JUICEDMOTORSPORTS
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 03-24-2010, 04:43 PM   #1
bbktech2
Drives: 1937 Ford
BBK 4020/0/5 Shorty headers fitment
On Monday the 22nd of March, it was brought to our attention that there was a fitment issue with BBK Performance's Shorty headers Part numbers 4020, 40200, 40205.
The issue was bolting the stock mid pipe flanges back up to the flanges on the headers. The preproduction ones I did the test fitting and dyno work with did have clearence to use the stock flange nuts and I used an open end wrench to do the tightening of the nuts. As they went into production, the collector area at the flange grew slightly and the already close tolerance of collector wall to stud hole was compromised. The result was that the stock flanged nuts could no longer be used. In addition, the stock front midpipe stud on the driver side was now hitting the collector due to it's design and inability to be copied from the original design.
We offer our most sincere apologies for this mishap!!! We tried so hard to come up with a nice looking, well performing shorty header for this awesome Camaro.
We do have a fix in the works and have come up with a solution of having bolts supplied in the kits to replace the studs when installing. The bolt size is 10mm x 1.50 x 25mm, if any of you should end up getting a kit without the bolts. If that should happen, please don't hesitate to give me a call and we will ship them out directly to you. I can be reached at 951-266-1771 ext. 312. That's PST as we are located in So Calif.
bbktech2 is offline   Reply With Quote
Old 03-24-2010, 11:54 PM   #2
pnyklr
Drives: A Gift From My Wife
Props to you guys in addressing an issue. Excellent Customer Service IMHO.
Now, can we get a dyno graph, please!
-Funk
pnyklr is offline   Reply With Quote
Old 03-26-2010, 01:57 AM   #3
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
I was the first to alert BBK of the fitment issue. You can read my posts in the " Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons " section for details. As I state in the Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons section, BBK is doing whatever is necessary to ensure I'm a happy customer. Even with this fitment issue I'm satisfied I made the right choice. For a DD, T-304 stainless is the right choice, spark plugs and wires fit and are accessible just like OEM and there is noticeable increase in power. Ed.
Ed.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, Hawk HPS Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9 & 20x11 DS3 wheels with Pirelli Pzero 275/40/20 & 305/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, GM SS Fender & LS3 Emblems.
flht99b is offline   Reply With Quote
Old 03-26-2010, 09:39 PM   #4
yota924x4
yota924x4's Avatar
Drives: 2010 Camaro SS m6, 1970 Nova SS396
Send a message via AIM to yota924x4
right on guys, it is nice to see the vendor posting in the forums and eager to make everyone happy. now if i only can get around to doing my taxes and getting some coin back i'm going to pick up a set of these in t304.
yota924x4 is offline   Reply With Quote
Old 03-26-2010, 09:45 PM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Are you guys getting CARB numbers for these?
"...What IS true: We anticipated that this would happen - we are never finished - and yes, Ford DOES deserve to win now and then. To think that GM can come out with a car to make ford throw in the towel is simply foolhardy..." - fbodfather
Old 03-28-2010, 11:25 AM   #6
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Nice!
9/26/09 Took delivery!
Old 03-29-2010, 09:18 AM   #7
bbktech2
Drives: 1937 Ford
Yes, we will be submitting the shorty headers for CARB exemption. It's a llloooooonnngg drawn out process so I am sorry to say I can't give a date of when the will be Calif legal.
Old 03-29-2010, 11:14 PM   #8
2010SSRSM6
SoCal C5 Family Member
2010SSRSM6's Avatar
Gotta love commiefornia's anti-fun laws.
Powered by Cunningham MotorSports
Old 03-30-2010, 10:01 AM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
That's good news! So far, I'm liking these shorties the best.
Thanks for the heads-up.
Old 04-01-2010, 05:14 AM   #10
flht99b
flht99b's Avatar
BBK 4020/0/5 Shorty headers fitment - My Fix
Here is my cure for the BBK shorty fitment issue. On the right is one of 4 stock m10-1.50-15mm hex head flanged hex nuts that retains the stock mid pipe to the stock cast iron exhaust manifold and or shorty headers. Due to the flange on this nut will not fit with the BBK shorty header, there isn't sufficient clearance between the stud that comes up from the mid pipe through the collector flange, the collector is too big or needed to be dimpled for clearance. Substituting a non-flanged m10-1.50-15mm hex nut ( 15mm socket size ) will fit BUT due to the too close proximity of the points of the 15 mm nut to the collector ( approximately 1mm ), it is a very tedious ordeal to tighten these nuts with very short open end and crow foot wrenches being the only option due to the space constraints under the car and headers. The nut on the left is a stainless steel ( polished to boot ) m10-1.50-12mm 12 point head flanged nut ( 12mm socket size ) I purchased from allensfasteners.com, p/n 400-8345. In SS they are pricey at $3.72/ea but in standard steel they are $2.83/ea. The short 12mm, 12 point combination wrench pictured is a Husky Pro but all tool manufacturers produce a similar short 12mm combination wrench. Had BBK included 4 of these nuts with their headers, gaskets and header bolts I guess this and the thread I started on BBK shorty headers fitment issues would have never been.
Ed M.
Old 04-01-2010, 11:07 AM   #11
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
There ya' go!!! I won't even get into how many "specialty" tools I bought for my cars, just for exactly the job that I was working on, from headers to clutches, lol. Good job
BBK Headers for V6 2010 Camaros! PHASTEK Performance Sean@Phastek V6 Bolt-Ons & Tunes 157 03-28-2012 10:20 AM
BBK Shorty Headers V8 LS3/L99 - Chrome, Ceramic Coated, or Stainless Steel Sean@Phastek V8 Bolt-Ons & Tunes 10 06-09-2010 12:30 PM
BBK LS3 shorty headers flht99b Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-26-2010 09:37 AM
bbk shorty chrome headers DANS2010BLKCAMARO Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 12-15-2009 09:50 AM
JBA releases exhausts, headers and midpipes. Bewenched Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 09-16-2009 03:04 PM
