Old 03-22-2010, 12:44 PM   #1
Acebeforejack
Acebeforejack's Avatar
Drives: 2010 Camaro SS2/RS
JBA shorty headers installed, engine light on
I just got my JBA shorty headers installed 2 days ago and the engine light is on.. I have a diablo sport predator tuner and i was curious is anyone could walk me threw on how to turn the engine light off.. I also have another quistion.. I installed a CAI and i thought i could tell the little hp differnce then after i installed the custom tune that came with the predator i didnt notice anything really... I turned off the skip shift and i think the DOD.. Is there anything else i can do? thanks..
Acebeforejack is offline   Reply With Quote
Old 03-22-2010, 01:11 PM   #2
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
Did you/they reset the computer after the header install? I had no codes with my JBA shorties.
No knowledge of tuning, so can't help there...
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 03-22-2010, 01:14 PM   #3
Icntdrv55
CCOTR Member
Icntdrv55's Avatar
Drives: Victory Red 2010 2SS/RS A6
On a separate topic.....have either of you guys noticed any performance increase with the shorties. I am on the fense as I have heard mixed reviews, some say they increase HP some say they dont!
Camaro Club Of The Rockies (CCOTR) Check us out on Facebook!
2010 Camaro SS/RS Victory Red A6- Vararam Intake, Doug Thorley Tri Y LTs, Magnaflow X-pipe, Flowmaster Super 40's, VMS Tune, Razzi Ground Effects, Herritage Grill, RED headlight and fog light Halos, LED DRLs, Dash and extended Door ABL, engine, grill and rear defusser LED lighting ........ 12.59@112.21 (DA Corrected)
Icntdrv55 is offline   Reply With Quote
Old 03-22-2010, 01:26 PM   #4
Acebeforejack
how do you reset the computer? no i didnt.. and i bet they didnt either
Old 03-22-2010, 03:30 PM   #5
JBAGREG
Drives: JBA SUPERSPORT 2SS/RS Vortech Blown
If you have the Diablo Sport Tuner you should be able to read what code you have triggered. Before you do anything, follow the step by step instructions that came with your Diablo and read the Check Engine Code. Thats going to tell you where to start your diagnosis.
Once you know what the code is. Write it down and use the Diablo to clear the code. After that, come back and tell us what code you have triggered.
FYI. The JBA 1812S headers will not trigger a light unless you have caused an issue with an 02 sensor. Lets see what codes you have before we do anything else.
JBAGREG is offline   Reply With Quote
Old 03-22-2010, 03:33 PM   #6
Michael_Js
Michael_Js's Avatar
Ok, what he said
If you don't have the tuner, some auto parts stores, like AutoZone, will read the code for free...
Old 03-22-2010, 04:57 PM   #7
Acebeforejack
okay i did what you said... I got 3 codes P0030 P0053 P0135 they all had to do something with heating something... But it wouldnt let me clear it..
Old 03-22-2010, 05:33 PM   #8
Eric Baker
Drives: Black/Black 2SS/RS 6M
Are any of the O2's unplugged by chance?
Eric Baker is offline   Reply With Quote
Old 03-22-2010, 05:54 PM   #9
JBAGREG
P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
P0053 HO2S Heater Resistance (Bank 1, Sensor 1)
P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
Did you disconnect the battery when you installed the headers?
Old 03-22-2010, 06:18 PM   #10
JBAGREG
Sounds to me like a Bad 02 sensor. - Could have been damaged during install or not hooked back up. Here is the data I found on OBD-Codes.com
Your OBD-II Trouble Codes Repair Site
Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
What does that mean?
This code refers to the front oxygen sensor on Bank 1. The heated circuit in the oxygen sensor decreases time needed to enter closed loop. As the O2 heater reaches operating temperature, the oxygen sensor responds by switching according to oxygen content of the exhaust surrounding it. The ECM tracks how long it takes for the oxygen sensor to begin switching. It the ECM determines (based on coolant temp) that too much time elapsed before the oxygen sensor began operating properly, it will set P0135.
Causes
A code P0135 may mean that one or more of the following has happened:
O2 Heater element resistance is high
Internal short or open in the heater element
O2 heater circuit wiring high resistance
open or short to ground in the wiring harness
Possible Solutions
Repair short or open or high resistance in wiring harness or harness connectors
Replace oxygen sensor (cannot repair open or short that occurs internally to sensor)
Old 03-22-2010, 06:24 PM   #11
trudawg660
Drives: 2006 Dodge Charger / 2SS IOM
a couple of the v6 people had that problem with the jba shorties
trudawg660 is offline   Reply With Quote
Old 03-22-2010, 06:50 PM   #12
2010 4 DW
Drives: White 2010 RS/SS
They fixed the check engine light when the leak was fixed between the flanges on the collector.
You have to use high temp RTV at that location for optimal seal.
DW
2010 4 DW is offline   Reply With Quote
Old 03-22-2010, 10:22 PM   #13
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
DW
I had the same problem when installing my DT shorties on the driver-side. We torqued the head bolts on top first and couldn't get the bottom flange to seal w/ the collector (should have done the opposite first, but the instructions didn't specify, if I recall. I would get under the car and check those flange connections to make sure they're flush first, before anything else (I had a huge gap, LOL).
fldrummer is offline   Reply With Quote
Old 03-23-2010, 01:38 PM   #14
Acebeforejack
none of that sounds good :(
Engine Cleaning With Pictures Angelo@Autopia Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 4 05-01-2010 11:00 PM
Kenne Bell Vs. Whipple Who Wins? thalilbear02 Forced Induction - V8 132 01-28-2010 07:23 PM
JBA bolt up shorty headers ROD1 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 31 01-13-2010 05:55 PM
JBA shorty headers? SS-screamer Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 09-21-2009 02:28 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
