Solo Performance
Old 03-30-2010, 12:05 PM   #15
Will@Apf
Will@Apf's Avatar
Drives: corvette
Originally Posted by Brian@Vortech View Post
The engine is a stock LS3 block, 405 cubic inches, 8.6:1 compression, stock LS3 heads ported by Wicked HP to flow 400cfm, Wicked HP custom grind cam, stock intake manifold, stock throttle body, Doug Thorley Tri-Y Headers, Custom Exhaust out the back, 91 Octane pump gas, Vortech V-7 YSi-Trim Supercharging System with optional 50mm cog drive, custom tuning by Cody Chapman @ Wicked HP.
As far as hp draw from the blower, Vortech features the most efficient superchargers in the industry, so due to the efficiency and design of the Vortech centrifugal compressor it will certainly be far less than any other Supercharger...no matter which brand you choose!
Great job Brian! looks good..
Will@Apf is offline   Reply With Quote
Old 03-30-2010, 12:09 PM   #16
Z_Rocks
Z_Rocks's Avatar
Drives: everyone crazy...
@ Brian: But, that's not what I asked if Vortech is more efficient than other supercharges. I was asking how much power will it draw from the engine to produce that much volume of air. I'm sure these tests are done at your facility, but if you don't want to divulge the info, I can understand.
Z_Rocks is offline   Reply With Quote
Old 03-30-2010, 12:16 PM   #17
djw32
Drives: on blocks
That supercharger sounds insane! Very nice work
djw32 is offline   Reply With Quote
Old 03-30-2010, 12:39 PM   #18
Fritostud
Drives: 2008 Suzuki Hayabusa2010 2SS/RS M6
VERY VERY impressive!!! What are you doing for fuel??
Fritostud is offline   Reply With Quote
Old 03-30-2010, 12:44 PM   #19
Gotthat02fire
Gotthat02fire's Avatar
Drives: 2010 Camaro 1ss IOM
Wow nicely done!!!!!
Gotthat02fire is offline   Reply With Quote
Old 03-30-2010, 01:29 PM   #20
WickedHp
Drives: WHP1000
Hello everyone,
For those who don't know me, I am cody chapman from Wickedhp las vegas. I think Brian hit on most of the details of our current combination. If you guys have any other questions please feel free to ask, as i appreciate all input so we can always improve our product. I would also like to let everybody know that our current goal has not been met yet. With in 3 weeks we will have 1000rwhp on 91 octane pump fuel and it will be streetable. We have already done startup, idle and driveability on this combo. Stay tuned for updates as, I will be efficient as possible with my replies.
P.S.-I also have and will be posting our other available packages within a couple of days.
Thanks, cody chapman
WickedHp is offline   Reply With Quote
Old 03-30-2010, 02:14 PM   #21
Total_Perf_Eng
Total_Perf_Eng's Avatar
Drives: Corvette
Send a message via AIM to Total_Perf_Eng
Great Job Cody, It looks nice. Your almost there.. Talk to you soon
Total_Perf_Eng is offline   Reply With Quote
Old 03-30-2010, 02:22 PM   #22
SDCamaro10
SDCamaro10's Avatar
Drives: 2010 Camaro 1LT RJT
How about something along these lines for the V6?? We're dying for some FI!
SDCamaro10 is offline   Reply With Quote
Old 03-30-2010, 06:13 PM   #23
Adam@ST
Drives: 2010 SS Camaro
Great numbers!!!
How much boost??
Adam@ST is offline   Reply With Quote
Old 03-30-2010, 06:28 PM   #24
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Originally Posted by Adam@ST View Post
Great numbers!!!
How much boost??
Yes, that looks like a tiny pulley on the blower - how much boost?
Did you strengthen the stock LS3 block in any way ?
Also, I will ask you guys the same question as everyone else - what upgrades did you make to the trans/driveshaft/diff and axles? We are all trying to see what really works.
Thanks.
Old 03-30-2010, 07:16 PM   #25
WickedHp
Drives: WHP1000
Hello everyone,
Here is some answers for you guys, hope this helps.
1)The smoke from under the hood at the end of the run comes from the breather system that is not finished yet. The cause is when you let off the throttle after a hard run the rings will unseal for a split second causing blowby until they recover from the major change in cylinder pressure. We have a solution for this, just have to finish it.
2)I believe the boost is in the 14-16 psi range right now, but i have'nt checked it since we changed pulleys. I want to tune it all the way to 7500rpm first. The 896 run is only at 6000rpm. The 850hp/710tq run was with 12 psi. This engine is extremely efficient so it takes less boost to achieve a big number.
3)The fuel system is a custom system we are working on utilizing the stock pump system as a balance system. We use an eliminator pump for the engine. We are using the eliminator because we will most likely put 250 worth of nitrous on our car when we finished with everything else.
4)The block is a stock ls3 with some internal modifications that we do in house. The drivetrain is all bone stock right now as i wanted to find some limits for our own knowledge. So far with hard street driving and some 7500rpm wot launches in 2nd gear off the clutch we have had no problems. I will let you know when and how we find the limits. For now good job gm.
Old 03-30-2010, 07:56 PM   #26
600hp-lpe
Drives: 2010
thanks for the more detailed info. That makes your power output even more impressive that it is utilizing the base ls3 parts.
600hp-lpe is offline   Reply With Quote
Old 03-30-2010, 08:16 PM   #27
michael's maro
RAM'S CAMARO
michael's maro's Avatar
Drives: 2010 camaro ss
Great job guy's. I want some
michael's maro is offline   Reply With Quote
Old 03-30-2010, 09:22 PM   #28
speedster
SST...
speedster's Avatar
Thanks for the response Wicked...
Looks like you are coming up with a great combination.
Hope it all holds together and if you do pop something in the drivetrain, please post or PM.
Thanks Again and great numbers !!!
Fill her up! A question for Jerseyites and others at the gas pump. Darqueling USA - NY / NJ / PA 24 08-05-2009 01:36 AM
First 8 sec C6 Z06 on pump gas CamaroSpike23 General Automotive + Other Cars Discussion 15 03-20-2009 07:43 PM
Fuel pump or bad tank of gas? Boomer Sooner 4th Generation Camaros 25 01-02-2009 06:34 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 12:20 PM
Hot Rod Pump Gas Drags z28camaro2471 General Automotive + Other Cars Discussion 9 09-02-2007 06:41 PM
