Gen5DIY
Old 03-25-2010, 03:30 PM   #1
import_killa
import_killa's Avatar
Drives: 2SS IBM
TSB on rear mains
there is a TSB, technical service bullentin, for certain casing numbers for the rear main seals leaking, when i went and had my oil changed they noticed i had a small amount of oil on the botton of the transmissions bell housing and they researched it and mine falls into the casing number and the part was oredered and is going in the shop on Monday. Just wanted to give yall a heads up the next time you have your oil changed take a peek and see if you have a leak. Mine wasnt leaking bad enough to form drops so I would not have never known if I hadnt looked under it while they did the oil change
1 7/8 AR headers, roto-fab CAI with radiator, fuse box, and valve cover, cam, upgraded fuel system with 85lb injectors, under drive pulley, TVS 2300 S/C, muffler delete, aftermarket wheels, AAC headlights fogs sidemarkers footwell dome and trunk lights.....That's 659.9 RWHP 611.9RWTQ
T
import_killa is offline   Reply With Quote
Old 03-25-2010, 08:38 PM   #2
Baldman
EMERALD COAST CAMAROS
Baldman's Avatar
Drives: 2015 Spice Red Metallic 2LTZ Impala
How old is your Camaro? Vin number would help.
Baldman is offline   Reply With Quote
Pfadt Camaro Rear Toe Link Reinforcement Kit Install write-up PfadtRacing Suspension / Brakes / Chassis 9 01-28-2014 08:15 PM
New from RPI! 2010 Camaro Pre-Painted Body Color Rear Spoiler! $399.00, painted! RPI Designs Exterior Parts & Accessories 10 03-25-2010 03:42 PM
2010 Camaro SS Blue in Syracuse NY $32690 Mitsubishi in Syracuse Camaro Price | Ordering | Tracking | Dealers Discussions 0 12-31-2009 03:44 PM
Some Texas Lighting Laws Mecha USA - Texas 5 10-20-2009 02:49 PM
Suspension guys out there - lets talk wheel hop Crowley Suspension / Brakes / Chassis 14 10-09-2009 01:06 AM
