Emblempros
Old 03-29-2010, 10:50 AM   #1
eastwood
eastwood's Avatar
Drives: Blown 2010 Orange camaro ss/rs
problem with sub install
i tried hooking up a rockfost punch 900 and did the hook through the
DYI article on this site. everything went well till i hook the rca plug that i hooked up (just did the right side and spliced in to the dark blue wire for + and the tan wire for - ) when i turned the amp on there was a loud high pitch tone from rear stock speakers... Now the wierd thing is i took the -off the tan wire and it worked?????
i have two 10 inch subs and i used a double male plug to plug into my left and right channel on amp. and just running off the + only on right side of vehicle oem amp..
what am i doing wrong???
thanks
Clint
eastwood is offline   Reply With Quote
Old 03-29-2010, 04:53 PM   #2
mrray13
mrray13's Avatar
Drives: 2010 1LT RS Rally Yellow
Do you have the Boston Acoustic factory system? How about pics of how you set up off the speaker wires?
PacMan
mrray13 is offline   Reply With Quote
Old 03-29-2010, 05:49 PM   #3
eastwood
eastwood's Avatar
yes it is a boston system... and i will get some pics soon
Old 03-29-2010, 06:42 PM   #4
mrray13
mrray13's Avatar
You need to make sure you aren't grounded elsewhere, that you got the lowlevel side and that you aren't back feeding. Almost sounds like you are grounding somewhere else, if you grabbed the right wires, and causing a backfeed.
PacMan
INSTALL OF BARTON SHORT THROW SHIFTER BLACK10 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 141 03-20-2017 11:01 PM
Header install problem, need help 1977and2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 39 02-15-2010 01:02 PM
P0300 Misfire Code Help black-knight 4th Generation Camaros 4 02-08-2010 02:45 PM
SLP header install problem kunkelz28 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 10-01-2009 10:57 AM
Somewhat Annoying Back Seat Problem! ZNOLMT 5th Gen Camaro SS LS LT General Discussions 5 06-21-2009 10:22 AM
