Solo Performance
Old 03-31-2010, 08:30 AM   #1
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Exclamation GM Fix: High/Low Octane Map!
Can anyone validate whether GM fixed the problem of the low octane map & the fuse reset to assist in correcting the problem?
Also, those of you with early VIN #'s & performed the fuse reset, did the problem (drop in horsepower) eventually return? Did the dealer admit the problem & reflash to permanently correct???
According to Livernois Motorsports, stock baseline dyno for the SS are showing 360-370 rwhp, some of you are reporting 320 rwhp & you accept there is nothing wrong with you car?
Smirnoff is offline   Reply With Quote
Old 03-31-2010, 08:35 AM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
I guess you don't know that the SS comes in two different engines. LS3 equals manual 6, 426hp, typically dyno's in the 360+ range. L99 equals automatic 6, 400hp, typically dyno's in the 320-330 range.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 03-31-2010, 10:02 AM   #3
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Thanks for keeping me honest - yes I know of the LS3 & L99 & the HP difference, for clarification many on this board with the LS3 claimed 320 RWHP was valid & is a good number.....?
But, the BIGGER issue is whether GM has a permanent fix or not? I would hate to keep pulling fuses to get the car to run right, what type of quality is that???
Old 03-31-2010, 10:22 AM   #4
kdbolt70
kdbolt70's Avatar
Drives: 2010 Camaro 2SS/RS
To be honest, I do notice a difference in fuel tables. But that difference is realized based on what gas I use. Premium from Speedway, for example, is noticeably slower than Premium from Shell. Just my observation.
2SS/RS Victory Red M6 w/ Black Rallys #3305
Muffler Delete, Lloyd "SS" Floormats, K&N Aircharger, Skip Shift Eliminator, Blacked Bowties
kdbolt70 is offline   Reply With Quote
Old 03-31-2010, 11:46 AM   #5
ron10
Drives: 2010 2SS IOM L99
i only use shell 93.it is a "top tier" gas.the fuse pull is simply a method to reset your computer for the high octane gas.the dealer put 87 octane in my car.this does not void your warranty
Old 03-31-2010, 11:52 AM   #6
brtaus
brtaus's Avatar
Drives: None
Circle K/QT premium is same way; I only use Chevron or Shell premium.
brtaus is offline   Reply With Quote
Old 03-31-2010, 12:03 PM   #7
Mr Smith
Born again Hot Rodder
Mr Smith's Avatar
Drives: Black 1SS/RS LS3 M6
Yup..Switched to Chevron from Costco...Big difference in price but the mileage and hp gain was even better...18+ mpg around town with my foot in it constantly.
Mr Smith is offline   Reply With Quote
Old 03-31-2010, 12:20 PM   #8
SharpSS
SharpSS's Avatar
Drives: Decked Out Inferno Orange 2SS
Damn! I can't even get that on the highway.
SharpSS is offline   Reply With Quote
Old 03-31-2010, 12:22 PM   #9
wbt
Drives: 2010 Challenger R/T;2011 Mustang GT
Checked my DIC and I am averaging 18.5 here. City driving for the most part.
wbt is offline   Reply With Quote
Old 03-31-2010, 12:22 PM   #10
RedJewel2SS
12.23s@113mph
RedJewel2SS's Avatar
Drives: 2SS/RS, A6, just a few bolt ons
the octane map your referring to is just from the dealer you bought the car from putting their 87 octane they keep on the lot cuz they're too lazy to drive down the street and put the proper fuel in it
RIP Cammie 7/15/2009 - 4/1/2011
RedJewel2SS is offline   Reply With Quote
Old 03-31-2010, 12:54 PM   #11
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Right -- the problem is when 91 or 93 octane is then poured into the tank, the low octane map doesn't convert to the high octane map....my question is, did or does GM have a permanent fix?????????????????
Other than pulling the fuses?????????????????????????????????????
Old 03-31-2010, 01:43 PM   #12
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Same here, think I'm getting 14 and change ... and 17 and change on my LT ...
Old 03-31-2010, 01:50 PM   #13
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
I know I shouldn't but....
Show-off!
Old 03-31-2010, 01:52 PM   #14
Iwantone2
Iwantone2's Avatar
Drives: CGM 1SS RS
Could the fuel have come from the factory? When I bought my car, my salesmen let me take the car to fuel it up myself. Put 91 in it and I still had to do the fuse pull.
What type of fuel to use? Matth3w 5th Gen Camaro SS LS LT General Discussions 13 03-24-2010 12:56 PM
Anyone running something other than 87? jeansonne627 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 31 10-01-2009 02:40 PM
No 93 Octane in California tribone Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 15 08-27-2009 04:18 PM
Hmm...higher octane? Shadowsong Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 27 08-29-2008 06:29 AM
Octane Booster and synthetic oil big_bank5000 5th Gen Camaro SS LS LT General Discussions 25 05-14-2008 03:32 PM
