offline   Reply With Quote
Old 03-21-2010, 10:19 PM   #5
techsupport
Drives: 1ss, heritage grille cfh perf. mods
price that belt before you cut!!!! i seem to remember it is outrageous. the easiest way i have found and done before, it takes a little time but remove front ac compressor bolts fully and then slowly loosen rear ones to relieve tension. install in reverse fashion. either way get a price on that belt trust me
techsupport is offline   Reply With Quote
Old 03-21-2010, 10:41 PM   #6
playadam
Drives: anything lsx
yeah it is almost impossible to get the belt off without dropping the engine (which I did) and you can fight the a/c lines and bend the a/c enough to pry it off and then back on...Good luck if you are going to fight the A/c without dropping the engine, you will problally have to loosen the ac lines that run under the balancer that are attached on the frame rail for any chance of movement.
playadam is offline   Reply With Quote
Old 03-21-2010, 11:24 PM   #7
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
When I picked my car up the belt slipped off the same day. I noticed I had no AC and when I popped the hood to show someone the engine we saw the belt dancing around. I took it to the dealer right away and they printed up the tech info that said it needed to be cut and replaced with a new belt. There is no tensioner so they are a one shot deal.
9/26/09 Took delivery!
Old 03-22-2010, 01:06 AM   #8
Ivan @ Southwest Speed
Job Security! lol
Shitty deisgn...but it's true.
-Ivan
Old 03-22-2010, 12:36 PM   #9
Fritostud
Thanks Guys..Looks like I will be cutting it off!!
Old 03-22-2010, 12:47 PM   #10
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
just use a small pry bar while you rotate the engine over with a ratchet,, i have had mine on and off several times with no issues
also snap-on/blue point make a tool for this but i havent seen the need yet since it is very easy to remove and install without a special tool
DIY : Install headers on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 66 01-18-2017 12:47 PM
DIY : Install Performance Swaybars in 2010 Camaro Nine Ball Camaro DIY & HOW-TO instructions & discussions 17 09-14-2015 12:36 AM
Engine Reduced Power- After Cam Install E85LSX Tuning / Diagnostics -- engine and transmission 16 01-04-2011 01:31 AM
LG g6x3 or Super Charger Cam!!! Your Thoughts Mr. Brownstone Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 01-24-2010 01:45 PM
