Emblempros
Old 03-31-2010, 08:41 AM   #1
Huggerorange73
Banned
Drives: The REAL C5
Send a message via AIM to Huggerorange73
My dyno results for a stock LS3...discuss
Okay, so I drove down the Straightline Performance to get a baseline dyno pull. I pulled the Roto-Fab CAI induction off the car for the pull. Once I got home, I put it back on along with the SLP LM II.
Are these numbers out of line? Seems that alot of people think there results are "off".
Huggerorange73 is offline   Reply With Quote
Old 03-31-2010, 10:14 AM   #2
ULTRAZLS1
ULTRAZLS1's Avatar
Drives: 14 Silverado LTZ Z71, 16 Camaro SS
Dont I know you from ls1tech?
Probably just differences in dyno. But that is a solid pull especially for a mustang dyno. The most common number for the new camaro is 36x to 37x. I have seen some 38x and 39x but those are usually dynapack or dynojet dynos. I havent seen a mustang dyno read out as high as yours for a stock car yet.
One possibility is that your car may have slightly adjusted its computer for when you had the rotofab on...and then when you took it off and went to the dyno it could have still been running different parameters and effected the numbers.
See if you can get another 6 speed car to pull on the same day as you and see what happens.
Also...doesnt your car have a couple thousand miles on it? A lot of motors are known to pick up about 10-15 hp after break in...this could be part of the equation also. A lot of dynos I have seen around here are on cars with less than 500 miles on them.
Black 2016 1SS A8 NPP
Drag pack, CAI, Headers, Mamo ported MSD intake, Pray ported TB, E85
1/4 - 11.10@122.08
1/8 - 7.15@97.83
+1500 DA 1.64 60 ft stock converter 3740 RW
ULTRAZLS1 is offline   Reply With Quote
Old 03-31-2010, 10:20 AM   #3
Meister@Torq
Drives: 2001 Crown Vic
Send a message via AIM to Meister@Torq Send a message via MSN to Meister@Torq
I think the HP@50 number is a bit on the low side. I would have them use something like 13.5-13.75, which is a pretty good guess and this will change the numbers some.
Meister@Torq is offline   Reply With Quote
Old 03-31-2010, 10:22 AM   #4
J-Rod6410
M6 10 second club
J-Rod6410's Avatar
Drives: A 4000 Lb BeaSSt
Your dyno graph reads out at 369 max horsepower.
Your text on the sheet reads 391 max horsepower.
There is a misprint somewhere. 369 sounds perfect for this dyno.
TEAM LS3 Best pass: 10.49 @ 135 with M6
730RWHP 650RWTQ ECS S/C stock bottom end, 4L80, 9"
Built by: J-Rod.... Tuned by: Matt Sorian @ FSP (floridaspeedandpower.com)
Check out my youtube channel: http://www.youtube.com/user/6410Jrod
Follow me on Instagram: @J_Rod6410
J-Rod6410 is offline   Reply With Quote
Old 03-31-2010, 10:59 AM   #5
Huggerorange73
Banned
Drives: The REAL C5
Yup, I'm on tech as well....All of your logic sounds reasonable to me. Car does have over 2K on it.
I'll relay the message, thanks!
Good catch...how the hell did I miss that?!?!
Old 03-31-2010, 11:44 AM   #6
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
I think the numbers on the lower sheet are the adjusted ones. I would say thats about what most ls3's put out stock.
9/26/09 Took delivery!
Old 03-31-2010, 07:07 PM   #7
4xchamp
MURC 666
4xchamp's Avatar
Drives: 69 Pace Car 68 Camaro Restomod 81 Z
Here's mine on the mustang dyno .
Higher #s were with the airbox open , air filter only ( taped to housing )
Guys hoarding their Camaros are depriving some youngster the opportunity to restore it 25 years from now .
Drive it like you stole it , let the next guy baby it !
4xchamp is offline   Reply With Quote
Old 04-01-2010, 01:57 PM   #8
Huggerorange73
Banned
Drives: The REAL C5
Okay, I have confirmed that the dyno was in fact accurate...several other cars went on after mine that day with nuts on readings.
With regards to the graph results off from the cover sheet...the cover sheet is usually always a little higher because it uses SAE standards for correction, where as the graph uses raw data.
Old 04-01-2010, 10:31 PM   #9
MadMav
Drives: 2010 SS/RS M6
Sorry, but the bottom graph is the accurate numbers. No stock LS3 makes 390hp to the wheels. Yours is 369hp/359tq.
Mav
SS/RS M6, SIM, CGM stripes, Barton S/T, BMR trailing arms, ADM Race intake(no scoop), Texas Speed 1 7/8" headers and full 3" exhaust, RMCR custom tune.
MadMav is offline   Reply With Quote
Old 04-01-2010, 10:44 PM   #10
DaveT
DaveT's Avatar
Drives: 2010 2SS CGM LS3
Same that mine laid down stock.
DaveT is offline   Reply With Quote
Old 04-02-2010, 01:06 AM   #11
RBC2010SSRS
RBC2010SSRS's Avatar
Drives: 2010 SS RS 6spd. 402 rwhp
Here is slighltly more than stock DYNO results.... Lots of ppl say they are no good bc they are STD readings....
LS3 dreamin
RBC2010SSRS is offline   Reply With Quote
Old 04-02-2010, 07:05 AM   #12
g-townmach
I FARTED
g-townmach's Avatar
Drives: 2010 2SS/RS
Mustang dynos always produce lower #'s than a dynojet.
They are just #'s. A dyno is just a tuning tool... How does your car FEEL??
g-townmach is offline   Reply With Quote
Old 04-02-2010, 02:24 PM   #13
Jason L
Drives: 2004 Pontiac GTO
There is our's stock. I like to tell people not to get too wrapped up in numbers, it only show's what the car makes that day. Most of the time its pretty accurate but a dyno is just a tool.
Jason L is offline   Reply With Quote
Old 04-02-2010, 04:03 PM   #14
Slowhawk
Drives: 1999 Trans Am
Your #'s look right for the Mustang dyno.The power@50 is close and wouldn't change the output. By the graph I see KR which is typical on these cars.
Slowhawk is offline   Reply With Quote
Stock LS3 dyno numbers?? Spiffyguitar Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 22 02-17-2011 12:16 PM
LS3 engine specifications Tran Wiki 3 10-06-2010 10:56 PM
LS3 Dyno Baseline MickGIS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 01-31-2010 08:24 PM
Stock LS3 Dyno Monte Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 01-21-2010 07:57 PM
ALL Our Camaros are GM Prefer Pricing (old Supplier Pricing) at MacMulkin Chevrolet! MacMulkin Dealer Camaros for Sale 0 01-20-2010 06:40 PM
