BORLA
Old 03-23-2010, 10:07 PM   #15
lrc250
480 HP 2010 2SS
lrc250's Avatar
Drives: 2010 Camaro 2SS
Originally Posted by SSMickey View Post
Does anyone know what the VIN range of the affected cars is, or is this an across the board concern?
I don't know the range but I can tell you mine appears to fall in it and my VIN is 7470. This past weekend I noticed my oil pressure dropped to just above the the zero mark on the oil pressure gauge on the 4-pack while idling. At cruising speed it still only registers ~ 25 pounds. I carried it by the dealer today and they said did you get a low oil light come on and I replied no and he said it is probably nothing then. I told them it is either low pressure or a bad gauge, I don't know which it is but they are going to fix it.
Without data you are just another person with an opinion.
1100 :10/15/08
3000:3/2609
3300:4/18/09
3400 (broadcast)April 25, 2009
3800 (produced):May 4, 2009 #7470
4200 (Shipped): June 1, 2009
5000 (At Dealer) June 9,2009
374.9 rwhp & 371.7 rwtq - bone stock @ 85 deg.
lrc250 is offline   Reply With Quote
Old 03-24-2010, 12:30 AM   #16
firestone_ss
firestone_ss's Avatar
Drives: 2010 camaro ss
i believe this affect more vehicles than camaro,that would probably mean its not vin related,just my two cents doesnt mean im not curious for more info tho
firestone_ss is offline   Reply With Quote
Old 07-16-2010, 08:20 PM   #17
acowherd
acowherd's Avatar
Drives: 2010 2ss/RS 4l80. 2009 2500 HD
Had this happen to me...New oil pump on the way!!!
Follow along as we build and race this 2010 Camaro!
https://www.facebook.com/pages/FNSS-...75028626000379
FNSS Racing!
acowherd is offline   Reply With Quote
Old 07-16-2010, 08:47 PM   #18
2L82RUN
2L82RUN's Avatar
Drives: ABM SS/RS
Did this happen on your way to Cincy??!!
2L82RUN is offline   Reply With Quote
Old 07-17-2010, 05:23 AM   #19
acowherd
acowherd's Avatar
Thankfully I was already in cincy when it happened at the hotel.
FNSS Racing!
Old 07-17-2010, 09:00 AM   #20
Merc
In The Circle
Merc's Avatar
Originally Posted by thiggin2 View Post
It's not a bulletin, its a PI - PIP4158C.
What's a PI?
Old 07-17-2010, 09:18 AM   #21
Qwkss
Qwkss's Avatar
Drives: Hoopty Winter Beater
In deed. Its on the lift and HOPEFULLY will be finished up today!!
We talked to a GM tech and he said a TEMPORARY FIX: Fire the Car up and DEAD REV it to get the Oil Pressure to UN-Stick the plunger. If the oil pressure comes back, you should drive the car Home, or to your local dealer as it will probably/WILL get stuck again.
Qwkss is offline   Reply With Quote
Old 07-17-2010, 09:22 AM   #22
shevyman
Drives: 2010 Camaro SS IOM
damn i have seemed to notice that ford and chevy have THE most tsb out there. hahah
ok sorry for that. well thank you for letting us know. when i get my car back, that will be another thing to have checked or fixed.
shevyman is offline   Reply With Quote
Old 07-17-2010, 09:35 AM   #23
venice17517
venice17517's Avatar
Drives: 2010 Camaro
PIP4786: Low Oil Pressure Message Light - Inspect Valve Lifter Oil Filter - (Apr 5, 2010)
Subject:Low Oil Pressure Message/Light - Inspect Valve Lifter Oil Filter
Models:2007 Cadillac Escalade
Built before April 1, 2006 with 6.2L L92 Engine
(These engines were built with AFM Hardware but the AFM system was disabled.)
2009 Buick Lacrosse Super, Allure Super (Canada Only)
2005-2007 Buick Rainier
2010 Chevrolet Camaro SS
2007-2010 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007-2009 Chevrolet Impala
2005-2009 Chevrolet Trailblazer
2007 Chevrolet Monte Carlo
2007-2010 GMC Sierra, Yukon
2005-2009 GMC Envoy
2007-2008 Pontiac Grand Prix
2008-2009 Pontiac G8
2005-2009 Saab 97x
With an AFM (Active Fuel Management) V8 Engine RPO: L76, L94, L99, LC9, LFA, LH6, LMG, LS4, or LY5
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
<A href="#ss1-2435251">Condition/Concern:
Some customers may complain of a low oil pressure message/light on the dash and a technician may find a P0521 DTC in the ECM.
<A href="#ss2-2435251">Recommendation/Instructions:
If this concern is encountered, follow SI diagnosis. If it indicates that the Tech 2 oil pressure parameter is low but proper oil pressure is present at the oil filter housing, inspect the Valve Lifter Oil Filter for debris/sludge that could be restricting oil flow to the oil pressure sensor before replacing any parts.
Follow the Valve Lifter Oil Filter Removal and Installation Procedure to remove the filter for inspection. If the filter is plugged, it can normally be cleaned with brake/contact cleaner and light shop air. If it cannot be cleaned for some reason, replace it using the part number listed in the parts catalog. Do not replace the complete Valve Lifter Oil Manifold just because the filter is plugged.
#452 - Valve Lifter Oil Filter
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
venice17517 is offline   Reply With Quote
Old 07-22-2010, 09:21 PM   #24
moiy1983
moiy1983's Avatar
Drives: 2010 camaro ss/rs
Angry
had this happen to me! i almost literaly shit my self but i turned it off right away! gonna repalce it with a hight volume pump asap!:moo n:
moiy1983 is offline   Reply With Quote
Old 07-22-2010, 09:37 PM   #25
busaboy
busaboy's Avatar
Drives: Black RS/SS M6
Thanks for the heads up.
busaboy is offline   Reply With Quote
Old 07-22-2010, 09:45 PM   #26
1CAMSS
1CAMSS's Avatar
Drives: 2010 1SS CAMARO/GBA/M6- sold.
sure glad i read this this! i don't have gauges. i will look out for message in the DIC though.
1SS @ home. 12/14/2009
1CAMSS is offline   Reply With Quote
Old 08-01-2010, 06:45 PM   #27
LP0425
Blue Growler
LP0425's Avatar
Drives: 2010 IBM 2SS/RS
Mine popped up just this weekend; car is 6months old. Headed to the dealer tomorrow
LP0425 is offline   Reply With Quote
Old 08-01-2010, 07:06 PM   #28
1CAMSS
1CAMSS's Avatar
how many miles on your odometer?
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 08:51 AM
Stock Injectors vs Magnuson Kit Injectors Mark-HD Forced Induction - V8 24 01-27-2010 08:04 PM
BP Makes "Giant" Oil Find in Gulf of Mexico KILLER74Z28 General Automotive + Other Cars Discussion 1 09-02-2009 07:39 PM
How about a barrel of oil for around $16? Blownhotrodder General Automotive + Other Cars Discussion 19 03-06-2009 07:25 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
