JDP Motorsports
Old 03-30-2010, 12:43 PM   #1
Mustang Killa
Mustang Killa's Avatar
Drives: Black 2SS
Ls1 ram air intake for 5th gen Camaro..
I miss that intake set up from my 4th gen and have been thinking about making this work on the new car...the link below has a hood that could work because the scoop is close enough to the front..its the closest to the actual SLP hood ive seen..anyone else tried this or considered this?
http://cgi.ebay.com/ebaymotors/2010-...Q5fAccessories
Mustang Killa is offline   Reply With Quote
Old 03-30-2010, 12:49 PM   #2
ron10
Drives: 2010 2SS IOM L99
looks good.
Old 03-30-2010, 03:13 PM   #3
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
I think you'll have a hard time getting the air from the scoop to your intake pipe. There are a couple scooped hoods that have pathways molded in to move the incoming air to the OEM location. These hoods work very well with the the open top CAI's. I also don't see a way for water to be drained off, when it rains. The above mentioned hoods do. I think it's a decent looking hood but you'll have to do a lot of fab work to get it to do what you want. If you have the time, parts, and ability to do it, go at it.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 03-30-2010, 03:27 PM   #4
BabyHauler
Drives: CGM 2SS/RS 6M
Originally Posted by axis View Post
There are a couple scooped hoods that have pathways molded in to move the incoming air to the OEM location. These hoods work very well with the the open top CAI's. The above mentioned hoods do
Where can I find info on the hoods that do route the air to the OEM location?
Z06+Baby= 2010 2SS/RS 6M
BabyHauler is offline   Reply With Quote
Old 03-30-2010, 03:31 PM   #5
axis
Search Ninja
axis's Avatar
Nickey Chicago has the stinger hood and SLP has one as well. RK my have one too, not sure though. If I had the $$, i'd be sporting the Stinger for sure.
Halltech CF 102 fed
Old 03-30-2010, 07:02 PM   #6
Mustang Killa
Drives: Black 2SS
Thats why i was talking about using the LS1 intake set up, the front facing intake that is straight forward instead of the bend to the side..
Old 03-30-2010, 08:14 PM   #7
axis
Search Ninja
axis's Avatar
There are MANY problems with that setup though. There's not much room between the opening and the TB. In that area, you need to drain the rain, straighten out the airflow, add in a PCV tube, and put a MAF in. All this and keep from throwing codes and causing driveability problems. You just need to look at the problems that New Era and VR were having with their OTR CAI's. It's an ambitious project but if you have the ability, make it work.
Halltech CF 102 fed
Old 03-30-2010, 09:37 PM   #8
SShift
SShift's Avatar
Drives: Only Bowties!
look into the revolution hood. Its the hood the car should have come on.
SShift is offline   Reply With Quote
Old 03-30-2010, 11:24 PM   #9
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
RKsport's "Ram air" hood does exactly this, with ducting to drain water as well as two heat extractors. Click the picture in my sig for more pics of it.
Hot air Intakes -By Kenne bell ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 66 02-08-2011 09:33 PM
K&N TYPHOON Air Intake Kit - On Sale ~ Bolt on 18+hp! Circuit Motorsports V8 Bolt-Ons & Tunes 101 02-06-2010 01:16 AM
