Old 03-22-2010, 09:53 PM   #1
getarz4u15ster
getarz4u15ster's Avatar
Drives: Camaro RJT 2SS/RS
Throttle body plate drilling...
Okay so next week i'm putting a cam in my SS, and after much research i was on LS1helptech.com and found on one of the forums an old school trick for smoothing out the idle. Apparently "drilling a small hole in the bottom the throttle plate no greater than 1/4 of and inch. But... again that was an LS1 with a throttle cable. I know this works in the older carb motors, but how much does it help with the LS3 where it's a drive by wire system? I would think that the ECU take care of opening the throttle body plate to level out idle, regardless of cam lobe size... well... with in reason of course.
Please if anyone has done this, let me know your experience and if this has worked for you!
Ideas, hints, tips are welcome....
2010 RJT SS
Port and Polished, Milled .005 Heads
Patriot Valve Springs, Titanium Retainers&locks
Manley Race Valves
Comp Chromoly push-rods
Ported T/B
DT Headers, JBA H/F Catted mid pipes
Magna Flow Comp series exhaust w/ Xpipe
Comp Custom grind Cam
Tune and Machine work done by MPC
CAI Intake
getarz4u15ster is offline   Reply With Quote
Old 03-22-2010, 10:07 PM   #2
kismyss
Drives: CGM 2SS Roto-Fab CAI, Mach XL CAT
Just get an intake and a tune. The Car's Computer is learning your driving habits so make sure your teaching Her right. Also If you barely floor it a little instead of just punching it you"ll get a better jump. The throttle is a computerized and I think it takes longer for the computer to register a "Floor it" than to "Throttle Engage" if that makes sense. It may be trying to protect the engine. I love this freakin car. It's a monster
kismyss is offline   Reply With Quote
Old 03-22-2010, 10:40 PM   #3
Slowhawk
Drives: 1999 Trans Am
Do not drill the throttle body.. That was something we did in 2001 when tuning was not available.With todays cars you can control the throttle opening for idle. By drilling the hole you might screw up something.
Slowhawk is offline   Reply With Quote
Old 03-23-2010, 12:18 PM   #4
X-treme Horsepower
X-treme Horsepower's Avatar
Drives: 2010 LSX Shootout World AM Finalist
exactly what he said
X-treme Horsepower is offline   Reply With Quote
Old 03-23-2010, 12:26 PM   #5
getarz4u15ster
That's what i thought. thanks guys.
2010 RJT SS
Manley Race Valves
Ported T/B
CAI Intake
Old 03-30-2010, 12:13 AM   #6
reason
reason's Avatar
Drives: 2010 Camaro 2SS / RS
ahh memories, i did that in high-school after camming the LT1.
reason is offline   Reply With Quote
Airaid Poweraid Throttle Body Spacer Dynabyte Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 17 08-05-2011 03:41 PM
Body color license plate frame? ShockwaveTXB Cosmetics and Lighting Modification Discussions 1 12-03-2009 06:32 PM
I have a front plate and it's STILL illegal... wrek Cosmetics and Lighting Modification Discussions 23 10-25-2009 12:11 AM
Hardcore racers rejoice!! GM Performance Parts to offer new Camaro body in white radz28 5th Gen Camaro SS LS LT General Discussions 23 12-22-2008 10:57 AM
