sjm autoprod
Old 03-27-2010, 01:25 PM   #1
mikey8
mikey8's Avatar
Drives: 2SS/RS Transformer LS3
LS3 on Dynojet low?
UPDATE: DYNO SHEET ADDED POST #10
DynoJet 352.99 hp, and 345.95. CF: Standard.... I have a CAI, in shipping, and a catback on the car. Are these numbers low, or real? 78 degrees, 30.17 hg, and 44% humidity. They seem low from seeing others here. I could post the printout, if my frickin scanner worked. He told me those were real numbers. He said that the dynojet was accurate because he can't play with weather settings? I dunno
mikey8 is offline   Reply With Quote
Old 03-27-2010, 11:12 PM   #2
moiy1983
moiy1983's Avatar
Drives: 2010 camaro ss/rs
i think that is kinda of low did he tune it or was that stock? to give u an idea i have a ls3 with a lmr cai and kooks full exhauts ( long tube headers and catted exhaust) and a tune it base lined at 386rwhp and after the tune it was right at 400rwhp (sae setting on the dyno). i mention that because he changed it to std it was 408rwhp.
moiy1983 is offline   Reply With Quote
Old 03-27-2010, 11:18 PM   #3
2010SSRSM6
SoCal C5 Family Member
2010SSRSM6's Avatar
Look at your graph and see what settings were used. STD or SAE? What smoothing? Those are pretty low for an LS3. Was traction control AND stabilatrak off?
UNDER CONSTRUCTION. ETA 2017 ish...
Old 03-27-2010, 11:26 PM   #4
linkwpc
The punching cat
linkwpc's Avatar
Drives: '10 Camaro SS Black W/Hugger&W/IOI
You could just have some bad gas.
My car build (COTW 7/23/12) - - - - - - > CLICK HERE! : http://www.camaro5.com/forums/showthread.php?t=80725
linkwpc is offline   Reply With Quote
Old 03-28-2010, 12:00 AM   #5
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
Something isn't right. I just put out 400/405 in my headers/exhaust/intake car (sae, not std) on a BONE STOCK tune
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 03-28-2010, 06:37 AM   #6
mikey8
mikey8's Avatar
It was STD:1.01 Smoothing 5. As far as I know, traction contol and stabil trac were on. The only mod I have is a catback. No tune. Oh well, At least I have a base for when I put my CAI on, when it arrives tomorrow. After the intake, I'm done for a while. The next mod will be a tune.
Old 03-28-2010, 07:12 AM   #7
MEDISIN
MEDISIN's Avatar
Drives: 2011 CTS-V Sedan
How many miles on it? 93 octane? Mine was a bit low from the factory too with 354HP and 357TQ on a dynojet. Headers, CAI and a proper tune brought me to 415HP and 412TQ. I figure the factory tune just didn't fit my car well
2012 - Present: 2011 CTS-V Sedan, A6, Airaid, Zmax TB and Tune by R.P.M. = 535 hp/503 lb-ft.
2009 - 2012: 2010 2SS RS IBM M6, MGW Shifter, BMR Trailing Arms/Tunnel Brace, Roto-Fab CAI, VMAX Ported TB, Kooks 6511-Complete (Headers, X-Pipe, Mufflers), dyno tuned by R.P.M. = 415 hp/412 lb-ft.
"Not giving a f*^k is truly the greatest luxury, and no luxury car gives fewer f*^k's than a CTS-V." - Matt Hardigree
MEDISIN is offline   Reply With Quote
Old 03-28-2010, 07:14 AM   #8
mikey8
mikey8's Avatar
2200 miles, 93 octane. It doesn't feel like a slug.
Old 03-28-2010, 07:16 AM   #9
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
You best bet would be to ask the shop what the other stock LS3s are dynoing on that dyno. Your numbers could be normal for that dyno.
Old 03-28-2010, 09:44 AM   #10
mikey8
mikey8's Avatar
UPDATE: I got my scanner to work!!!! He only did 2 pulls, as I wanted to save the last for my CAI, on Monday. BTW, he was in 4th gear, I think, for the final pull with the most hp.
Old 03-28-2010, 09:58 AM   #11
mikey8
mikey8's Avatar
I think I'm the first Camaro LS3 they have done. I guess I'm the baseline. I was talking to him about a tune, for shits and giggles, and he said he uses EFI live.
Old 03-29-2010, 12:42 AM   #12
2010SSRSM6
2010SSRSM6's Avatar
With Traction control and Stabilitrac on you will not get a correct read. Hold the button down for 7 seconds next time and see what happens. You should see somewhere near the 370-380 on both HP and TQ.
If I'm not mistaken, STD should show HIGHER numbers than SAE.
Old 03-29-2010, 09:32 AM   #13
mikey8
mikey8's Avatar
Thanks bro. When I got in after the dyno, the stabiltrac light was on. He said I would see that and maybe the abs light because the rear tires were moving and the front was not. Is that any indication that TC and ST were on?
Old 03-29-2010, 11:02 AM   #14
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Any dyno is ONLY AS ACCURATE as the Input Sensors, and Dynojet has a 10% acceptable Error on they're sensors.
LS3s Dyno 372-378 RWHP, they must be fully up to temp, the oil must be fully up to temp, and 4 dyno runs should be made and average the best 2, the first two will be low if not warmed up.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
LS3 engine specifications Tran Wiki 3 10-06-2010 10:56 PM
Advice---Supercharged L99, S/C'd LS3 or LS9? CamaroZR1 Forced Induction - V8 25 09-25-2008 09:21 AM
LS376/480 EFI LS3 Gen IV V-8 NOODLESgoneWILD Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 09-04-2008 08:14 AM
corvettes LS3 vs Camaros LS3 Caliman93230 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 09-02-2008 10:52 AM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 10:06 AM
