Old 05-05-2011, 02:13 PM   #71
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
Originally Posted by mattderk View Post
I have this issue and dealer refused service due to my cam and pcm tune. Anyone have any issues / luck with dealership ?
a little late now, but a note to everyone else...when to do a cam swap, there's NO reason NOT to replace your oilpump.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 05-05-2011, 02:24 PM   #72
mattderk
Drives: 2010 Camaro 2SS
Yes 20/20 hindsight. In the end the issue was a jammed check valve and the o-ring was cut. GM installed the oil pump with a cut o-ring .. nice quality control. There is the source of my issues.
mattderk is offline   Reply With Quote
Old 05-05-2011, 02:49 PM   #73
POWERFREAK
I.AM.
POWERFREAK's Avatar
did they do it under warranty for you? how many miles did you have on it when it went?
most good performance shops will automatically replace the oilpump when doing a cam since it's right there (on these motors).
NY5thgen.com
Old 05-09-2011, 08:51 AM   #74
mattderk
I went to the shop that did my heads and cam. They found the damaged o-ring and check valve after removing the pump. I wasnt having GM do it since this is $$ out of my pocket.
Old 05-09-2011, 09:39 AM   #75
tom692010
Drives: 4 wheels
Originally Posted by jrhaus76 View Post
not sure thats true. they should have still done the TSB for you... If its a known issue (flaw) it shoud be covered regardless of mods. For example, if your tail shaft fails, you get a new tranny no matter what mods you have done b/c the part is a known issue...
That's a good one for a Monday morning
tom692010 is offline   Reply With Quote
Old 05-09-2011, 10:47 AM   #76
Stingr69
'69 Owned Since '79
Stingr69's Avatar
[QUOTE=tom692010;3196609] That's a good one for a Monday morning[/QUOTE
This issue is not covered by a TSB! It is just a PI (product information) at this point from what I have been able to find out. This is not the same as a TSB and carries less weight.
As for "should" they do it - well, "should" is a good word to describe the situation. They "SHOULD" fix it but they will PROBABLY deny it and then it would be up to the car owner to fight that battle. No fun at all! :(
-Mark.
Old 05-09-2011, 11:01 AM   #77
DREV LSX
DREV LSX's Avatar
Drives: Its the Millenium Falcon
Originally Posted by SmokinBills 2SS View Post
Dec 14th '09 Lot of other chevrolets in this TSB(corvette,camaro,trucks and suv's)but i was one of the lucky ones that had the condtion and caught it in time to save the motor. had to service it myself because of all the Mods, Cam,Heads,exhaust. oh well my new hot rod right. it's only money$$$$$$$$$$$$$$$
Under the Magnuson Moss Warranty Act no dealership can deny warranty service or a TSB to your vehicle regardless of mods.
DREV LSX is offline   Reply With Quote
Old 05-09-2011, 04:24 PM   #78
tom692010
Drives: 4 wheels
[QUOTE=Stingr69;3196835]
-Mark.
I asked a service rep if my warranty would be void on my tranny because I installed a short shifter and ran Royal Purple fluid and he answered---Depends. Now that's total BS so I wouldn't be suprised at any denial of service. Just my thought!
Old 05-10-2011, 10:27 PM   #79
GaryTucker
Drives: 09 Vette GT1, 06 350Z, 82 MSE
Not sure which rule book you are reading...because GM can AND will deny TSB work on highly modified or tuned cars. They cannot deny doing RECALLS...but that is different than PI's or TSB's. Do a search around the net and even on here...they will deny.
GaryTucker is offline   Reply With Quote
Old 05-10-2011, 11:24 PM   #80
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
Wrong.
Ovenmitt is offline   Reply With Quote
Old 05-28-2011, 06:17 PM   #81
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
dam no vin range yet huh
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 05-28-2011, 11:19 PM   #82
L99CAMA2011
L99CAMA2011's Avatar
My 1SS doesn't have those 4way guages but dealership can install them, if this happens too often I will probably be switching back to Mustang 5.0 since Ford don't try to void warranties for sneezing too loud.. My personal opinion is we should have a good lawyer take GM to court for voiding warranties for stuff that definitely doesn't have squat to do with the problem. I have a Vararam no tune intake and after hearing all this I think I am going to keep it that way, no tune. Because of this GM is going to loose a customer or 2000, just saying
Old 05-29-2011, 12:28 AM   #83
Neriah
Neriah's Avatar
Drives: 2011 2SS/RS
What will you take them to court for? Because YOU signed the contract to purchased the car and accepted all stipulations of the Warranty? there are rules from GM, since they are the ones issuing the warranty..... its not mandatory or the law that you get any kind of warranty at all... so if you accept the warranty from GM... you accept the stipulations and rules they put on them... you dont like them? buy a Mustang... whatever gets you to stop ....
Built By Blu808
LG G6X3 Cam, UD Pully, Rotofab Intake.
Dynatech LT's. Borla ATAK Catback.
Full BMR bushings and suspension.
Neriah is offline   Reply With Quote
Old 05-29-2011, 11:01 AM   #84
POWERFREAK
I.AM.
POWERFREAK's Avatar
geez, let's all get our panties in a bunch here.
If you read through the posts (there's only about 2323403430 of them, so you'll have to read through all the waaaaah), it really all depends on the dealer. There's been plenty of people here with aftermarket parts get warranty work taken care of. (see posts about output shaft & blower)
I would imagine some ford dealerships will be tightwads about aftermarket/warrenty issues too.
My feeling is that being that there's a TSB on the oilpump, if your oilpump fails, there really isn't any aftermarket part that is going to cause that to happen, so GM should step up to the plate and fix them. But I'll be doing a cam soon on mine and will absolutely be putting in a better oilpump at the same time. Dealers should at least be willing to do something to help out and not just say VOID! If that's the case, find a different dealer.
NY5thgen.com
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
Stock Injectors vs Magnuson Kit Injectors Mark-HD Forced Induction - V8 24 01-27-2010 09:04 PM
BP Makes "Giant" Oil Find in Gulf of Mexico KILLER74Z28 General Automotive + Other Cars Discussion 1 09-02-2009 08:39 PM
How about a barrel of oil for around $16? Blownhotrodder General Automotive + Other Cars Discussion 19 03-06-2009 08:25 PM
