Cold Air Inductions
Old 03-30-2010, 01:33 PM   #1
trudawg660
Drives: 2006 Dodge Charger / 2SS IOM
Tap shift
ok i just upgraded from the v6 to the v8 a couple weeks ago and in the v6 when i used tapshift it downshifts by itself all the way to first gear. in the v8 while using tapshit when i come to a complete stop it stays in 2nd gear is that normal?
and with the v6 from a stop you could only be in 2nd gear, with the v8 i can start in 3rd is that normal? and my last question while you are using the paddle shifters is AFM turned off?
trudawg660 is offline   Reply With Quote
Old 03-30-2010, 01:47 PM   #2
ron10
Drives: 2010 2SS IOM L99
when you are using tap shift,you hand shift to first.the afm does not shut off.i never use it.i find it more fun to put it in "S" mode.more responsive.oh yes with the tap shift you can start in whatever gear you want.
Old 03-30-2010, 01:56 PM   #3
TapShifting is awesome.
Old 03-30-2010, 02:50 PM   #4
trudawg660
for example im in 6th gear doing 60mph while in tap shift. i come to a complete stop without touching the shifter it suppose to downshift. the v6 downshift all the way back to 1st gear by itself. and the v8 downshifts to 2nd not first.
Old 03-30-2010, 02:53 PM   #5
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
To your question ... The SS only downshifts to 2nd and the LT downshifts to 1st. If you want 1st in the SS you have to Tap it there yourself ...
Old 03-30-2010, 02:57 PM   #6
trudawg660
i wonder why. if your using tapshift i doubt your really trying to save gas. but you can if you want to because it will let you shift up to 3rd gear from a dead stop
Old 03-30-2010, 03:04 PM   #7
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
Just one of those things that GM did to improve on the overall mileage of the car as all OEM's have to maintain a minimum CAFE (Corp Avg Fuel Economy) rating over the entire line and every little bit helps in that regard.
To answer another question you had in your first post. I find the AFM very rarely engages when in M mode. And always engages in D or S.
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 03-30-2010, 03:23 PM   #8
Dave2SSRS
Dave2SSRS's Avatar
Drives: 2010 Camaro 2SS/RS
Tapshift does only downshift to 2nd. It is is the manual.
RTFM!! LOL! ;-P
Dave2SSRS is offline   Reply With Quote
Old 03-30-2010, 03:27 PM   #9
calmaro
Drives: 2013 BMW 128i
Does Tapshift mode rev on downshifts?
calmaro is offline   Reply With Quote
Old 03-30-2010, 03:43 PM   #10
SlingShot
SlingShot's Avatar
I can only base off of what my LT does, but the answer would be yes if downshifted manually ... But the computer will only let you do it within a certain RPM range. If the RPM is to high the computer denies the shift ...
Old 03-30-2010, 04:04 PM   #11
hypurone
hypurone's Avatar
It does on my SS. Really nicely too!
Old 03-30-2010, 04:57 PM   #12
GoldBowtie
GoldBowtie's Avatar
Drives: 2010 2SS/RS L99, 15 Yukon Denali
One reason might be the very short distance you can move in first before shifting ---- about 3/4 of the way across most intersections. I find second gear works great for "normal" starts and if you use first gear --- be ready to shift in about 50 feet!
2SS/RS Silver Ice/Black L99 - Delivered 5/15/09
GoldBowtie is offline   Reply With Quote
Old 03-30-2010, 04:59 PM   #13
Dave2SSRS
Dave2SSRS's Avatar
Sooooo true! but MAN does it launch nicely in first!! LOL!
Old 03-31-2010, 02:07 AM   #14
petman
Proud IBM Owner
petman's Avatar
Drives: 2010 1SS-RS
If No one answered YOU... yes that is normal.... I got back in mine today after a Nov 1st lay-off till Today Mar 30th storage,,,,and only had 670 miles on it... but remembered you have to DROP it to 1st.... it'll stop at 2nd when in tap shift... and it'll be something to toy with to learn... man...just un-bagged mine after 5 months. it has 680 miles on it and started right up...and smells NEW
My Baby, 1SS/RS Auto
petman is offline   Reply With Quote
Super Sale on Raptor Shift Lights @ KY SPEED FRCBobby Audio / Visual / Electronics/ Gauges / Nav 44 11-25-2011 11:34 AM
Did Camaro (automatic) reviewers use tap shift ? trudawg660 5th Gen Camaro SS LS LT General Discussions 30 11-09-2010 08:55 PM
Tap Shift When to Use NoFatChx V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 03-24-2010 10:18 AM
Tap Shift on the Stick ttss V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 14 12-09-2009 08:44 AM
Tap Shift not standard? MB2010CC 5th Gen Camaro SS LS LT General Discussions 8 11-10-2008 12:30 AM
