BORLA
Old 03-27-2010, 11:14 PM   #43
pnyklr
Drives: A Gift From My Wife
What else is needed to get BT working?
-Funk
pnyklr is offline   Reply With Quote
Old 03-27-2010, 11:16 PM   #44
techsupport
Drives: 1ss, heritage grille cfh perf. mods
the onstar vcim in the ls and 1ss dont have the port for bluetooth antenna. you would need the bluetooth vcim and antenna. problem is gm wont sell it to you for some reason. some of us on here are talking to gm about that also
The Speed Demon (aka tech support)
techsupport is offline   Reply With Quote
Old 03-28-2010, 12:15 AM   #45
Eski7399
Arizona All Gens
Eski7399's Avatar
Drives: 2SS/RS, M6, IO-Int
Wow, way to make that look easy.
As I've torn into my car the more and more I realize that this car was designed by this guy...
Summit White, 2SS/RS, IO Int, M6, Sunroof, Black Rally Stripes, Built 10/30/09.
Current Mods: Pacesetter 1 3/4" LT Headers, High flow Cats. CAI Inc. Intake, LPM custom Grind Cam, Comp Hardened Pushrods, Pac Racing 1521 Dual Springs with Titanium Retainers, Hardened Seats and Locks, LPM Custom Dyno Tune by NicD, Barton Ind. S/T Shifter, Muffler Delete, ABL Dash, AAC Style P13W LED DRL, Phantom Billet Grill by T-Rex, Razzi Rear Diffuser & Side Skirts, Street Scene Spoiler, PFADT Coilovers.
Loud Pedal Motorsports (LPM). http://www.loudpdl.com/index.php
Eski7399 is offline   Reply With Quote
Old 03-28-2010, 01:55 AM   #46
alex33x
Drives: 2013 Camaro ZL1
Originally Posted by cab2g View Post
The 1SS does not have the option to be ordered with bluetooth. However all other trims except for the LS can be ordered with bluetooth. It's pretty much a crime that GM won't allow you to order Bluetooth with the 1SS like you can with the 1LT, but if you like cloth seats and the V8, this is the only way to get bluetooth.
Oh ok thanks for clearing that up. lol
Devliered July 20, 2012
alex33x is offline   Reply With Quote
Old 03-28-2010, 01:55 AM   #47
huskerwr38
Drives: Chevrolet Camaro
Will this void the manufacturing warranty in any way? That is the only thing I'm worried about.
huskerwr38 is offline   Reply With Quote
Old 03-28-2010, 02:18 AM   #48
techsupport
seeing as how it is a gm program and a gm part i realy cant see where there would be a problem. The switch might not be covered for the duration of warranty if you had an issue with it since it was added on.When you order remote start for these vehicles you have to get them programmed from gm and all it is is a new key fob/clicker and a new program. That wont void any type of warranty. The only time i have ever seen them not warranty something that went wrong is because of an aftermaket install ie exhaust,radio,wheels and stuff like that. They cant say the program is what made your bcm go bad because it was from them. you will get a reciept from your dealer with the fact that it was gm programmed by them. The bulletin i posted says gm is ok with you adding this to your car. They just arent going to pay to get it done, because there isnt a fault with your vehicle, just like if you wanted the usb port. same thing gm part and program not gonna void your radio warranty.To tell you the truth unless you mentioned the fact of installing them at a later date they probably wouldnt even know since it is a factory switch. I am looking for gm to come out with an upgrade kit for this option anyways. It was way too easy and a ton of people want them.
Old 03-28-2010, 11:13 AM   #49
ShadoChaser
Gamer & Ghosthunter!
ShadoChaser's Avatar
Drives: 2010 GCN 2SS/RS L99
I just check on my LS and all the wires appear to be connected to the SIR Coil. and When I checked the Lt. Green Wire with my Voltmeter, and pressed my buttons. I was able to see the voltage appear and each button was a different voltage, So I guess I'll take it to the dealer with the PIC5320 and ask them to activate it.
Thanks for all the work 'techsupport'
ShadoChaser is offline   Reply With Quote
Old 03-28-2010, 12:05 PM   #50
TA219
Drives: 2010 SS - 1967 327 Coupe
I am so glad to hear about this, my parts are on order now! I already have the PDIM and the bluetooth module, this was the only thing I was missing!
Thanks for the great information!
TA219 is offline   Reply With Quote
Old 03-28-2010, 12:26 PM   #51
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
what does the src button do?
What will work as a plug and play if we cant get it programmed from our dealership?
SSTony is offline   Reply With Quote
Old 03-28-2010, 01:19 PM   #52
techsupport
if you plug it in the only thing that works when you plug it in is the back lightsof the switch none of the switch buttons function until programmed. the src button is for source (am,fm,xm,aux jack, or ipod) it will toggle between the bands and accessories.
Old 03-28-2010, 01:22 PM   #53
techsupport
thanks shadochaser for letting me know the wire is there let me know how it goes at the delaer. i have a feeling tomorrow will be a busy day for dealers in both parts for the wheel and programming them.
Old 03-28-2010, 01:45 PM   #54
Z28COP
Z28COP's Avatar
Drives: 2011 SGM 2SS
Shadow Chaser, Can I just swap out the steering wheel and swap the air bag and them I'm good to go for the BCM update? Bought a Brand New 2SS Strg. Whl on a website.
2011 SGM 2SS: CAGS, NPP Exhaust, ZL1 Wheels/Tires, 3.91 gears, 1LE track pack suspension, ZL1 Shifter, ZL1 Fuel Pump, 1LE catch can, 1LE Splitter. 2012 Steering Wheel.
Z28COP is offline   Reply With Quote
Old 03-28-2010, 02:22 PM   #55
ShadoChaser
Yeah, That's just what I did, I bought a wheel of EBay and used my airbag. It looks like I just need to get the BCM Updated!.
Old 03-28-2010, 04:19 PM   #56
Z28COP
Z28COP's Avatar
Great! thanks
Use bluetooth phone for both phone and audio? gmunson Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 8 12-24-2009 08:22 PM
My Camaro Experience...a good read, but long. Mr. Wyndham 5th Gen Camaro SS LS LT General Discussions 83 09-28-2009 10:19 AM
2010 Stang vs Camaro (seems unbiased) MerF 5th Gen Camaro SS LS LT General Discussions 17 02-09-2009 11:11 AM
