JUICEDMOTORSPORTS
Old 03-31-2010, 02:25 AM   #1
RBC2010SSRS
RBC2010SSRS's Avatar
Drives: 2010 SS RS 6spd. 402 rwhp
HOME MADE CAI cont. Heat Sheild fab 1st attempt
All posts have generally all said a heat shield is necessary. THIS IS NOT MY FINISHED FABRICATION. Just need more time, one more attempt with with a larger piece of aluminum and a distributer that sells rubber weather stripping. It is SOOOO ugly right now, I need rubber!!!!
All comments negative or positive help the process.
LS3 dreamin
RBC2010SSRS is offline   Reply With Quote
Old 03-31-2010, 03:00 AM   #2
RBC2010SSRS
this would be the model from scratch.
LS3 dreamin
Old 03-31-2010, 04:19 AM   #3
Soundwave
Soundwave's Avatar
Drives: Camaro SS(2)/RS
Aluminum conducts heat a lot faster than stainless or plastic (like all the other heat shields). You won't be doing yourself any good after it heats up with the rest of your engine bay.
Soundwave is offline   Reply With Quote
Old 03-31-2010, 05:43 AM   #4
69lt1bird
69lt1bird's Avatar
Drives: 1969 Pontiac Firebid
Here s what you need.
http://www.eplastics.com/Plastic/ABS...-Plastic-Sheet
Free HP Tuners Beginners Tuning Guide
Michigan Snowmobiler
1969 Firebird: 7.55@97.93 1/8 1.70 60 ft.[/COLOR] EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
69lt1bird is offline   Reply With Quote
Old 03-31-2010, 06:00 AM   #5
g-townmach
I FARTED
g-townmach's Avatar
Drives: 2010 2SS/RS
Make a simple drawing and get a machine or fab shop to bend one up for you if you don't have access to a press brake.
For weatherstripping, sealing, adhesives, radiant heat insulation and just about anything else you'd ever need go to www.mcmaster.com
g-townmach is offline   Reply With Quote
Old 03-31-2010, 11:39 AM   #6
RBC2010SSRS
THANKS GUYS, the aluminum was malleable so it was easy to see how it need to fit in there.
G-townmach, did a machine shop fab that exhaust bracket for you??
LS3 dreamin
Old 03-31-2010, 11:42 AM   #7
RBC2010SSRS
Originally Posted by 69lt1bird View Post
Wow, this site has almost everything....
LS3 dreamin
Old 03-31-2010, 12:09 PM   #8
g-townmach
I FARTED
g-townmach's Avatar
Drives: 2010 2SS/RS
I'm a machinist. I made it myself. Not a bracket. It's a driveshaft tunnel brace.
Old 03-31-2010, 12:15 PM   #9
RBC2010SSRS
I envy your job, I went to tcu and played football there. Should have just went to a trade school
LS3 dreamin
Old 03-31-2010, 12:38 PM   #10
g-townmach
I FARTED
g-townmach's Avatar
Drives: 2010 2SS/RS
Haha... I'm a Blinn college dropout.
Well it looks like you've got some mechanical skills regardless. Keep working on your cai, I'm sure it'll turn out great.
If I were you I'd just go to your local fab shop and get em to bend you up a simple aluminum shield. Then just line it inside and out with some radiant heat insulation foam.
Old 03-31-2010, 12:44 PM   #11
RBC2010SSRS
Do you think your brackets increase torque? I know the more solid things are the better the motor can torque it around.... Like engine mounts and such...
LS3 dreamin
Old 03-31-2010, 12:55 PM   #12
g-townmach
I FARTED
g-townmach's Avatar
Drives: 2010 2SS/RS
I don't know about increased torque, but they do keep the driveshaft tunnel area from flexing so much. PM me if you want more details... We don't want to hijack your thread.
Old 03-31-2010, 01:54 PM   #13
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
Looks like you're on the right track RBC!
Old 03-31-2010, 02:01 PM   #14
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
I spent 25 years as a tool maker / millwright, it was fun for the first 5 years ... LOL ...
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 10:40 AM
I made it home. Beemer Camaro Photos | Spyshots | Video | Media Gallery 16 10-15-2009 10:41 AM
