JDP Motorsports
Old 03-30-2010, 10:51 AM   #1
mcdoogle6969
mcdoogle6969's Avatar
Drives: 2010 Camaro SS, 2008 Heritage 300C
Question on NOS
I have a CAI and axle back exhaust installed on my SS right now, Headers are at the shop and waiting to go on with a tune. I was thinking about also getting a 120 shot of NOS added on there so if i got it down the road i wouldn't have to pay for a second tune. What do you guys think? Is spray pretty fun?
This will be a substitute until i can one day afford a blower. (i hope this is the right thread)
mcdoogle6969 is offline   Reply With Quote
Old 03-30-2010, 11:24 AM   #2
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
With GM cars you really need 2 tunes and the ability to switch between them for use with NOS.
So An SCT tuner might be a good choice.
You need to pull about 6 degrees of timing for 120 HP, the other Option might be the addition of the MSD LS timing control.
Good Luck and Be careful, Monitor your bottle pressure and temp carefully.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 03-30-2010, 12:01 PM   #3
mcdoogle6969
Good info! Now for your opinion, is a bottle worth the price?
Old 03-30-2010, 12:08 PM   #4
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
The bottle is one of the best $$/hp mod out there.
For timing you can reflash the ECM with a nitrous tune when you want to spray or you can tie into your IAT and pull timing that way. You can also use a timing box to pull timing.
EFI Live has a new COS that will pull timing whenever you flip a switch. I installed the pin in the ECM and ran the wire already just need to convert the calibration into the new COS to use it.
You should be safe with a 150 shot. I would recommend a plate system rather than a nozzle setup. I installed a Nitrous Outlet 2010 Camaro Specific kit on the car with a dedicated fuel tank(C16 fuel) and squeezed a 200 shot to start but will work it up to 300 shot. It made 811 tq and 640 hp on the juice.
You can get info on the nitrous kit here:
http://www.nitrousoutlet.com/catalog...=14&section=37
http://www.nitrousoutlet.com/catalog...6&product=3925
I have the nitrous kits in stock so let me know if you want one.
Here is a video I took of the kit installed and purging it a little:
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 03-30-2010, 01:21 PM   #5
mcdoogle6969
That's a pretty cool vid! So it sounds like you need two tunes for the car, one without nos and another for when you want to use it? Or will the switch fix that so whenever i want to use it i just hit the switch and good to go? Can you toggle nos on and off with that?
Old 03-30-2010, 02:07 PM   #6
SRT10KLLR
Depends on how much you spray. On a 50-100 shot you may be able to just use one tune for both NA and nitrous with a little less timing when off the N2O. Or if you use the IAT or COS(Custom Operating System) you just have one tune and when you flip a switch it removes more timing for the nitrous automatically.
I hooked the wire from the ECM to the nitrous switch so when you activate the nitrous it pulls timing too. But that is using EFI Live's new COS that not just pulls adjusts timing but can also adjust fuel when on the spray.
Old 03-30-2010, 02:23 PM   #7
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Bottom line, you can make it as trick as you want. It all depends on how much $$ you sprinkle on it.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 03-30-2010, 02:32 PM   #8
Jekyll-N-Hyde
I put the FU back in FUN
Jekyll-N-Hyde's Avatar
Drives: 1969 SS 396 , 2010 Camaro SS
Pm OrangeChevyII and ask him if anyone is a Bottle Junkie and knows his stuff its him.
However Ted made a VERY good point as always
Jekyll-N-Hyde is offline   Reply With Quote
Old 03-30-2010, 02:33 PM   #9
mcdoogle6969
Haha, alright sounds good guys. I will probably be going with that within the month hopefully. Pretty curious to what the final numbers will be on the car.
Old 04-14-2010, 01:06 PM   #10
guyjusthere
guyjusthere's Avatar
Drives: 2016 2SS Camaro
I have an newer zex kit off my mustang gt...
Will pulling the fuel from the tap on the passenger fuel rail be safe?
I'm only running a 50 shot, so I will not be retarding the timing...
guyjusthere is offline   Reply With Quote
Old 04-19-2010, 12:47 PM   #11
guyjusthere
Bump
Old 04-19-2010, 01:02 PM   #12
JANNETTYRACING
For a 50 shot you will be fine.
At levels above 100 HP I don't like to pull fuel off the rail since when the NOS activates it creates a wicked Low Spike in fuel pressure and a lean condition for about 1 second, and engines fail in Milliseconds.
The dry systems work very well up to 150 HP. all the extra fuel goes through the injectors and no fuel pressure spikes.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 04-19-2010, 02:08 PM   #13
guyjusthere
I have never gone dry. It would be a lot easier. hmm..
Anything different with dry systems?
spray nozzle placement?(in the intake)
Old 04-19-2010, 03:48 PM   #14
JANNETTYRACING
Yes Before the Maf, it picks up the added Air flow and temp drop and adds the fuel automatically.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 07:53 AM
Question re: c.i. displacement and hp Arli 5th Gen Camaro SS LS LT General Discussions 6 03-24-2009 02:20 PM
Bored so Ill ask a speculation question :) BLACK SUNSHINE Camaro Price | Ordering | Tracking | Dealers Discussions 13 02-12-2009 12:16 PM
Ready to place my order this week - One Question BLACK SUNSHINE Camaro Price | Ordering | Tracking | Dealers Discussions 9 01-21-2009 10:20 PM
IRS question 454lsxss Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 08-30-2008 10:06 PM
