Old 03-21-2010, 06:56 PM   #1
lakersftbl69
lakersftbl69's Avatar
Drives: 2010 camaro 1ss/rs
engine light!!!
hey everyone just want to see what everyone thinks about this. i had my camaro tuned this past wednesday the engine light was on because whoever put the headers in didnt do it rite. the passenger side sensor was no good. on friday i took it to the mechanic to put a new sensor and change the spark plugs, everything was well after. i drove yesterday all day and it was fine. i took it out today and just coming home now the engine light goes back on. i just want to see whats everyones thoughts on possibilities of what it could be.
lakersftbl69 is offline   Reply With Quote
Old 03-21-2010, 08:25 PM   #2
Soundwave
Soundwave's Avatar
Drives: Camaro SS(2)/RS
Either get yourself some sort of OBD II reader or go to auto zone an they'll pull the code
for free and tell you exactly whats going on. Don't long tube headers get rid of the cats? If so your probably throwing the "cat not warm enough code" because you don't have any.
Soundwave is offline   Reply With Quote
Old 03-21-2010, 08:38 PM   #3
Autobot
More than meets the eye
Autobot's Avatar
Drives: 2SS RS M6 V.R. & 2006 Jetta TDI
take it back to the tuner
LT Headers will sometimes throw a code (mine did) the tuner just needs to plug it back in and reprogram for the LT headers.
Autobot is offline   Reply With Quote
Old 03-21-2010, 08:47 PM   #4
MrGazinya
MrGazinya's Avatar
Drives: Aggressive
I did KOOKs longtubes and had a custom tune by Jannetty racing via Diablo and couldn't be happier. No CE lights
Black 2SS RS LS3 Inferno Int. Powdercoated 20's {MODS} KOOKS LT: Borla S-Type: Roto-Fab CAI: Hurst ST.: PFADT Stage 2, Trailing arms, Tie Rods: ECS BigBlower Cam: Fast 102mm intake: Brian Tooley racing dual spring kit: TFS pushrod set: Katech C5R timing chain: Mellings high volume oil pump: ATI Balancer: Tuned by Doug Ring at ECS. 472RWHP/445RWTQ.Dynapack Dyno.
MrGazinya is offline   Reply With Quote
Old 03-21-2010, 09:34 PM   #5
Slowhawk
Drives: 1999 Trans Am
Just bring it to me to scan.Could easilly be a left over code from the not working 02 it had before.
Slowhawk is offline   Reply With Quote
Old 03-21-2010, 10:11 PM   #6
lakersftbl69
depending on the weather is there anyway i can bring it this wed at around 3-330 i gotta work lunch. how much will i need to bring?
Old 03-21-2010, 11:30 PM   #7
themossman
Apprehensive Optimist
themossman's Avatar
Drives: '10 SS/RS SIM
whoever did the tune should be looking at it and fixing it.
Car is for sale --->http://www.camaro5.com/forums/showthread.php?t=158486
Current Summary:
Engine:Phase One-(All work by Vengeance Racing): Custom Cam, AR Headers, ported throttle body, ported intake, custom tune, dual valve springs, hardened push rods, under drive pulley, thermostat, Vararam CAI, C5R timing chain, Melling oil pump catch can, breather, MagnaFlow Sport Axle Back
Suspension: Pfadt Sport Sway Bars, Pfadt drop springs
Other: MGW Shifter, Custom Paint
my build journal ---->http://camaro5.com/forums/showthread.php?t=30057
themossman is offline   Reply With Quote
Old 03-22-2010, 06:14 AM   #8
Slowhawk
There's no $$ involved to scan it ect. Call me,alot easier.
Old 03-22-2010, 06:19 AM   #9
Slowhawk
Yes he should but the person that tuned it spent alot of time fixing another shops bad install that resulted in 25% more fuel getting dumped into 1/2 the motor for pretty much free.Then still will go over the tune again after all the plugs are changed and the new 02 sensor is in there. -for free.
I'm thinking the tuner is pretty nice.... LOL
(yes,we tuned it)
Old 03-22-2010, 09:01 AM   #10
themossman
themossman's Avatar
(yes,we tuned it)
Agreed...the tuner is pretty nice...
Good luck!
Current Summary:
Hot air Intakes -By Kenne bell ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 66 02-08-2011 09:33 PM
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
LLT engine specifications Tran Wiki 2 03-29-2010 11:06 AM
List of Intakes that will work with the TVS-2300 MagnaCharger JJ2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 03-19-2010 03:11 AM
Pfadt Race Engineering releases new Camaro V8 Engine Mounts PfadtRacing Suspension / Brakes / Chassis 6 01-15-2010 01:58 PM
