JDP Motorsports
Old 03-28-2010, 01:20 PM   #15
TRSS2
TRSS2's Avatar
Drives: 2010 Chevy Camaro 2LT Black RS
Originally Posted by Wizzer View Post
Well I got a fast answer but it was not what i was looking for.
Wizzer
Sorry that's not my dept . I don't deal with the wiring group.
----- I guess it was a long shot but I have a nice snap on tool that lets me poke the wire and see if it is hot. I am going to go out in the garage and check around. I feel this might be a challenge.
Wizzer
Apologies for having a question that has a rather difficult/tedious answer, but your efforts will most definitely help others, I greatly appreciate the time and effort you are putting forth.
2010 2LT/RS Black(exterior) on Black(Interior Leather) on Black(Flat Black Powdercoated Rims)
AAC interior red dome lights, footwell lights, SMD wheel well lights, led pods, afterburners(SMD), RED/WHITE halo headlights and fog lights, Nite Rider scanner times 2, illuminated bowtie, T-REX black phantom billet grill upper and lower, had vinyl blackouts-they turned out to be illegal . Soon to have LTLAudio door projectors.
TRSS2 is offline   Reply With Quote
Old 03-28-2010, 03:06 PM   #16
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
ask this person to ask the same question in the correct department
Wizzer
Wizzer
SSTony is offline   Reply With Quote
Old 03-28-2010, 07:17 PM   #17
Wizzer
Drives: 2010 Cyber Grey
Well I went out a poked around the fuse box and they are all hot as expected being the fuse box. I then poked a few wires under the dash as best I could constantly testing them with the car armed and unarmed. I get the feeling the parts we need is behind the dash and up there deep. I even went so far as to listen for relays moving or clicking. Nothing. I will ask the guy if he has any contacts in that department but based on his short answer I am thinking he is a busy guy.
Wizzer is offline   Reply With Quote
Old 03-28-2010, 07:24 PM   #18
RedRyder
RedRyder's Avatar
Drives: 2010 VR 2SS/RS M6
You need to poke around and test the pins on the BCM (under dash). We need something that is hot when the alarm is on and not when its unarmed and only when its unarmed. I'd do it but my cars not here yet :(
RedRyder is offline   Reply With Quote
Old 03-28-2010, 09:42 PM   #19
TRSS2
TRSS2's Avatar
Sounds like a lot of work and time, thanks for all that work
Old 03-29-2010, 08:09 PM   #20
SSTony
SSTony's Avatar
Drives: SS Camaro
if somoene could pop off the light for the alarm then we can at least know what color it is.
Old 03-29-2010, 09:17 PM   #21
RedRyder
RedRyder's Avatar
What do you mean? Is there a light for the factory system?
Old 03-29-2010, 11:14 PM   #22
Wizzer
Well all I know for sure is the little dome in the middle of the dash blinks when the alarm is on. I'd like to trace that wire but it would mean dash removal.
Old 03-29-2010, 11:28 PM   #23
TRSS2
TRSS2's Avatar
I was hoping it wouldnt resort to that... I do appreciate all the time and effort that has been put into this inquiry thus far.
Old 03-29-2010, 11:53 PM   #24
Don O
Camaro and Vettehead
Don O's Avatar
Drives: 2SS/RS IOM L99 69 427/400 Vette
Here's the wiring diagram. I just received my service manual today. The LED is part of the ambient light sensor.
Don O
Nothing sucks more than that moment during an argument when you realize you're wrong.
Don O is offline   Reply With Quote
Old 03-30-2010, 12:14 AM   #25
TRSS2
TRSS2's Avatar
Don O
Ludicrously AWESOME! Muchos Gracias!!!! Mui Bueno!! Ok, so this is what I am gathering...you are saying that the light that blinks while the car is locked on the center of the top of the dash, the power for that is coming off of the ambient light sensor from the gray block under the driver side, and the wires is on the 21 position on that block? So do I actually need to find the black wire that branches off of the ambient light sensor? I will have to see about tinkering with that as soon as i can, and I will post pics of install once I get some time may be this weekendish, if all goes well.
Old 03-30-2010, 12:24 AM   #26
Don O
Don O's Avatar
The black wire is just ground. You can get that anywhere on the metal on the car. You might need to use a relay if the BCM has a current sensor on the output to the LED, but you might get by if you're just powering a few LEDs.
Don O
Old 03-30-2010, 10:16 AM   #27
RedRyder
RedRyder's Avatar
Thanks for the schematics! But if it's for the ambient light sensor doesn't that means it's on all the time? Or are your saying the sole purpose of that gray wire is for the blinking led and it is just labeled as under the ambient light sensor?
Old 03-30-2010, 03:25 PM   #28
SSTony
SSTony's Avatar
Drives: SS Camaro
if it pulses that wont work well for us.
aac, knight rider, security, tap, wiring
Third brake light Rob53 5th Gen Camaro SS LS LT General Discussions 28 09-23-2017 01:49 AM
DIY - ABL using EL wire, and 3/16" tube camarorick Camaro DIY & HOW-TO instructions & discussions 502 02-25-2014 02:29 PM
Onstar....a spy???? please comment dieseldave24v General Automotive + Other Cars Discussion 138 02-23-2012 02:12 PM
Those with LT's, RESET your check engine light! TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 107 08-18-2010 02:51 AM
