SDPC
Old 03-29-2010, 09:43 PM   #1
426hpss
Drives: black 2010 1ss rs
need help wiring JL cleansweep
i have a 1ss without the BA system, i need inputs from thefront and rear speakers, also the remote wire. i have read all the post and there is no direction to show me how. can anyone help, pics would really help.
thanks jay
426hpss is offline   Reply With Quote
Old 03-30-2010, 10:41 AM   #2
Iomcamaro
The enjoyment never ends
Iomcamaro's Avatar
Drives: 2010 1LT/RS IOM #25223
are you installing subs?
Iomcamaro is offline   Reply With Quote
Old 03-30-2010, 11:56 AM   #3
426hpss
yes
Old 03-30-2010, 06:27 PM   #4
Droid6
Droid6's Avatar
Drives: 2010 Camaro LS
There's a post here by a guy from JLAudio saying the Camaro doesn't need the clean sweep because the stock deck doesn't add any equalization to the signal.
Droid6 is offline   Reply With Quote
Old 04-01-2010, 04:52 PM   #5
Topdown
The wait is over!
Topdown's Avatar
Drives: 2010 Camaro, IOM, L99, Auto
Good info to have right there...
Topdown is offline   Reply With Quote
Old 04-06-2010, 02:06 AM   #6
Hess RS
Drives: 91 Camaro RS
Ive only worked on cars with the BA system, and Im assuming that the non-BA system doesnt have an amp, is that correct?
Hess RS is offline   Reply With Quote
Old 04-07-2010, 09:30 AM   #7
Droid6
Droid6's Avatar
I'm pretty sure there is no amp in the non-ba system. I was going to look to see where the low voltage wires that would go to the ba amp are so I could tap into them for a clean RCA install.
Old 04-07-2010, 09:38 AM   #8
strauchpete
Drives: 2010 Camaro 1LT
I did a clean sweep on my car with out BA.
If you are just doing it as for sub woofers you really dont need a clean sweep you would need more like an audiocontrol line driver.
If you are replacing all of the speakers in the car and adding 4 channel amp you need a cleansweep and a summoning device for the clean sweep since the signals are crossed over you need the summoning device to put it back not crossed over then from there you run it into the clean sweep.
strauchpete is offline   Reply With Quote
Old 04-07-2010, 09:42 AM   #9
strauchpete
Strange if that is someone from JL because I called JL ,we are a dealer of them, and told them what I wanted to do and they said I would need a cleansweep and the summoning device for it.
Old 04-07-2010, 10:56 AM   #10
third1
speed freak
third1's Avatar
Drives: 2012 Cadillac Escalade,10 IOM 2ss
I think you could get by without it.I tested the line ins on the amp and they all had .6 volts going into the amp.
Current:2012 Cadilac Escalade.2011 CVO StreetGlide cammed,tuned&loud. 2010 IMO/IO,custom stripes,GFX,sunrf,solo exhaust,JBA shorties,rotofab,Jannetty tune,Pfadt,JLw6 Audison&Hertz,7/4/09 2GIFKIEJ6A9123779Del 7/10/09 Former Camaros 72 LT1 Z28, 86 z28
third1 is offline   Reply With Quote
Old 04-07-2010, 11:15 AM   #11
strauchpete
.6 v at what volume, I never bothered to test my wiring for it. Only thing that if it is .6 v max I would at least put a line driver on it to boost the voltage to the amp.
Old 04-07-2010, 11:23 AM   #12
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
Audiocontrol processors are the shitz..
Old 04-08-2010, 08:45 AM   #13
third1
speed freak
third1's Avatar
That was .6 at a very low volume. I didn't take a chance and added a Rockford Fosgate 360.1 that I had. I just have to fine tune it.
Old 04-11-2010, 10:34 AM   #14
Go Fast Kid
Drives: Camaro 2010 SS LS7 427ci
Clean sweep install
I spoke with the audio engineers at JL Audio, they analyized the head unit on thier test bench. They believe the dynamic audio range of the head unit is so good no clean sweep is needed.
They did recommend replacing all the speakers and amp which are the week link in the audio system
Go Fast Kid is offline   Reply With Quote
BCM wiring HaZe_X 5th Gen Camaro SS LS LT General Discussions 4 11-03-2012 05:57 PM
Urgent help needed- rear speaker/sub wiring Arachnyd Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 1 01-13-2010 08:35 PM
Camaro Factory Wiring Diagrams speedster Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 3 12-15-2009 04:38 PM
Anyone have picts/info on the factory infotainment system wiring harness & plugs? Matt'sSS Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 3 10-01-2009 12:48 AM
