Old 10-19-2010, 09:04 PM   #57
RX SS RACERX
RX SS RACERX's Avatar
Drives: 2010 2SS/RS RJT
Question What's the informed opinion?
3k and change miles. Vin 2337. Mods probably toast warranty. Can't believe I bought an extended warranty! Hopefully they will cover a wiper motor!:-) Even if they will cover on their dime-wonder if I should just buy a quality pump and install myself? SC/etc. in the future. What do 'you' suggest? Hope I'm not jinxin' myself-no oil press issues so far, even though I did pour Castrol Edge down that Mobil One labeled hole!Build date 3/10/2010
RX SS RACERX is offline   Reply With Quote
Old 10-19-2010, 09:25 PM   #58
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
since it's a known problem, it still should be covered...but I guess that depends on your dealer. Couldn't hurt to just replace it....I'm definitely going to when I do a cam swap, just for piece of mind.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 10-20-2010, 07:28 AM   #59
GMRULZ
GMRULZ's Avatar
Drives: 2010 SS & 2008 C6
Ok, so far as a count on here to help others possible figure out if their car will be affected, lets try and put the info together for everyone.
Your:
Vin#
Date of manufacture
Type of motor (LS3 or L99)
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s!
Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list..
GMRULZ is offline   Reply With Quote
Old 10-22-2010, 02:38 PM   #60
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Had my car towed to the dealer today. Let's see what they say is wrong.
Funny thing was that the service rep was already trying to sell me an oil change. I told him I would wait for them to tell me what's wrong first.
If the warranty repair requires them to drain the oil, do I have to pay for the "oil change"?
Old 10-22-2010, 06:48 PM   #61
1CAMSS
1CAMSS's Avatar
Drives: 2010 1SS CAMARO/GBA/M6- sold.
i doubt you have to pay for an oil change if the part that needs replacing is under warranty. i have less than 18000 miles on my car and it was built in December 2009. I hope mine is trouble free!!!
1SS @ home. 12/14/2009
1CAMSS is offline   Reply With Quote
Old 10-23-2010, 12:55 AM   #62
NC_SG_SS
NC_SG_SS's Avatar
Drives: 2011 Synergy Green 2SS
does this TSB cover the 2011 camaro SS as well, everyone i saw having this issue owns a 2010 SS...mine was built in aug 2010. i have not had this issue...but seems the TSB will cover the replacement..i have had componets changed on TSBs before. this is a straight forward deal. any good dealership should be able to comply...seems like the other pump is a good option but u loose warranty coverage...i have not seen this on mine..have had it just over 30 days...
2011 2SS/RS SGM KAE, MN6, SLP ZL sways. TPC strut tower brace, GMPP Exhaust,roto-fab cai, pfadt lowering springs, Pedders subframe inserts, radius arm and steering rack inserts. 69 camaro fender and hood badges,heritage grill with orig SS badge, AAC green and white LEDs, RJM designs interior with green houndstooth seats inserts, suede headliner, Berger Chevrolet rear blackout big block tribute, 3stage white gold diamond pearl custom rally stripes by ayers custom paint concord, nc
NC_SG_SS is offline   Reply With Quote
Old 11-09-2010, 02:04 PM   #63
slick rick
SoCal Mayhem
slick rick's Avatar
Dealer replaced the oil pressure relief valve and everything seems to be OK now.
Old 11-09-2010, 02:36 PM   #64
GMRULZ
GMRULZ's Avatar
VIN number? LS3 or L99?
Old 11-09-2010, 03:30 PM   #65
slick rick
SoCal Mayhem
slick rick's Avatar
A9105323
LS3
Old 11-09-2010, 04:05 PM   #66
LP0425
Blue Growler
LP0425's Avatar
Drives: 2010 IBM 2SS/RS
Dealer fix issues
Its a fix covered by warranty as long as you haven't modified your car. You shouldn't have to pay anything, including oil. The fix requires either being able to clean it out, but in more cases... they have to replace. To replace, they pull your engine and are to inspect for additional damage and debris in the oil pan=oil change.
When they give it back to you, there is a possibility of the engine rattling around a bit, and they are "supposed to" tell you to come back to check the mounting bolts & retorque. If it's loose, you'll hear a rattle on curves.
LS3
appx 2800miles when it went out
build date Dec 19, 2009
LP0425 is offline   Reply With Quote
Old 02-06-2011, 12:51 AM   #67
Camaricopa
Camaricopa's Avatar
Drives: 2010 Camaro 2SS/RS BLK/ORG
Add me to the List. Had just run a HPDE Session . Let the Engine cool Down, went to go get gas and "No Oil Pressure". Had a tow truck come get the car and my wife come get me. I have no internal Mods to the Engine, so hopefully the dealer won't give me to much grief for tracking my car. Bad news for those of you hoping it was isolated in VIN or date code. Don't have my VIN handy but my car was born in May of 2010.
Camaricopa is offline   Reply With Quote
Old 02-06-2011, 01:15 AM   #68
CC Performance
Drives: 99 Camaro SS, 79 z28, 70 GTX
meling 10-296 is what we use in all our engines
CC Performance is offline   Reply With Quote
Old 05-03-2011, 03:30 PM   #69
mattderk
I have this issue and dealer refused service due to my cam and pcm tune. Anyone have any issues / luck with dealership ?
mattderk is offline   Reply With Quote
Old 05-03-2011, 03:32 PM   #70
mattderk
Originally Posted by jrhaus76 View Post
not sure thats true. they should have still done the TSB for you... If its a known issue (flaw) it shoud be covered regardless of mods. For example, if your tail shaft fails, you get a new tranny no matter what mods you have done b/c the part is a known issue...
Dealer wouldnt cover for me .. trying to force them by calling gm direct.
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
Stock Injectors vs Magnuson Kit Injectors Mark-HD Forced Induction - V8 24 01-27-2010 09:04 PM
BP Makes "Giant" Oil Find in Gulf of Mexico KILLER74Z28 General Automotive + Other Cars Discussion 1 09-02-2009 08:39 PM
How about a barrel of oil for around $16? Blownhotrodder General Automotive + Other Cars Discussion 19 03-06-2009 08:25 PM
