Old 03-28-2010, 08:17 AM   #1
rex113
rex113's Avatar
Drives: 2010 2ss silver/cyb
Barton shifter (boot)
I am ready to drop the hammer on a Barton short throw shifter. Can someone who installed one answer this question.I want the flat stick,but the boot on the console seems to have a round chrome ring on it, does this have to be removed or modified to get the thicker (flat stick) shifter through it?
rex113 is offline   Reply With Quote
Old 03-28-2010, 08:48 AM   #2
Daddyo01545
New England C5 Member
Daddyo01545's Avatar
Drives: 2010 Camaro 2SS/RS
Not sure what chrome ring you are talking about....if you are referring to the chrome ring is part of the stock shifter. Once you pull it (knob) off and remove the boot from the stock shifter - no more chrome ring. The Flat Stick will no doubt have a method for the top boot install such as a ring. The boot is attached by a zip tie in both the stock and aftermarket shifters.
Daddyo01545 is offline   Reply With Quote
Old 03-28-2010, 08:51 AM   #3
Slim2SS
Black Thunder
The chrome ring on the stock shifter is removed when you install the new shifter. It is attached to the leather boot with a Zip tie. Bartons shifter has a grove machined into it for the boot to attach to with a new zip tie supplied in there kit.
Slim2SS is offline   Reply With Quote
Old 03-28-2010, 09:32 AM   #4
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
Just do it ! The Flat stick is a great Mod and a huge improvement over the stock shifter. When installing just take your time with the dust boot underneath. Most vibration problems are due to this being installed incorrectly.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
DIY Hurst Short Throw Shifter Install - Pix and Video TAG UR IT Camaro DIY & HOW-TO instructions & discussions 121 02-26-2015 11:08 AM
TAG's 2010 THRSS #2 TAG UR IT Member Car Journals 3129 08-14-2014 10:29 AM
My Shifter Review – Factory vs Hurst vs MGW caverman V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 46 02-02-2013 05:03 PM
Pic's of Aftermarket Shift Knob on Stock shifter stalk jammer174 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 12-04-2010 09:49 PM
Barton Shifter wbt V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 18 08-10-2010 01:56 PM
