Gen5DIY
Old 03-31-2010, 11:11 PM   #1
Jeffro
Jeffro's Avatar
Drives: 2010 Camaro 2SS 6M
Just Installed Halltech Cold Air
I just installed my Halltech Cold Air Intake it was easy to install and the only bad thing I can say about it is the heat shield. The heatshield bows a little bit but no big deal and is a tight fit. The kit does not come with install instructions but the only thing I had a concern about was the rubber hose I cut the factory line and used a hose clamp to attach the rubber hose. What did other people do about the rubber hose?? The air filter touches the washer bottle but no big deal. I did not pull fuses or disconnect the battery I drove the car and right away I noticed a difference. Im happy with it and I purchased it from SouthernCarParts.com because they were the cheapest that I found. I dont plan on dynoing the car but Im sure I picked up 10hp.
Jeffro is offline   Reply With Quote
Old 03-31-2010, 11:15 PM   #2
ron10
Drives: 2010 2SS IOM L99
nice job.how long did it take to install?
Old 03-31-2010, 11:18 PM   #3
wbt
Drives: 2010 Challenger R/T;2011 Mustang GT
I see where you can fix the heat shield. Trim the top gasket about 1/2" back from the front and it will allow the front part of the shield to slide under the frame properly. Loosen the nut on the bracket before doing this and tighten after you have the shield in place. Post some after pics once this is done.
wbt is offline   Reply With Quote
Old 03-31-2010, 11:18 PM   #4
Jeffro
Jeffro's Avatar
It took about 30 mins from start to finish
Halltech cold air intake
ARH long tube headers 1 7/8
3" exhaust no cats
Borla S type mufflers
Diablosport tune
Old 03-31-2010, 11:20 PM   #5
Bellringer
Bellringer's Avatar
Drives: my wife nuts.....
Any sound difference, anything you noticed?
44030 is all mine!
GM
Bellringer is offline   Reply With Quote
Old 04-01-2010, 12:03 AM   #6
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Also make sure the bottom of the heatshield is running along the frame, between the silver AC line and the frame. The first notch in the bottom of the shield should be where the silver AC line crosses over the frame and the one on the back side is where that line exits.
You did the right thing by cutting the platic tube but it looks like you might have cut it a little too far up. The rubber hose shouldn't be bending like that. It's not a HUGE deal but I wonder if the engine cover will fit properly now. That's easily fixed with a trip to your local auto parts store though. Also, you don't need a clamp on that junction. It's made to be a VERY tight fit so one isn't needed.
I imagine if you push the intake tube closer to the TB, it would move the filter away from the washer bottle.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 04-01-2010, 10:47 AM   #7
Jeffro
Jeffro's Avatar
Thanks guys for the input I will adjust the intake tube and the heatshield then I will take pictures to let you guys know what I come up with. The engine cover fits fine over the rubber hose it is just pinched between the cover and throttle body but I dont think its anything to worry about. There is a big sound difference first of all it made the stock exhaust sound a little louder and second when you step on the throttle the intake makes a mean growl due to all the air being sucked in.....it sounds sick!!!!
3" exhaust no cats
Diablosport tune
Old 04-01-2010, 03:23 PM   #8
Bellringer
Bellringer's Avatar
44030 is all mine!
GM
Old 04-01-2010, 03:26 PM   #9
looks awesome
Old 04-01-2010, 06:27 PM   #10
Russell James
Russell James's Avatar
Drives: Camaros
I would take that hose clamp off. You don't wan't sharp edges around the heater hoses. I just pushed the line over it and it seems pretty tight.
I spent a lot of extra time messing with trimming the shield. My L bracket was too low, revitted that a bit higher. Had to trim the fender side of that shield quite a bit down low to get it to push over far enough to be tight against the fender. Then the filter hits the washer bottle. I'll have to figure out how to perfect that. After a day of driving the filter was about to fall off, the pressure from the washer bottle wants to keep pushing it off.
I tried putting it on with no trimming and the L-bracket in its as built spot. The bottom was way off the frame, the shield was bowed, the L bracket was bending up, I'm sure it would have broken off in a day.
On the plus side, the performance seems great. Attention to detail though, I'm handling that. I also wish they would have included a complete hose connection to the pcv so the OE line didn't have to be cut. Some day I'll need to put it back to stock, and will need to buy a new OE hose there with it's special fittings on each end.
Old 04-01-2010, 09:14 PM   #11
Bagzinator
Bagzinator's Avatar
Drives: CGM 2SS/RS
I installed mine yesterday too. The engine now sounds awesome and the throttle response and power are certainly better. My heat shield fits good I did trim about a half an inch off of the front and side to make it fit better. My air filter clears the washer fluid reservoir by about 1/2". I think it is an angle thing you may have the intake tube pushed on too far. Try backing it out a little this will angle the air filter further from the washer fluid reservoir. My only issue is the small rubber hose gets squeezed between the engine and the engine cover. It's not that big of a deal, but I think over time the rubbing will cause the hose to get cut. I will try and post pics tomorrow. All in all I really and happy with this CAI.
Bagzinator is offline   Reply With Quote
Old 04-02-2010, 01:13 AM   #12
axis
Search Ninja
axis's Avatar
It would be easy to take it back to OEM without buying anything. Just keep the cutoff piece and cut a 2-3in piece of the hose off, then push cutoff piece into hose. Instant OEM.
Halltech CF 102 fed
Old 04-02-2010, 01:26 AM   #13
Camaro68
Camaro68's Avatar
Thumbs up
Looks good
Old 04-02-2010, 06:45 AM   #14
Russell James
Drives: Camaros
Hey thanks, I'll do that. I must have fought with that shield so long I overlooked the obvious on how to position the filter and tube better. On that little hose, I got mine positioned better by using a longer rubber hose.
Fastlane Pipeline Cold Air Intake at Phastek Performance Jason@Phastek Performance V8 Bolt-Ons & Tunes 2 03-30-2016 07:19 AM
Roto-Fab Cold Air Intake from Phastek Performance Sean@Phastek V8 Bolt-Ons & Tunes 17 06-09-2010 12:31 PM
Texas Speed Cold Air Install Dyno Results gomer Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 01-26-2010 09:42 PM
Fastlane Pipeline Cold Air Intake Fastlane V8 Bolt-Ons & Tunes 24 01-12-2010 09:35 AM
AirAid Cold Air Intake anyone? FLYNNZL1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 01-01-2010 09:05 PM
